If I remember right, a guy on a german forum said they were using mQX motors (I think those were CCW again, but I am not entirely sure anymore) However, this was not 100% plug and play - but again ... maybe something worthwhile taking a closer look at ...
Latest blog entry: The WLToys V912
Joined Feb 2007
When I was at lhs last I debated between ccw mcx and regular nano setup, since I also had the solid boom mod. Unless I'm remembering wrong, I think it was $10, so I figured for $14 just get the nano setup with the hollow boom (that lasted less than a day), but you also get another tail rotor and holder too.
I tried a V911 tail motor, didn't have enough hold unless boom was 6-6.5" long. looked funny but then motor did seem to hold, even with flips. Plus tail motors seem to last pretty good on these. Even my 2nd main motor is lasting better. |
Australia, NSW, Newcastle
Joined Jun 2012
I guess I kinda understand the battery life side of it. My perspective would be different though, as I have 8 stock batts, 3 hyperions, and a bunch of old turnigy's that I throw through mine. I rotate maybe 10 through it each time I fly, and since I'm no 3d expert, (only just starting to try rolls and flips) I get an easy 4-4.5 from stocks, and 5 out of the hyperions.
Maybe someone else has posted this but I must have missed it... Anyone with tail wags or vibration try this out... install your battery and then take some scotch tape and secure the battery to the battery holder so it cannot move... it makes my Nano's tail the most solid I have ever been able to get it... go figure
![]() One caveat, it seems to work perfect on my Airtime skids, but not as perfect on the stock skids... I guess they are inherently so flimsy it is almost impossible to get them to not oscillate under load... anyways, I hope someone benefits from my trial and error
Joined Jun 2012
I only fly in IU, but with some FFF and attempted rolls, I've gotten a 6 min 15 sec flight out of a stock pack. I kinda wish I didn't push it so far, as it is a damaged battery now, with no real umph left, but now I know.
I don't spend a lot of time with the motor stalling though, no pitch pumps or overly hard pitch changes, as my rolls are quite large. I suspect that when I get better that will change. I fly to 4 mins on the nano and both my mcpx's though so lots of home toys. |
Have flown mcx and mcx2 fine. got the nano cpx today. Have to work, but couldn't resist. Set it up according to http://www.rchelicopterfun.com/ ebook on tame settings. Still a handful, but was able to hover it somewhat.
1. Notice that it tilts slightly to the right when hovering (almost as if it where a plane, one wing would be heavier than the other--not much, maybe a few degrees). 2. Servo twitching like crazy. Is that normal for the nano? Right out of the box upon binding with DX8 it did it, and still does. Fine while flying thought. 3. After landing and when blades are spooling down, almost all the way stopped, the bird does a little shake as if something is out of balance, but then is fine and stops. It doesn't shake at all while flying, just that second while spooling down. 4. I got a few Turnigy nano tech 150's but they seem to be about 1mm too thick. :-( 5. I still need to go through the pitch check/setup per http://www.rchelicopterfun.com/ but couldn't resist flying out of the box. Radio is all setup, but I still need to go through checking pitch (attempt to anyway) ;-) 6. I've heard using the bullet blades are more stable? Should I put them on and just use the bullet blades while learning? 7. I've also heard the blade msrx blades are as good/better to use on this nano? |
| Thread Tools | |
| Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter | zadaw | Micro Helis | 5192 | Jun 13, 2013 11:46 AM |
| Discussion is there anything better than mcpx v2 at same or smaller size? | Legendary_Agent | 3D Electric Heli Flying | 33 | Feb 24, 2012 08:46 PM |
| Question What’s Better than a Blade CP and Smaller than a Trex? | HavingFun2002 | Micro Helis | 74 | Mar 05, 2006 05:07 PM |
