Joined Aug 2011
Cool. So this will work?
http://www.ebay.com/itm/1-6X-Pico-Li...20861638167%26 |
Joined Aug 2011
You can bump up the charge rate according to how many batteries are plugged into the cable. But I find that since you're now charging (potentially) 6 batteries at a time there's no reason to hurry up to get the next battery on the charger. So I leave the charge rate at the original one battery rate and just let them take their time. Slow charging batteries is easier on them. Using the celectra, you can plug in 4 parallel charging cables and charge up to 24 batteries at a time. All you need is a JST adapter like this http://www.horizonhobby.com/products...Page-_-BLH3126 for each parallel cable. Don't mix empty batteries with full batteries on a parallel charging cable. Make sure they are all at 'roughly' the same charge (voltage) level. A little variation is OK (it's relative), so don't stress if some are discharged more than others. If you mix a full battery with an empty battery the full battery will dump it's charge into the empty battery, probably at a rate that exceeds the safe discharge/charge rate (reducing your battery life). |
| Thread Tools | |
| Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter | zadaw | Micro Helis | 5183 | Yesterday 04:47 PM |
| Discussion is there anything better than mcpx v2 at same or smaller size? | Legendary_Agent | 3D Electric Heli Flying | 33 | Feb 24, 2012 08:46 PM |
| Question What’s Better than a Blade CP and Smaller than a Trex? | HavingFun2002 | Micro Helis | 74 | Mar 05, 2006 05:07 PM |
