Old Dec 09, 2012, 09:56 PM
Matt Ls Thumbs is offline
Find More Posts by Matt Ls Thumbs
Joined Aug 2012
The 1S charger with the Nano needs 6V input, so no, you cannot use your bigger power supply.
Best to invest in a better 1s charger. I use a Eflite 4-port charger, which isn't much better, but at least it came with a transformer.
Matt Ls Thumbs is offline Find More Posts by Matt Ls Thumbs
Old Dec 09, 2012, 11:34 PM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
Originally Posted by Tat76 View Post
I'm loving mine so far and after two days of flying I'm hooked.. I do feel that I've lost some power either from the lipos or the motor. Full throttle, climbs slow it seems but maybe it's me since at first I wouldn't make fast moves.
Is there an aftermarket charger? Can I use a power supply from my big lipo charger (2s-3s) to power the charger instead of using AA?
it is just the simple use of an adapter - and you can ACTUALLY use a "big lipo charger" to charge the nano (=msr/x) batteries. (I do this with mine all the time ... balance charge 3 at a time with the Xtreme charge harness[I use either an ImaxB6AC or a Thunder AC6])
Old Dec 10, 2012, 08:40 AM
elgecko is offline
Find More Posts by elgecko
Fighting Gravity
elgecko's Avatar
USA, PA, Red Lion
Joined Sep 2005
Make sure your gear has not slipped down on your main shaft. You can just push it back up. It will cause you not to have as much positive pitch.
elgecko is offline Find More Posts by elgecko
Old Dec 10, 2012, 10:24 AM
Willyboy is offline
Find More Posts by Willyboy
Willyboy's Avatar
United States, CA, Tehachapi
Joined Sep 2007
I charge six Nano batteries at a time on my iCharger 106B. It' s the only way to do it if have quite a few batteries.
Bob
Willyboy is offline Find More Posts by Willyboy
Old Dec 10, 2012, 12:12 PM
Ramblin is offline
Find More Posts by Ramblin
Canada, ON, Carleton Place
Joined Jun 2011
I am trying to remove the tail boom from the tail motor housing but it won't budge. Any suggestions?
Ramblin is offline Find More Posts by Ramblin
Old Dec 10, 2012, 01:00 PM
Petrie is offline
Find More Posts by Petrie
United States, AR, Lockesburg
Joined Feb 2012
Since the talk is about chargers. Why dose the manual say not to use rechargable batteries? I have a iCharger under the tree but the for now the stock charger eats AA batteries.
Petrie is offline Find More Posts by Petrie
Old Dec 10, 2012, 01:31 PM
Puddytatter is offline
Find More Posts by Puddytatter
Joined Nov 2012
The charger has a little chip inside that monitors voltages and decides what lights to display. Regular batteries are usually 1.5 to 1.6 volts and they gradually lose voltage over time. Rechargeable batteries are usually 1.2 volts and they maintain that voltage almost to the end and then suddenly drop off. I guess they optimized the chip to work with regular batteries.
Puddytatter is offline Find More Posts by Puddytatter
Old Dec 10, 2012, 01:42 PM
Joined Nov 2012
Get a block of wood and drill a hole through it that is just a little larger than the diameter of the tail boom. Then you should be able to push the tail boom through the hole and by quickly pulling on the end it should "knock" the motor housing off. If that doesn't work, put the boom in a vice and use something to pry against the block of wood.
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Because nominal voltage would be 4.8V, rather than 6V. Alkaline cells also have much higher capacity than NiCad & NiMH cells of the same letter size. I always keep a couple of Radio Shack 1A wall-warts with changeable plugs & selectable 4.5, 6, 7.5, 9, and 12VDC outputs on hand - just in case I may need one. http://www.radioshack.com/product/in...ductId=3875403
Joel
turboparker is offline Find More Posts by turboparker
Old Dec 10, 2012, 02:55 PM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
Temptation
Hmmmmmmmmmm. . . .
I just walked by the dining room table and guess what I saw on it all unwrapped and cute and looking like it really wanted to be test flown before Christmas . . . . And my wife won't be back for an hour or two . . . . I mean, it's not REALLY a maiden, more of a test to make sure everything works, mechanically and all. . . .
On the other hand, it might be a bit hard to explain why the little thing spontaneously exploded in it's box and got grass stains all over itself if I accidentally (and very likely) crashed it . . . .
Ho Hum, how many more days till Christmas?
whichwaysup is offline Find More Posts by whichwaysup
Old Dec 10, 2012, 04:45 PM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
I'll add that to my list of advantages of flying in winter with a foot of snow. There is very little risk of damage and virtually no risk of grass stains.
Jovanx is offline Find More Posts by Jovanx
Old Dec 10, 2012, 07:36 PM
Ramblin is offline
Joined Jun 2011
Thanks, that did it!
I had been prying against the end of the housing but was deforming it with no sign of progress.
Old Dec 10, 2012, 11:08 PM
lkagan is offline
Find More Posts by lkagan
lkagan's Avatar
United States, FL, Boynton Beach
Joined Aug 2011
Originally Posted by Jam-ehz View Post
When I try to pirouette starting with a still hover, tail toward me, it always starts heading to my 2 O'clock by the time it gets to 180 degrees, quite quickly in my opinion..
I figured the AS3X would keep the heli still but not the case..
Just wondering if there's something to adjust on the heli, or am I just expected to counter it with the sticks?
If it's extreme, that's an effect of an unlevel swash plate. You can try leveling the swash by using a zip tie around the main shaft or maybe ensure all links are same length.
lkagan is offline Find More Posts by lkagan
Old Dec 11, 2012, 12:05 AM
Wookster is offline
Find More Posts by Wookster
Augernaut
Wookster's Avatar
United States, KS, Overland Park
Joined Jan 2010
indoor inverted flight has taken its toll on the little bird. One observation for the folks having trouble with lift. In almost every blade heli there is a collar on in the middle of the main shaft that is screwed in place and keeps the main shaft from sliding down. On this heli it is glued in place. It is also a very low quality glue. my main shaft collar has slipped and now its almost impossible to fly. add in a tail rotor that is now acting up, I have to give it a flick to get it started, and it looks like the repair costs are starting to add up. Been flying her pretty hard, but man does it break down a lot. Parts are durable in crashes, but not for longevity.
Wookster is offline Find More Posts by Wookster
Old Dec 11, 2012, 12:11 AM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
I just got my CPX and am reading the manual and the thing keeps talking about Stunt mode.
I'm going to fly this with my DX8, programmed as they suggest but I can't figure out what stunt mode is or if it applies.
My recent Heli experience is fairly limited but I figure this ought to be safe over grass. My previous, flybar equipped version withstood amazing punishment.
Do I need to worry about stunt mode? How do I invoke it if it applies.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6142 Yesterday 11:44 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
