Old Jan 13, 2013, 07:44 AM
turboparker is offline
Find More Posts by turboparker
I'd rather be flying!
turboparker's Avatar
Joined Jul 2009
Tsenecal,
I fly with a Futaba 10CHP. Swash is 'H-1 Pure 1/2/6', with channels 1-4 & 6 reversed.
Joel
turboparker is offline Find More Posts by turboparker
Old Jan 13, 2013, 08:54 AM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
Nice pics indoorheli, I think it's safe to say you're a Blade fan. I understand why, the stuff just works. I am struggling with clones right now, about to give up and buy a 450x, just too much money for what it is.
shahram72 is offline Find More Posts by shahram72
Old Jan 13, 2013, 09:51 AM
aesmith is offline
Find More Posts by aesmith
Joined Apr 2010
Originally Posted by dacaur View Post
... the MSRx blades have almost a soft feel to them (like a FP heli. go figure) ...
Isn't that because you're operating them at a fixed pitch, so that you have to adjust power by varying motor speed? I would have thought a better comparison would be to compare both types of blades with a fixed head speed and variable pitch.
Tony S
aesmith is offline Find More Posts by aesmith
Old Jan 13, 2013, 10:18 AM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
Success at last
Haha! FrankenNano flipped! I finally managed to get the stick movements figured out- not the least of which is to flip the TWO switches before attempting. The first few had a LOT of altitude loss, but by the end of the day I was only losing 5 ft or so. Lots of practice ahead but finally making progress.
whichwaysup is offline Find More Posts by whichwaysup
Old Jan 13, 2013, 10:47 AM
skeppley is offline
Find More Posts by skeppley
2 Turbos...Nope 1 Big one
skeppley's Avatar
United States, PA, Lake Wynonah
Joined Aug 2004
Anyone looking, i just posted an astroid brushless kit.
These sell quickly!
http://www.rcgroups.com/forums/showt...0#post23800613
skeppley is offline Find More Posts by skeppley
Old Jan 13, 2013, 02:20 PM
bad_mofo is offline
Find More Posts by bad_mofo
Joined Jan 2013
Hi. Finally my nano + dx6i are here. Outside is heavy snow, so I have no alternative but my living room. I've found quite difficult to hover with the settings of the manual. Ca n you point me in a slower, easier settings?
bad_mofo is offline Find More Posts by bad_mofo
Old Jan 13, 2013, 02:22 PM
helipilot23 is offline
Find More Posts by helipilot23
Unregistered User
helipilot23's Avatar
Joined Oct 2012
i like the stock settings.
just a tip: syma s107 blades are the same size as nano blades
helipilot23 is offline Find More Posts by helipilot23
Old Jan 13, 2013, 02:55 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
If you fly it on Low Rates and set the Pitch Travel/EPA to 70/70%, it should tame it way down until you get used to it. I'm running 40% DR and 20% Expo on Low. Some like lower Expo too.
heritageflyer is offline Find More Posts by heritageflyer
Old Jan 13, 2013, 02:57 PM
gonracn is offline
Find More Posts by gonracn
RC ADDICT
gonracn's Avatar
United States, MN, Plymouth
Joined Sep 2005
Bad mofo- dial in way more expo, other than that its practice, practice, practice. I thought the same at first also. It's really stable but it still gets away really fast!
gonracn is offline Find More Posts by gonracn
Old Jan 13, 2013, 03:25 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Tony S
That's not possible because the MSRx blades are undercambered, so only provide lift without straining the motor within a very narrow range. A flat curve at 50% is what they are designed for (0 degrees pitch) at 45% it wont lift off even at 100% throttle (not to surprising i guess), and at 60% it bogs the motor. I don't know if you have any experience with undercambered wings, but wing incidence is very important. Bring The front of the wing down to far and you lose lift, bring it up to far, and you gain lift, but at the cost of increased drag, which means you need more power to fly, which is wasteful of battery life, but when you get it just right, it is very efficient.
I figured the fairest test would be to fly them both as they are designed to be flown. A flat throttle curve is unfair to the MSRx blades, while a flat pitch curve is unfair to the symmetrical blades....
I really only tried the MSRx blades because I read that MSR blades give much longer battery life (which is true, with MSR blades you can fly with the old 12C e-flight batteries, which wont even get the heli off the ground with symmetrical blades), but the hobby shop I stopped at didn't have the MSR blades, just MSRx, so I decided to try them out..... I will save them for a rainy day when I bust up my bullet blades and have no spares, or my batteries significantly weaken.
