cale10 , that is a doctored up photo I did as I thought a brushless nano couldn't be done due to the very small size of it.
I see Dylan already converted his to brushless. That is great to know it can be done! Awesome job Dylan! Tom |
Latest blog entry: My RC Web Site
In normal mode for example you may start off with a touch of negative but as you progress on throttle your pitch will increase (on a non linear pitch curve), along with your throttle to give you lift. Normal mode is just that, no 3D flying there. Once you get used to all the benefits of stunt mode (higher head speed, better wind handling, more responsive), you will abandon normal mode. |
Joined Feb 2007
Thanks, your reply seems to be talking about a TX that allows programming. How is Normal mode mixed on say the RTF package with DX4e, which does not allow programming your own mixes, correct?
One suggestion, I know it will be more money, but seriously consider getting a better transmitter, like the dx6i or higher. The resolution will be higher and you will have a lot more control over your aircraft, not just due to higher resolution, but the ability to adjust dual rates and expo, as well as pitch and throttle curves. Your flying will improve with a better tx IMO. |
I wonder if the BL conversion flies better though
Latest blog entry: Estes Rubber Band Condor gets powered...
Given the size and the additional servo. There's not much space to insert a brushless motor and mount. At least not the outrunner type we're accustomed to seeing on this size helis.
I bet it the same diameter motor as the mSR X. |
Latest blog entry: Syma S105 Battery Mod
| Thread Tools | |
| Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter | zadaw | Micro Helis | 5192 | Jun 13, 2013 11:46 AM |
| Discussion is there anything better than mcpx v2 at same or smaller size? | Legendary_Agent | 3D Electric Heli Flying | 33 | Feb 24, 2012 08:46 PM |
| Question What’s Better than a Blade CP and Smaller than a Trex? | HavingFun2002 | Micro Helis | 74 | Mar 05, 2006 05:07 PM |
