Old Feb 16, 2013, 09:43 PM
Greg Head is offline
Find More Posts by Greg Head
Joined Aug 2012
wow, with the mild asteroid upgrade I was really unimpressed with the performance of this heli until the post man arrived with my nano tech 160mahs. For the people with douts out there it is a huge difference. Just not with tired old batteries. Seems like I will have to track my batteries closer now and only keep the best for the nano. Good thing the others still fly the socks off my msrx and champ, the nano with bl motor just requires fresh hi c rated batteries to fly right.
Greg Head is offline Find More Posts by Greg Head
Old Feb 16, 2013, 09:48 PM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
If you think NanoTech are good. Stalk EPBuddy and order some Glacier 160.
I found they are consistently better than the NanoTech. Cheap too. Words is spreading and thus will make these LiPO harder to source I am sure.
However, if you're getting good batches of NanoTech. That's great indeed.
Daryoon is online now Find More Posts by Daryoon
Old Feb 16, 2013, 09:50 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
im starting to loose faith in Hyperion, my last couple 160s have both had the black part with the plug come unglued, and my second to newest one has completely died after maybe 50 cycles at max. An older one still works fine. New one does seem to have more initial punch than eflite 150s, but not any better run time, sometimes shorter.
seeingeyegod is offline Find More Posts by seeingeyegod
Old Feb 16, 2013, 09:52 PM
Billz_01 is offline
Find More Posts by Billz_01
Billy
Australia, NSW, Newcastle
Joined Jun 2012
I'm just waiting to find out enough info as to whether it is worth spending any money on. I'm having a bit of fun with my larger heli's at the moment, upgrading my 130x mostly.
As for those hyperions, I'm a little on the same side there seeingeyegod. I had to glue my cap back on one of them, and the plugs are not pulled through enough on the other 2 so it doesn't plug in properly. (slides on but falls off in the slightest of crashes). I'm thinking of giving the TP's a go, have heard good things, but for the money side of it I'm just going to get a bunch of nano-techs. My old turnigy packs (before nano-tech) are still good enough to run my micro plane and the msr.
Billz_01 is offline Find More Posts by Billz_01
Old Feb 16, 2013, 10:08 PM
Joined Aug 2012
Don't yell at me because I know that charging batteries is a sensitive subject but is .4 on the celectra charger ok for this size battery. I don't know how I arrived at .4 but both of mine are set there and with how poorly my eflight batteries are performing I was wondering if it was because I am charging at too high a rate. Don't want to ruin more batteries this way if that is the case. Most of the old batteries still give good flight time on other helis but stink in the nano with a bl motor.
Old Feb 16, 2013, 10:34 PM
iTz Nicholas72 is offline
Find More Posts by iTz Nicholas72
Joined Nov 2010
CHARGING AT .4A IS JUST UNDER THE 3C MAXIMUM CHARGE RATE FOR THE EFLITE BATTERIES!
Sorry couldn't help myself...
In all seriousness that's probably a big factor why your batteries are already dropping in performance. Stick to a .2A charge rate or even .1A if your not in a rush and your batteries will thank you.
With that said I charge my new EFlite 35C batteries 6 at a time at .5A each because I consider these tiny 1S lipos almost disposable with how cheap they are. Plus when they don't do we'll in my Nano I retire them to my UM Polecat which is much easier on batteries and get a month or two extra out of them.
iTz Nicholas72 is offline Find More Posts by iTz Nicholas72
Old Feb 16, 2013, 11:19 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
I have one hyperion I got from a LHS, and It had the same problem. I glued it back on, but now it doesn't plug in properly. It goes, but doesn't "snap" in like my e-flights... never had it come loose yet, but I have only flown indoors in my house so far, so no bad crashes... (waiting for snow to melt and grass to dry)
dacaur is offline Find More Posts by dacaur
Old Feb 17, 2013, 06:29 AM
Petrie is offline
Find More Posts by Petrie
United States, AR, Lockesburg
Joined Feb 2012
Anyone know where I can find some bullet blades? I don't see them anywhere
Petrie is offline Find More Posts by Petrie
Old Feb 17, 2013, 07:35 AM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
i have 16 hyperion 160 mah batts (gathered over time) and not one snaps in place, just picked up 4 thunder power 160's and the are more compact and seem to dish out the same power if not more, they snap in better the hyperion, but not as good as stock.
keithy4129 is offline Find More Posts by keithy4129
Old Feb 17, 2013, 11:36 AM
dacaur is offline
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
get a time machine and go forward a month or two... bring some green ones back for me....
Old Feb 17, 2013, 12:51 PM
Alex4R is offline
Find More Posts by Alex4R
Alex4R's Avatar
United States, OK, Tulsa
Joined Dec 2012
According to fastserve, ETA on black, green and orange fast flight blades is 2/21
Alex4R is offline Find More Posts by Alex4R
Old Feb 17, 2013, 12:52 PM
aesmith is offline
Find More Posts by aesmith
Joined Apr 2010
Originally Posted by aesmith View Post
Any hints for tracking down vibration in flight? I can see the tail fin vibrating side-to-side at the bottom. I'm guessing the main rotor blades are out of balance but I spent ages trying to add weight to one or the other without really getting anywhere. I could make it worse, but not better.
Anyone?
aesmith is offline Find More Posts by aesmith
Old Feb 17, 2013, 12:57 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Anyone?
If it isnt blade balance my guess would be feathering shaft either bent or too tight.
indoorheli is offline Find More Posts by indoorheli
Old Feb 17, 2013, 01:34 PM
aesmith is offline
Joined Apr 2010
Cheers. It could still be blade balance, the feathering shaft looks straight using the "take one blade off and rotate the shaft" test. I'll try loosening it. What's the best way to check blade balance? I was getting nowhere trying to think up a way.
Old Feb 17, 2013, 01:38 PM
Petrie is offline
Joined Feb 2012
Are the Microheli or the lynx blades anything like the fast flight blades? There are aftermarket bullet blades for the mcpx and 130x, anyone else make them for the ncpx?
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6160 May 20, 2016 04:10 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
