Old Feb 01, 2013, 01:02 PM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
Originally Posted by kidlat View Post
Does this heli have trouble piroing? I can't even do a 360 without it going crazy out of control.
Is that new to the heli, or is the heli new to you? Just trying to understand the context of the question. If the heli is new to you (and you didn't fly the MSRx), yes, you can't Piro with these (or at least I can't!) without managing your aileron and elevator to compensate. My Nano is down, but if I recall, it is similar to my mSRx - a clockwise piro requires slight (hairs breath) backstick and slight (1/2 hairs breath) right aileron - don't apply all three inputs at once though - it goes (again, this is mSRx, and I THINK for my Nano now, but i can't validate *arrgghh*): Rudder, back stick, slight aileron. SOmeone with a working Nano can validate or concur, but the main point is, this thing requires active control to piro.
If this is a new behavior, though, or has become more noticeable, make sure your swash is level (actually, check that regardless).
whichwaysup is offline Find More Posts by whichwaysup
Old Feb 01, 2013, 01:04 PM
perschek is offline
Find More Posts by perschek
GEEBEE Can't WAIT!
perschek's Avatar
USA, OR, Seaside
Joined Dec 2010
I'm getting some mild tbe while hovering. I'm fairly confident its not the feathering shaft being bent or over tightened but my main gear is a bit warped from pushing it on unevenly, could this cause mild movements? Its enough to be annoying while hovering indoors but fff outside obviously doesn't bother me.
perschek is offline Find More Posts by perschek
Old Feb 01, 2013, 01:40 PM
kidlat is offline
Find More Posts by kidlat
Joined Aug 2011
Thanks whichway. My nano is brand new and very stable and I can do flips with it. However if I do a piro (even just a 360) with no cyclic compensation it just goes off in a certain direction. I have an Mcpx and it doesn't have that problem.
kidlat is offline Find More Posts by kidlat
Old Feb 01, 2013, 01:56 PM
Joined Apr 2012
Yep - same with mine. I haven't had the MCPx, but came frome the MSRx, so I kind of expected it. If it can be trimmed out, though, I'll be interested in hearing it.
Old Feb 01, 2013, 01:59 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
Originally Posted by Maxthrottle View Post
Hold is a flip of a switch just as switching back to normal mode is a flip of the switch. So the reason for hold has nothing to do not being able to shut down down rotation because of the mode you are in.
I know you weren't responding to me but this is a really confusing sentence.
Pilots need to learn to maintain pitch control with the throttle stick regardless of what mode you are in independent of when they need to throttle hold. From CP flight 1 a pilot is supposed to learn a disconnect between throttle stick position and cutting drive.
Again... what?
You didn't say to throttle cut but your reason why you don't was only because the mode you are in which is inaccurate along with idle up.
Another way of putting it is a new person watching your video could think, well I'm not going to try stut mode so I'll keep my fingers off any switches and cut the throttle if I need to, if that's the only reason for using hold. Where as, as I was taught, always be conscious of the pitch in your throttle stick, but the moment before impact, thats when you hit the throttle hold. That focused my attention to keep flying pitch control and not associate cutting power at all with my throttle stick no matter what mode I'm flying in. I didn't understand why at first but did later when I started causing more damage by not disconnecting the two.
I don't understand this last paragraph either. This post is really hard to understand man. You should like, re read stuff before you post.
seeingeyegod is offline Find More Posts by seeingeyegod
Old Feb 01, 2013, 02:03 PM
To me it seems easier to piro with the nano than the MSRx, but I still don't try more than two full spins in a row because I lose track of where the nose is pointing at that point. Interesting if the the Mcpx really can spin and spin with no other inputs.
Old Feb 01, 2013, 02:04 PM
ruzam is offline
Find More Posts by ruzam
Go small or go home
ruzam's Avatar
Canada, SK, Regina
Joined Mar 2008
I think it has something to do with a combination of the extra 'tilt' of the lighter nano vs the mcpx, and the inherent stability of the mcpx.