Obviously MSR and MSRx blades aren't good for any kind of aerobatic practice, but are good for hover/orientation type practice by giving longer flight times.
IMO, dual rates are a waste on models like this unless you are a rank heli beginner,(in which case you shouldn't have bought it). If you have any amount of single rotor experience, set the rates to 100% and bring your expo up to 40%-45% on aileron and elevator, and it gets much easier to fly. Also, switch to the bullet blades, they make it MUCH more stable.
As you can see by the conflicting advice, everyones flying style demands different settings. Of coruse, its also possible that some people just havent tried anything but what they use, because it works for them, (even though different setting might work better) so thats what they recomend.
The best advice is to try different settings, and see what works best for you.
The one thing to keep in mind though, is that dual rates and expo both do the same thing, which is make the stick softer around the center (at least in this application) but dual rates has the downside of not giving full servo travel if you need it, while expo still gives you 100% servo travel if you need it..... IMO, using just expo makes more sense on something like this. I guess if you are a stick banger, having full servo travel could be detrimental..... Just remember to be soft on the controls...
dacaur is offline Find More Posts by dacaur
Old Jan 13, 2013, 03:40 PM
Joined Apr 2012
Solid Tail boom help
Okay - the flipping is taking it's toll - I'm on my second tail boom - and I just broke it. The good news is that I am crashing very infrequently. The bad news is that, when I do, it tends to be rather spectacular. The aileron flips are definitely easier, but I've gotten a few flips using the elevator.
So, here's the question. I'm about to drop $60 for the CNC swash, AR plate, blade grips, and hub, but I'm getting tired of buying $14 tailbooms. What are my options? The one that Rakon sells says it is only for their frame, and it looks hollow. I found this vid - is it really that simple to do yourself? 2MM or .080 solid CF and then shrink wrap over it to hide/protect the wires?
Blade Nano CPX Solid Tail Boom Mod (10 min 27 sec)
Old Jan 13, 2013, 03:44 PM
Rich Knapp is offline
Find More Posts by Rich Knapp
LYNX/OXY Team Manager
Rich Knapp's Avatar
United States, WI, Appleton
Joined Jul 2012
Real world info. I have a MSR, 120sr and had a Super FP. I'm looking at eather a Nano or mCPx-V2. I hear the Mcpx-V2 has a issue with tail blow out but the Nano has a weak board and don't take crash's. I'll be flying in living room over winter and our black top parking lot with tunnel effect breazes (between a apartment building and apatment building gorages) in summer.
I'll be binding it to a DX6i. With were I'll be flying would the Mcp-x-V2 a better over all choice?
I thought about the 130X but I'm not ready for all the vereables with the aditional parts for the tail.
Rich Knapp is offline Find More Posts by Rich Knapp
Site Sponsor
Latest blog entry: Our Family heli's.
Old Jan 13, 2013, 04:08 PM
sideburn is offline
Find More Posts by sideburn
sideburn's Avatar
USA, CA, Cardiff-by-the-Sea
Joined Nov 2005
http://www.youtube.com/watch?v=1UNXbVIgi7M
In my opinion all you need is a metal swash and a solid boom. Just buy a 4' or however long they come 2mm carbon fiber rod. Cut them with a dreamil tool. And slightly flatten each end so they slide into the frame and tail motor assembly. Mine has never broken. Just twist the tail wire around the boom.
sideburn is offline Find More Posts by sideburn
Old Jan 13, 2013, 04:14 PM
Joined Apr 2012
I can't speak for the MCPx, but I can for the Nano - Not sure where you've heard the board is weak and it can't take crashes - I've smashed my poor FrankenNano into just about every substance known to man (including asphalt from about 40ft up) and it keeps on ticking. It's a great little heli in spite of the guy behind the sticks.
Thanks! I have two good motors, not sure why I didn't do this before. Thanks a lot!
Old Jan 13, 2013, 06:09 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Yeah I definitely like their heli's and have flown almost every one they offer.
I just got that yellow one, though still haven't flown it yet.
If you look around you can get some pretty decent deals on a new 450x.
Speaking of costing too much money, I have a goblin on order
indoorheli is offline Find More Posts by indoorheli
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6160 May 20, 2016 04:10 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
