Old Feb 04, 2013, 01:22 PM
aesmith is offline
Find More Posts by aesmith
Joined Apr 2010
CP Curve for MSR Blades
Hi,
I'm just trying my Nano with MSR blades, and I think I've got a reasonable combination of curves. I have it set to lift off at a stick position of around +25% or so. With the stick centred it's firmly on the floor, and as far as I can hear it maintains a reasonably constant rotor speed while flying whether climbing, hovering or descending. My settings are as follows ...
Power -100% -50% 0% +45% +90%
Pitch -40% -40% -40% -10% +30%
Just wonder what others find works well with these blades. I want to keep it controlled by pitch, not run as an FP machine.
Cheers, Tony S
aesmith is offline Find More Posts by aesmith
Old Feb 04, 2013, 01:27 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Either a flat 0 pitch (50-50-50-50-50) or a little added negative pitch, but again flat.
If you want to be controlled by pitch, you would be better off to put your cp blades back on.
indoorheli is offline Find More Posts by indoorheli
Old Feb 04, 2013, 07:26 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Originally Posted by aesmith View Post
Hi,
Cheers, Tony S
You are losing a lot of efficiency using a pitch curve. When I tried MSR blades, I found a flat pitch curve at 50% worked best.
At -40% you have negative pitch, which wont allow liftoff. at -10% you are probably OK, as it will fly within +/- 10% of zero pitch (0 pitfch is most effiencent though), and +30 you are wasting power, but more importantly,putting a larger load on the motor that you need to.
If you want more headspeed, MSRx blades will give you that, while still giving a little better flight times than the stock blades.
dacaur is offline Find More Posts by dacaur
Old Feb 05, 2013, 12:57 AM
emeraldc is offline
Find More Posts by emeraldc
west coast flyer
emeraldc's Avatar
Joined May 2012
Well all 3 arms on my swash plate are now glued on,...still fly`s good, but I think it`s time to order a metal one Made a good pair of skids with 2 broken ones, some thread & ca, they have been holding out great. Fixed my MH CF skids also, but I would not recommend them, the little post broke off and was stuck in the hole after 2 crash`s.
emeraldc is offline Find More Posts by emeraldc
Old Feb 05, 2013, 01:06 AM
Billz_01 is offline
Find More Posts by Billz_01
Billy
Australia, NSW, Newcastle
Joined Jun 2012
Love the frankenskids!
My Airtime skids should arrive soon, can't wait as I've already had to purchase another stock set in the meantime. Stupid POS stock crap...
Billz_01 is offline Find More Posts by Billz_01
Old Feb 05, 2013, 03:28 AM
burggraaf is offline
Find More Posts by burggraaf
Joined Dec 2012
bullet blades??
cant get any of the nano bullet blades, will the hisky FBL 100 bullet blades work (or the cheaper v922 blades?
burggraaf is offline Find More Posts by burggraaf
Old Feb 05, 2013, 03:29 AM
aesmith is offline
Joined Apr 2010
Cheers, I'll try a little less pitch and aim for 0% at hover power.
Old Feb 05, 2013, 04:58 AM
m_ark is offline
Find More Posts by m_ark
Gravity sucks.
Australia, QLD, Toowoomba
Joined Mar 2011
I figured out the problem with my nano shakes - the collar on the main shaft had slipped up. I pushed it back down and now it's perfect.
http://www.helifreak.com/showpost.ph...59&postcount=1
Point number 4 from the above link.
m_ark is offline Find More Posts by m_ark
Old Feb 05, 2013, 11:39 AM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
Got may darting to the left problem and glitchyness fixed, the battery was too cold and could not put out the power so it made the board act funky. Now i got some tail wag, i just put on a new boom with motor, changed out tail rotors and main blades, it still does it. When i spool up there is no vibrations, feathering spindle is new, any suggestions? Note- the ultra micro batteries need to be strong and up to proper temp to fly this heli properly, so when buying batts, pick up some that are high quality.