If I get the nano in a perfectly flat (hands off) hover, then hit the rudder I can get a few rotations before it wanders off. Put if I'm sticking it around and it's not quite settled when I punch the rudder it's all over the place before it's even half way around.
I find the nano way easier to fly than the mcpx, but having said that, the nano seems to be constantly in motion and being corrected, so it's rarely just 'settled'. It's just that the corrections are easier to control. Where as my mcpx is stays pretty smooth, because I find making corrections much more difficult. So my mcpx piros are normally starting from a level position but my nano piros are often starting mid motion.
ruzam is offline Find More Posts by ruzam
Old Feb 01, 2013, 02:33 PM
turboparker is online now
Find More Posts by turboparker
I'd rather be flying!
turboparker's Avatar
Joined Jul 2009
SR helis are not supposed to spin & spin without other input. All SR birds hover at a slight angle to compensate for tail rotor drift. The angle is dependent upon tail-rotor thrust. To maintain lateral position during a piro, some cyclic input will be required.
Joel
turboparker is online now Find More Posts by turboparker
Old Feb 01, 2013, 03:49 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Its hard to reply to you without knowing what you don't understand. You may need the context of theimacman's video and his explanation as to why you need to use the hold throttle. He didn't encourage the use of cutting power with the throttle stick but the explanation leaves it open for use if you happen not to be in stunt mode. This isn't the case.
Hold isn't associated with the mode you are in as he implied. Hold is simply to cut drive power to your assembly no matter what mode you are in and should be the muscle memory reflex move if impact seems imminent, autos or ground handling conditions.
The bad habit or thinking to be avoided is to use your throttle stick for cutting power at all. The pilot has to start thinking in terms that the throttle stick is primarily a rotor pitch control stick (CP), for which ever modes, that has a applicable throttle curve that follows.
Once a pilot gets the idea of rotor pitch firmly in mind and not throttle, its easier for them to react to keep attempting to fly regardless of orientation, inverted, varying wind, 3D etc. and never confuse the throttle stick flight control with cutting power in a split second reaction to avoid damage.
Because new pilots read comments with their own understanding, they can follow through on such to their own detriment because they don't know otherwise. So as I said, small thing but it could be misleading. Just as I said about the 35C150 battery earlier. Others don't know the difference but may take such as literal.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Feb 01, 2013, 03:55 PM
helipilot23 is offline
Find More Posts by helipilot23
Unregistered User
helipilot23's Avatar
Joined Oct 2012
PLEASE RESPOND PLEASE REPLY PLEASE RESPOND
has anybody seen the new pnp brushless kit on ebay?????
URGENT URGENT
LOL just satin this is the third time ive asked this.
Don't respond with a cat joke!
helipilot23 is offline Find More Posts by helipilot23
Unregistered User
Joined Oct 2012
*sayin not satin
Old Feb 01, 2013, 03:58 PM
Joined Apr 2012
URGENT URGENT
* Insert not-cat joke here*
Are you saying there IS a PNP brushless kit and asking if we've seen it (in which case, can you include the link, and the answer is no - at least for me), or are you asking if there IS a PNP brushless kit?
Old Feb 01, 2013, 04:07 PM
Unregistered User
Joined Oct 2012
There is one. Go to ebay an search "nano cpx motor" its the last result.
Here's a link. From mybtwblet so it mightnot work
http://item.mobileweb.ebay.com/viewi...id=33838757550
Old Feb 01, 2013, 04:23 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
having to modify the main fraim doesnt really seem like plug-n-play to me....
dacaur is offline Find More Posts by dacaur
Old Feb 01, 2013, 04:25 PM
Unregistered User
Joined Oct 2012
It wouldn't be that bad. I wouldn't ruin a billion main boards.
What do u think of it?
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6160 May 20, 2016 04:10 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
