Old Jan 28, 2013, 02:33 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
Originally Posted by Greg Head View Post
The tail motor spins with no throttle, it even spins when not bound to tx. It starts spinning the instant the battery touches the battery cable and only stops when I apply throttle. I did plug it in both ways just in case but no change. I don't want a new board, this is already my second one, HH sent me a replacement when my first one freaked out 5 flights in.
Still sounds like Reversed. Did you try Reversing the Channel (Rudder) in the Radio? Also Rebind Radio to Nano?
Did you have the Board Powered Off, Batt Disconnected when the Tail Motor was plugged in the first time?
If you replaced the Frame and Boom, could be crash damage to the FET?
heritageflyer is offline Find More Posts by heritageflyer
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
If it spins with no throttle and channel is not reversed, I'd guess a blown tail FET
indoorheli is offline Find More Posts by indoorheli
Old Jan 28, 2013, 02:34 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
That's really weird! Can't imagine what would make it start spinning before it even finishes its "boot up"
seeingeyegod is offline Find More Posts by seeingeyegod
Old Jan 28, 2013, 02:38 PM
ruzam is offline
Find More Posts by ruzam
Go small or go home
ruzam's Avatar
Canada, SK, Regina
Joined Mar 2008
Nothing should be powered up when not bound to the tx. That right there is a sign of a broken board, or at the very least a damaged tail motor fet. Sometimes fets fail out open, sometimes they fail shorted. If it's just the fet, someone with the right skills can fix it. Otherwise, it's back to the factory for warranty.
ruzam is offline Find More Posts by ruzam
Greg Head is offline
Find More Posts by Greg Head
Joined Aug 2012
Is there anyone that fixes tail fets on nanos (I am not soldering on a tail fet, I am fairly certain my poor soldering on my solid tail is what caused this problem), I recall there being some people that will fix one on an mcpx but this is the first I recall seeing blown on a nano. How can I tell if that is the problem? I looked for a burned spot on board because I thought that could be it but everything looks good.
Greg Head is offline Find More Posts by Greg Head
Old Jan 28, 2013, 02:40 PM
indoorheli's Avatar
Joined Sep 2007
if you do not see burnt spots try to push on the Tail fet while it is powered...see if it does anything different
Joined Aug 2012
Will Horizon fix the fet, I will pay, I just don't want to buy a new board. This is my second board and if I have to buy one I might just cut my losses and sell what I have to someone for parts.
Old Jan 28, 2013, 02:42 PM
indoorheli's Avatar
Joined Sep 2007
Horizon will not fix it but they might give you another board though
Old Jan 28, 2013, 02:45 PM
Joined Aug 2012
First off you guys always surprise me with how helpful you are.
Second, where in the world is the tail fet, anyone have a pic? When I said it didn't look burnt, I meant the entire board looks perfect. In fact it is pretty new.
Old Jan 28, 2013, 02:49 PM
indoorheli's Avatar
Joined Sep 2007
I am just a parrot
I think it is on the lower left, I don't have my nano with me. I know the one at the top just off of middle is the main FET
Old Jan 28, 2013, 02:50 PM
microheli is offline
Find More Posts by microheli
microheli's Avatar
Joined Jul 2006
Originally Posted by Palle_Plutt View Post
Does anybody know why trottle hold is 10% for the dx6i in the manual?
And 0 for the other computer radios.
For safety to prevent un-intended startup after plugging in the battery.
There is a "bug" in the DX6i, send -10 for TH. You can find some details in:
http://www.helifreak.com/showpost.ph...83&postcount=9
microheli is offline Find More Posts by microheli
Old Jan 28, 2013, 03:24 PM
Joined Aug 2012
Well I just had an idea to make lemonade out of a lemon. If it is a blown fet I think I am just going to see if I can get a brushless upgrade done on it by NCcraig over on helifreak. That way it is worth his time to fix my fet and I have been wanting to do the upgrade anyway, just didn't want to solder it myself. Of course I have no idea if that is the problem because I still don't know where the fet is
Old Jan 28, 2013, 03:32 PM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
Here's a before and after picture of a tail FET replacement. A guy on HeliFreak sent me his board to repair for him.
Obviously, this was a more extreme burnt FET. Usually, you can see a bubble or sometimes not even see anything wrong at all.
Hope that helps you.
Daryoon is online now Find More Posts by Daryoon
Old Jan 28, 2013, 03:38 PM
helipilot23 is offline
Find More Posts by helipilot23
Unregistered User
helipilot23's Avatar
Joined Oct 2012
Is brushless hard to convert?
helipilot23 is offline Find More Posts by helipilot23
Old Jan 28, 2013, 03:41 PM
indoorheli's Avatar
Joined Sep 2007
Not too bad at all if you are decent at soldering. There is a little bit of frame modifications as well.
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6160 May 20, 2016 04:10 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
