Old Feb 11, 2013, 10:18 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
Ok replaced the Main Shaft. Checked everything as I went, looking for cracks, flex points. It did take out 98% of the vibration and appears the Shudder is gone. Could not see anything wrong with the shaft just eyeballing it.
Found the AR pin bent off to one side on the swash. Found my swash riding really high in the back and had to redo the Zero Pitch on it. Was way off! Not sure how it got to be that way, but you could see the Elevator Link jacking the rear swash pin too high. Now it does Pumps really good and I can drop if from the ceiling and catch it on a dime.
As soon as I put it back together though, had Major Tailwag like never before. Shudder and vibrations gone but tail was really pulsing continuously. Played with the FS tension and blades and got it back to where it was previously, minor wag. Going to replace the Swash tomorrow night and lube it up again. Wondering about the bearing in that Swash. Feels like it is catching and a little noisy.
Flew 3 test flights, semi satisfied, just want to rid it of the annoying wag now. Putting the Bullets back on to test with after the Swash swap....
heritageflyer is offline Find More Posts by heritageflyer
Old Feb 12, 2013, 12:57 AM
Billz_01 is offline
Find More Posts by Billz_01
Billy
Australia, NSW, Newcastle
Joined Jun 2012
Got my airtime skids today, followed the youtube install instructions and they went in perfectly...
Didn't take long to get here and Rich was a great bloke to deal with. Definitely a must have upgrade. Makes getting to the main gear much easier also.
Wish he had a frame made out of this stuff.
Billz_01 is offline Find More Posts by Billz_01
Old Feb 12, 2013, 04:49 AM
merdock is offline
Find More Posts by merdock
South Africa, KZN, PMB
Joined Apr 2012
Does anyone know anything about rudder to elevator mixing? For smoother sport circles and piros. I have a Dx7 Tx
merdock is offline Find More Posts by merdock
Old Feb 12, 2013, 09:38 AM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
You could certainly set up a mix, but you won't learn how to fly that way. I suggest that you learn to fly the bird, rather than rely on a crutch. Master nose-in hovering, Practice flying slow circuits & figure-eights. Practice slow piros. Practice, practice, practice. That's how you become a proficient heli pilot.
Joel
turboparker is online now Find More Posts by turboparker
Old Feb 12, 2013, 10:38 AM
Kilo60 is offline
Find More Posts by Kilo60
Plane Crazy!!!
Ft. Lauderdale, FL
Joined Sep 2006
Going through the spare parts bag that came in the box and am wondering what the canopy gromets and two black counter weight looking thingies are for?
Doesn't have them listed in the manual anywhere?????
Kilo60 is offline Find More Posts by Kilo60
Old Feb 12, 2013, 11:40 AM
iTz Nicholas72 is offline
Find More Posts by iTz Nicholas72
Joined Nov 2010
Black counter weight things if I'm understand you are actually the tools for the spindle and servo nuts.
iTz Nicholas72 is offline Find More Posts by iTz Nicholas72
Old Feb 12, 2013, 12:37 PM
merdock is offline
Joined Apr 2012
Joel
Thought I could fly this thing. Cos I can fly a sim but I can only hover it tail in. Its to small to see. So I have to fly low and close by. I need to fly in a large grass field. Not my back yard where it likes to crash on the only concrete in the yard. I managed to mix (Rudder to Aileron +15% (on both) & 20% (on both) rudder to elevator), for piros. Managed to piro it almost perfectly without any deflecting.
Old Feb 12, 2013, 12:54 PM
aesmith is offline
Find More Posts by aesmith
Joined Apr 2010
Hi,
I've seen a few comments about fitting O rings onto the swash links, and/or on the blade grips. Is there an article showing exactly where they should be fitted?
Thanks, Tony S
aesmith is offline Find More Posts by aesmith
Old Feb 12, 2013, 01:17 PM
Billz_01 is offline
Billy
Joined Jun 2012
You want them on your ball links @ swash plate and blade grips. (7 in total if you're keen). I'm pretty sure sizes 001 & 002 respectively. You can also run a pair on each landing skid for a bit of traction, but fuel tube works also.
They are just a little larger than the stock ones, taking out that link rod play and allowing more precise control.
Old Feb 12, 2013, 01:53 PM
aesmith is offline
Joined Apr 2010
Cheers. To be clear, the O ring goes on the ball before you put the link on?
Old Feb 12, 2013, 02:00 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
I do kind of wonder why they give us so many canopy grommets, but not extra o rings. I've never lost a canopy grommet on any of the 3 blade Micros I've owned, has anyone else?
seeingeyegod is offline Find More Posts by seeingeyegod
Old Feb 12, 2013, 03:10 PM
Billz_01 is offline
Billy
Joined Jun 2012
Yes, it fits over the ball link, and the link pressed on (sits against the O-ring)
And I have lost a few canopy grommets before, but not often enough to require them in the box. I think they get used over the links on some birds (I have used them on my 130x while waiting for my silicone O-rings to arrive). It would be nicer if they could include more vulnerable parts as spares, like a main motor or two.
Old Feb 12, 2013, 06:12 PM
Joined Nov 2008
Got my Swash changed out. Now the pitch was off again.
Kept adjusting until it was right. Flew it, not enough Up Pitch. Landed, checked it again and it was off again. Was adjusting and on the fourth time popping the Link ball off, the new Swash rear ball broke off.
What could be causing the Pitch to change, the Rear Servo going bad?
That was the only Swash I had, both are broke. Going to try to CA the rear ball on the new one...
Seriously thinking about a MH Blue Aluminum.....
Old Feb 12, 2013, 06:18 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
I lost all up pitch when the main gear wasn't pushed up all the way.
hone1er is offline Find More Posts by hone1er
Old Feb 12, 2013, 06:22 PM
Joined Nov 2008
Wish it was that easy. I just put the main shaft in and gear on, did one test flight, just hovering and a landing, nothing else changed.
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6160 May 20, 2016 04:10 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