keithy4129 is offline Find More Posts by keithy4129
Old Feb 05, 2013, 02:07 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
my tail wags a little all the time, moreso in normal (not idle up) mode, and more so when the battery is fully charged. It settles down after a minute or two (maybe it needs to warm up?) I've sort of just come to accept it as a quirk and it doesn't really bother me.
seeingeyegod is offline Find More Posts by seeingeyegod
Old Feb 05, 2013, 06:28 PM
Rich Knapp is offline
Find More Posts by Rich Knapp
LYNX/OXY Team Manager
Rich Knapp's Avatar
United States, WI, Appleton
Joined Jul 2012
God I love this thing. Just got mine today.
Blade Nano (1 min 37 sec)
Rich Knapp is offline Find More Posts by Rich Knapp
Site Sponsor
Latest blog entry: Our Family heli's.
Old Feb 05, 2013, 06:58 PM
Billz_01 is offline
Billy
Joined Jun 2012
Freaky, watching this while I've got Judge Judy on in the background, lol...
It's definitely an awesome little heli, you'll have fun with minimal expense for repairs (unless you go the upgrade route, things get a bit dearer then).
Stand with your back to the light source and she is much easier to see. Of course I fly mine in a room full of windows so I understand that can be hard
Old Feb 05, 2013, 11:47 PM
Alex4R is offline
Find More Posts by Alex4R
Alex4R's Avatar
United States, OK, Tulsa
Joined Dec 2012
Originally Posted by Alex4R View Post
Feathering shaft is straight, doesn't wobble when I put a wrench on one side and spin it. I've tried various tightness, should it have any play back and forth (a gap between the bearing and washer)?
Blades are loose also. I've tried a new mainshaft, and cleaning the servos aswell as replace the feathering spindle and hardware. Also balanced the blades and tried the spare tail rotor.
Main gear is pushed all the way up and glued, no up and down play. Forgot to mention that.
I started to pull apart my blade grips to put some green slime on the o-rings to start playing with tightness, found a hairline crack around the inner bearing of the blade grip. So I lubed the o-rings, put it all back together with new grips. Spindle tight, but not binding and loose blades. It was still wobbling, so I loosened the feathering spindle till it had a little bit of play and it got a lot better, but it's still there. Still shudders when I descend. Now I'm going to try the bullet blades and see if it goes away since it isn't as bad as it was before.
Finally figured out my problem with the wagging/vibration/shudders. The main gear being pushed all the way up without any play was the culprit. Now I have ~1mm movement up and down, and she's solid!!!
Also lost the original main motor yesterday. It gradually lost power until it struggled to keep it in the air. 56 flights total with my timer set at 3 minutes, mild hovering indoors and outdoors, usually cooled between flights, oiled the bushing once with some trinity motor bushing oil I had from back when cars ran 27T brushed stock class, once or twice I flew two or three batteries back to back. I didn't make a habit of it though. I had a couple crashes in the grass outside trying to stay inverted, but I hit TH as quick as I could. Of course there are no motors to be had at either 3 local hobby shops here, So I went to work and ordered two main motors to make sure I get some and my friend said his nano got stepped on and basically needs a full rebuild, so he gave me his motor to use till my order is filled. Sweet! I'm gonna have to throw him some replacement parts to help get his back in the air for that!
Alex4R is offline Find More Posts by Alex4R
Old Feb 05, 2013, 11:58 PM
sideburn is offline
Find More Posts by sideburn
sideburn's Avatar
USA, CA, Cardiff-by-the-Sea
Joined Nov 2005
Where did you order the motor? The only place I found was wholesale trains but shipping is 10 bucks.
sideburn is offline Find More Posts by sideburn
Old Feb 06, 2013, 01:04 AM
Alex4R is offline
Alex4R's Avatar
Joined Dec 2012
Hobbytown. They aren't due in at horizon until the 10th so it'll be a week after that before I get them probably.
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6160 May 20, 2016 04:10 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
