Old Nov 29, 2012, 11:57 PM
CatBird is offline
Find More Posts by CatBird
CatBird's Avatar
Louisville, Colorado
Joined Oct 2007
Originally Posted by dragnse7en View Post
Do anyone have a different trick to add the PVA or rubber cemement to the ends of the spindle thread? Or - an easier way using Shoe Goo?
I realize it's not exactly what you asked, but blue Loctite is the best choice for this and all metal-to-metal stuff on electric helis. Just a tiny dab on the threads, get the tension right, and leave it an hour or so before you fly it. Don't use it on screws into plastic.
CatBird is offline Find More Posts by CatBird
Old Nov 29, 2012, 11:59 PM
J_skaggs is offline
Find More Posts by J_skaggs
United States, CA
Joined Jan 2012
That's what I use. Works great.
J_skaggs is offline Find More Posts by J_skaggs
Old Nov 30, 2012, 12:33 AM
dragnse7en is offline
Find More Posts by dragnse7en
dragnse7en's Avatar
United States, MA, Northampton
Joined Jan 2009
Correct - I use blue thread locking compound on my rc cars. I'm not at all personally comfortable using it in a tight spot on my helis though.
Do you have a trick to keep the lock-tite off the plastic blade grip?
*edit - nevermind - I got it. It's 1:35AM here and I'm going sleepy time
dragnse7en is offline Find More Posts by dragnse7en
Old Nov 30, 2012, 01:17 AM
ccpdx is offline
Find More Posts by ccpdx
United States, OR, Hillsboro
Joined Jun 2010
weak throttle?
This thread is moving fast!
I'm not sure why my 'Nano barely seems to move upward even at full throttle in normal mode.
I mainly fly in normal mode, high rates on the RTF/DX4e (so I can fly indoors without having to go get my main transmitter). Two batteries are just a week or so old, and the other two were purchased today. I can fly to the ceiling of my livingroom but after the first 30 seconds of flight it may take some effort. Throttle trim is in the middle, and I haven't tried re-binding yet.
Any ideas?
Charles
ccpdx is offline Find More Posts by ccpdx
Old Nov 30, 2012, 04:05 AM
jlk69 is offline
Find More Posts by jlk69
RC Aircraft Junkie
jlk69's Avatar
USA, CA, Chula Vista
Joined Sep 2004
Originally Posted by Daryoon View Post
Now, slowly sprinkle baking soda on the wet CA until it won't take anymore. I do it like I am seasoning with kosher salt.
The CA reacts with the baking soda instantly to form a very hard surface..
Great tip, I have never heard of that before. I too have had problems with the arms on the swash breaking/cracking. On one swash two arms have been repaired with CA and splintered carbon fibers to reinforce. The other swash has one arm repaired the same way. Although expensive, I think an aluminum swash
is in my future. Hopefully the weight will be the same or only slightly heavier.
jlk69 is offline Find More Posts by jlk69
Old Nov 30, 2012, 05:57 AM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
Any ideas?
Charles
Did you do the Neutral Pitch at Throttle Midstick check? Sounds like lack of pitch, OR you may have a bad motor.
heritageflyer is offline Find More Posts by heritageflyer
Old Nov 30, 2012, 07:16 AM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
yeah. The swashplate is the smallest I've seen of these types of heli. And the nano generates so much force during pitch changes. Add to that the Wild brushless motor at 16000kv. I think the swashplate needs to be reenforce. After stiffening it up, the heli feels much more precise and locked in. With the head govern at a higher speed, the nano is so stable in the air.
We'll see how this holds up.
A cnc swashplate sounds like a worth while upgrade. The stock swashplate is about .52 to .56g. The RakonHeli swashplate is .79g. The RakonHeli with the antirotation pin and guide moved to the back is .89g.
The MicroHeli weighs near identical to the RakonHeli version.
Both are about $25-27 bucks. Depending on if you buy the xswash version.
