But scroll down to the bottom of the link and there are some pretty pics that explain it Basically all the weight does is move the CoG closer to the leading edge of the blade, making the leading edge maintain a slight lag angle as it cuts through the air. Here is link to article page...http://www.w3mh.co.uk/articles/html/csm9-11.htm ![]() Here is page 1&2 of the article that explains all the different forces that are in play when flying a CP heli... http://www.w3mh.co.uk/articles/html/csm1_2.htm
Joined Apr 2010
Accucel-6 2 Pin 6 x Pico Plug Charging Set |
Here's a little video taken with a hatcam during an indooor session at Woodland Sports in Grand Rapids. If you like full blown high speed 3d then this video is not for you. I prefer a smoother more deliberate style being that I'm an old 1970's pattern flyer. Hoping to update my camera soon for better quality videos.
eflite has released a 35C 150 lipo that will give you the extra oomph you've been looking for. If your brushless is generally boggy, even with a good lipo, you should use a heavier gauge wire soldered directly to the brushless esc. If you dont have a new female end, just use the one that you cut off the 3 in 1 and splice it to the heavier wire. It will make a huge improvement in power. |
Back "in the day" before 45degree flybars, it was common to have weights (basically, wheel collars) on the flybar, which, due to the added spinning weight, tended to slow down your inputs and make the heli more manageable for someone learning. As you gained skill the weights would actually start to hinder you, at which point you moved them in toward the center or took them off entirely. |
| Thread Tools | |
| Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter | zadaw | Micro Helis | 5193 | Today 06:30 PM |
| Discussion is there anything better than mcpx v2 at same or smaller size? | Legendary_Agent | 3D Electric Heli Flying | 33 | Feb 24, 2012 08:46 PM |
| Question What’s Better than a Blade CP and Smaller than a Trex? | HavingFun2002 | Micro Helis | 74 | Mar 05, 2006 05:07 PM |
