Old Jan 27, 2013, 04:19 PM
jpconard is offline
Find More Posts by jpconard
Joined Feb 2007
Where do people break their landing gear? That is about the only part I haven't broke , completely anyway to where it is not usable. I broke the bottom rail off behind back support first day (snagged on carpet) and I've broken one side battery holder support but the landing gear itself is fairly flexible, still using original from late Sept.
I have broke -
swashplate all arms and separated 3 times, last one in flight, now replaced
on third main motor
on 2nd tail motor
solid cf tail boom, destroyed 2 stock ones
one set of lynx main blades
canopy destroyed- using V911
all 4 canopy pins - using paperclips
blade grip
feathering shaft bent back 20 times
rx board lost connection on rx chip, heat gun reflowed solder to fix
But still on stock L.G. You guys must land hard when not inverted. I tend to land hard inverted which tends to break even more I guess.
jpconard is offline Find More Posts by jpconard
Old Jan 27, 2013, 04:25 PM
J_skaggs is offline
Find More Posts by J_skaggs
United States, CA
Joined Jan 2012
Originally Posted by turboparker View Post
The tail-shake is often caused by weak batteries, as well. I had the exact same issue with my well-used & somewhat abused Hyp & TP 160s. Haven't had any LVC or tail-shake issues since I picked up some fresh batts.
Joel
I flew my 450X today and on my second battery had a tail rotor strike the grass. It didn't appear to be a hard strike. On the next flight the tail wagged a bit. I thought it might be related to the rotor strike. I went home and checked the battery voltage and found one of the three cells significantly lower than the other two. I got a fresh battery and went back to fly it. No wag at all throughout the flight. It appears the battery caused the wag.
J_skaggs is offline Find More Posts by J_skaggs
Old Jan 27, 2013, 04:46 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Interesting. I suppose the resulting ripple voltage was either too much for the tail gyro to handle, or it created enough ripple in tail-servo torque to cause overshoot problems.
Joel
turboparker is online now Find More Posts by turboparker
Old Jan 27, 2013, 05:46 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
My swash repair seems to have held for now anyway. Blob of medium CA and held it with the gap closed for about 30 sec then hit it with kicker. Of course my attempted landing gear repair failed but it still works, just a little fiddly
Yes its basically from super hard upright landings when hitting TH at altitude or forgetting and slamming it down. Glad it gives way rather than something more important.
seeingeyegod is offline Find More Posts by seeingeyegod
Old Jan 27, 2013, 06:19 PM
J_skaggs is offline
United States, CA
Joined Jan 2012
Joel
Glad that took care of it. I was about to start replacing tail parts. I wish I knew as much about these larger heli's as you and others here. I'm a year into this hobby and have been learning very slowly. I have been flying micro heli's mainly which are easy to repair. I have crashed my 450X twice. The first time I had the LHS repair it. The second time I did it myself with good results.
Jim
Old Jan 27, 2013, 06:20 PM
Billz_01 is offline
Find More Posts by Billz_01
Billy
Australia, NSW, Newcastle
Joined Jun 2012
Originally Posted by indoorheli View Post
On your vac forming, if you can make a plug out of resin/polymer or something like that, it will last longer and wont loose definition.
On the swash I found that hot melt glue worked very well.
Thankyou, I am planning on making a resin final plug, but making the first one from plaster so I can easily modify it and test it. I will then make a mold of it with silicon and plaster, (silicon first to capture all the details, ie. cut lines etc. then plaster around that to hold the shape) then use that mold to make my final plug from resin.
I will be trying the hot glue today, but will be purchasing a new one just in case anyway. Wish me luck...
Originally Posted by seeingeyegod View Post
My swash repair seems to have held for now anyway. Blob of medium CA and held it with the gap closed for about 30 sec then hit it with kicker. Of course my attempted landing gear repair failed but it still works, just a little fiddly.
That is exactly what I did, however my medium CA and kicker is foam safe, so might not be as strong on plastic.
Billz_01 is offline Find More Posts by Billz_01
Old Jan 27, 2013, 08:34 PM
BladeScraper is offline
Find More Posts by BladeScraper
Custom User Title
Joined Jun 2011
congratz, Billz_01, that post was the 4,100th post!
Anyway, I flew one of these again today and I still love it just as much as I dad 2 weeks ago.
BladeScraper is offline Find More Posts by BladeScraper
Old Jan 27, 2013, 08:35 PM
Wookster is offline
Find More Posts by Wookster
Augernaut
Wookster's Avatar
United States, KS, Overland Park
Joined Jan 2010
Bahh, need a little troubleshooting help. She's got a tail wag. On the second tail motor right now. still almost new. Had a bad vibration, turned out being a loose feathering shaft. It's a very rhythmic wag. maybe 3-4 times a second. Replaced the main motor thinking it would help, it didn't It's also shutting down when I first start it. get a little speed on the head and it settles down, almost like it has to warm up. Just trying to track this down.
Wookster is offline Find More Posts by Wookster
Old Jan 27, 2013, 08:47 PM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
CA and baking soda. That'll make the swashplate arms stronger than stock.
Daryoon is online now Find More Posts by Daryoon
Old Jan 27, 2013, 10:14 PM
burggraaf is offline
Find More Posts by burggraaf
Joined Dec 2012
help with dx6i binding
Does anyone have any tips for getting my dx6i to bind my nano. I followed the procedure listed in the manual.
plug in nano
turn on dx6i holding trainer/bind button
bind comes up on dx6i
release bind button and hold right rudder
release but blue led never goes solid.
the dx6i controls will then move the swash but not the motors
binds and flys perfect with the old dx4e though?
curious.. any tips?
burggraaf is offline Find More Posts by burggraaf
Old Jan 27, 2013, 10:27 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
I would suspect throttle trim is the problem, is it all the way down?
dacaur is offline Find More Posts by dacaur
Old Jan 27, 2013, 10:31 PM
Billz_01 is offline
Billy
Joined Jun 2012
Be sure you're DX6i is in heli mode, I've made that mistake before. (slightly different reaction but still didn't work properly). Also try it and don't let go of the right rudder until the heli light goes solid.
Just missed the 4100, Joel beat me to it. Damn
I will have to give that baking soda a go, it would make like a resin bog much like that with fiberglassing.
An overly tight and loose feathering shaft can create a tail wag. That part where it turns off-on is what I have noticed as a sign of a weak or dying motor. I know you say you've replaced them both, but that is just my experience. a broken tail boom (splintered and twisting) will also create a wag, and an old deformed tail rotor also. I use my KBDD mcpx tail rotors, as they are thicker and seem to stay straighter, longer.
Old Jan 27, 2013, 10:59 PM
perschek is offline
Find More Posts by perschek
GEEBEE Can't WAIT!
perschek's Avatar
USA, OR, Seaside
Joined Dec 2010
hey everyone thanks for the advice using med/thick can on the featgering shaft. the idea of elmers glue just isn't working. I assume you use activator afterwards?
perschek is offline Find More Posts by perschek
Old Jan 27, 2013, 11:02 PM
Aphro is offline
Find More Posts by Aphro
ChuckTseeker Super Fan
Aphro's Avatar
Joined Jan 2012
I do not... use kicker that is...
Aphro is offline Find More Posts by Aphro
Old Jan 27, 2013, 11:06 PM
Joined Dec 2012
dx6i bind problem
yep is in heli mode
not trim problem
tryed holding right rudder for quite a time (20 SEC) and light still flashing.. but i will try for holding longer.
anything else i need to check?
dx4e binds fine and flys fine
dx6i just gets swash movement and led still flashing after bind?
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6160 May 20, 2016 04:10 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