The MicroHeli antirotation guide interfered with the servo arms. And they have since fixed it and shipping replacements to owners right now. For those that purchased from another dealer, info is forthcoming on how to ask for a replacement.
Daryoon is online now Find More Posts by Daryoon
Old Nov 30, 2012, 07:40 AM
Petrie is offline
Find More Posts by Petrie
United States, AR, Lockesburg
Joined Feb 2012
I just got the Nano back from HH yesterday with a new 3 in 1 board. They said it was test flown but last night could not get it bind. By the manual it is only 8 steps canít be that hard. I have tried far away and touching the canopy to no avail. Spent a time last night reading post looking for a solution. Several people have had the problem but I could not find a definite thing that was done to resolve the problem. Any ideas? Calling HH back today. Thinking of just giving up on the Nano , put it all back in the box and place it on the shelf in the shop to stay.
Petrie is offline Find More Posts by Petrie
Old Nov 30, 2012, 08:43 AM
elgecko is offline
Find More Posts by elgecko
Fighting Gravity
elgecko's Avatar
USA, PA, Red Lion
Joined Sep 2005
I posted this a little while back...
As for binding, mine occasionally has issues.
It seems to work by having the radio on the ground 3 to 4' away from the heli. Plug the battery in and if I stand up and move away from both, it seems to bind with no problems. Sometimes if I'm on my knee waiting for it to bind, it doesn't.... strange
May have to unplug and try again. Most it took me when giving me problems was 3 times.
elgecko is offline Find More Posts by elgecko
Old Nov 30, 2012, 09:48 AM
Petrie is offline
Joined Feb 2012
@elgecko
You are talking about binding after a battery change right? What about your Initial bind? How did that go.
Old Nov 30, 2012, 10:54 AM
elgecko is offline
Fighting Gravity
elgecko's Avatar
USA, PA, Red Lion
Joined Sep 2005
Yes I was referring to after a battery change. I take it you are referring to initial binding.
IIRC I thought my heli was messed up and would not bind. Then I read the directions about holding the rudder stick...
Is it a RTF or BNF?
What radio are you using?
I have a computer radio, DX7, and think you have to hold the rudder stick to the right until the heli binds. If using a RTF radio, DX4e, the rudder stick is held to the left until it binds.
Just checked the websites manual and that is what it says.
Also saw it mentioned if the pitch and throttle must be programmed correctly or the heli will not bind.
Last resort; sometime a good chuck across the room scares the heli into binding....
Old Nov 30, 2012, 11:14 AM
ccpdx is offline
Joined Jun 2010
Thanks. No. I'll check. Right now it's as it came.
Charles
Old Nov 30, 2012, 12:44 PM
jpconard is offline
Find More Posts by jpconard
Joined Feb 2007
What advantage does the pin moved to the back provide? I read it helped something on the MCPX, but is it necessary on Nano. Thinking about getting a swashplate, my stock one is glued on all 3 arms. So with glue and reinforcement it would probably be about equal to the others.
Bought a backup, OK for now.
jpconard is offline Find More Posts by jpconard
Old Nov 30, 2012, 02:21 PM
ccpdx is offline
Joined Jun 2010
Yep, my lack of upward movement was due to lack of pitch. I found the cause in the manual - my main gear had slipped about a millimeter, so I wasn't getting enough positive pitch.
Meanwhile, kudos to Horizon's support! They're sending me a new servo. One of my side servos is/was sticking. I was able to demonstrate it to myself and my wife many times, although at the moment the symptom seems to have disappeared.
Charles
Old Nov 30, 2012, 02:39 PM
Joined Nov 2008
Something to do with more Elevator travel I thought, frees it up for greater travel?
Charles
Cool! Glad you found it! I just replaced the left side servo on mine. Locked up around flight 26 and the little servo motor got so hot it melted some of the mechanicals plastic holder frame. Bought a couple new ones and fixed it right up, got a spare too.
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6160 May 20, 2016 04:10 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
