Old Feb 06, 2013, 02:17 AM
burggraaf is offline
Find More Posts by burggraaf
Joined Dec 2012
throttle curve for mild
ive noticed people suggesting a flat throttle curve with the astroid design mild brushless kit- does that mean L75, 75 75 75 H75? how does that work?
wouldnt the heli spool up too fast with no throttle input?
burggraaf is offline Find More Posts by burggraaf
Old Feb 06, 2013, 02:33 AM
Billz_01 is offline
Find More Posts by Billz_01
Billy
Australia, NSW, Newcastle
Joined Jun 2012
Means that your throttle stays @ 75% while your stick input changes the collective. With gov on, head speed stays the same....
Billz_01 is offline Find More Posts by Billz_01
Old Feb 06, 2013, 02:52 AM
Joined Dec 2012
so i just set my curve to all 75 values?
sounds easy enough.
And no problem with the motor spooling up ?
thanks BillZ advice much appreciated as al;ways
Old Feb 06, 2013, 02:54 AM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
The ESC with BLHeli firmware has a soft start up routine. So it will slowly spool up.
Otherwise, some people has a linear throttle curve set in Normal mode to get the heli into the air. Then flip the switch into Stunt mode which has a flat throttle curve.
Either way will work. Depends on your preference.
Daryoon is online now Find More Posts by Daryoon
Old Feb 06, 2013, 03:30 AM
Billz_01 is offline
Billy
Joined Jun 2012
Yep, 75 right through and a linear pitch should be a good setup.
And no worries. :-)
Old Feb 06, 2013, 03:31 AM
Billz_01 is offline
Billy
Joined Jun 2012
Can you still use normal mode with Tx gov enabled???
Old Feb 06, 2013, 09:36 AM
KellyK is offline
Find More Posts by KellyK
Me
Joined Jan 2013
I think it is only set on the mode you wish: Stunt1/2, but not usually N.
KellyK is offline Find More Posts by KellyK
Old Feb 06, 2013, 11:05 AM
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Blade nano CPX - even smaller than the mCPX!
Of course. Not to actually fly because there will be a lag. (Feels like +expo on the throttle channel to me)
It's good for manual spooling up. Slowly taking off like a scale Heli. Hovering in the air.
Once in the air, flip over to your other mode that has a flat curve to govern your headspeed and actually "fly".
Old Feb 06, 2013, 11:31 AM
Billz_01 is offline
Billy
Joined Jun 2012
Fair enough. So somewhat possible but not ideal or practical.
Unless scale flying that is, but I guess the need for a gov BL CP heli surpasses the scale requirements.
Old Feb 06, 2013, 03:21 PM
Rich Knapp is offline
Find More Posts by Rich Knapp
LYNX/OXY Team Manager
Rich Knapp's Avatar
United States, WI, Appleton
Joined Jul 2012
Freaky, watching this while I've got Judge Judy on in the background, lol...
It's definitely an awesome little heli, you'll have fun with minimal expense for repairs (unless you go the upgrade route, things get a bit dearer then).
Stand with your back to the light source and she is much easier to see. Of course I fly mine in a room full of windows so I understand that can be hard
lol On the Judge Judy.
I'd go with back to doors but were I'm sitting is our kitchen and all our dining room stuff, so its more congested than If I face the doors.
Spring will be here in few months then outside flying.
Rich Knapp is offline Find More Posts by Rich Knapp
Site Sponsor
Old Feb 06, 2013, 03:33 PM
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
@Billz
It more just "different strokes for different folks". Some people are more comfortable controlling the rate at which the head spools up and the Heli leaves the ground. It's actually more similar to a stock setup.
Hearing the head spool up to a flat throttle curve rate can be unnerving for those using a brushless for the first time.
It's good to be aware of both scenario.
Old Feb 06, 2013, 06:45 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Well almost there on a few more conversions! They would be done but I forgot my glue
indoorheli is offline Find More Posts by indoorheli
Old Feb 06, 2013, 07:13 PM
Billz_01 is offline
Billy
Joined Jun 2012
It is definitely a fun little outdoor beast. I promise you though, once you start flying it outside you're gonna want something bigger. It's like a sickness, or addiction, once you start its a long and windy road to recovery :-).
No worries, I haven't modded to BL yet, I do have two stock BL heli's but I'm not seeing the unnerving part, ( they both soft start even in IU), perhaps when I put the new motor in the 130x that might change. :-)
I defo understand now though, not a problem. I just though that it would conflict with the esc being in TX gov mode.
I've got glue here, if you post me one of those BL conversions I will glue it into my heli and take photos for you
Someone's going to be in BL heaven soon.
Old Feb 06, 2013, 08:30 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
Got 5 flights in the living room tonight, but finally broke the wires inside the rear frame where the boom goes in. Boom was sagging and I dropped it with TH on to avoid a corner when it got behind me when the furnace blower kicked on.
Looked like no damage, set it down and it spun donuts. Tailmotor dead.
Getting a new Tip or Iron tomorrow at Lowe's with some shrink and will try and tack them together at both ends. Broke at the motor end too when removing them. Good time to put the CF rod boom on.....
heritageflyer is offline Find More Posts by heritageflyer
Old Feb 06, 2013, 08:48 PM
sideburn is offline
Find More Posts by sideburn
sideburn's Avatar
USA, CA, Cardiff-by-the-Sea
Joined Nov 2005
I'll take those stock main motors!
sideburn is offline Find More Posts by sideburn
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6160 May 20, 2016 04:10 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
