I say, get it as close as possible. If the swashplate is really off...like one side is much lower than the other...don't think the electronics will just handle that offset properly.
Here's the molded alignment marks that Blade started to put into the head and blade grips. I think I saw it first on the 130X. Bigger R/C heli have done this for a while now.
Latest blog entry: Syma S105 Battery Mod
I always set up all my helis proper before even attempting to add a battery to it and turn it on. J. Salt has some great tips - I think it's called rchelicopterfun.com, I'd suggest that you Google it
![]() Quote:
![]() Ahem: Quote:
![]() http://en.wikipedia.org/wiki/Teachin..._of_the_phrase |
BTW, not meaning to be too harsh on you dragnse7en -- welcome aboard!
FWIW, Jasmine is also is a bit of a [relative] old timer around the heli threads, so I think the question was a bit rhetorical, as were the answers -- yes, the ASX can soak up the slop for the most part, but nothing beats doing it right mechanically, if you are hoping for best overall operation. And yes, John Salt is a very good resource for beginning the long road to heli nerd-vana! Cheers!
Sick of having to fabricate a new tail boom nightly...and having to take care in filing the key at each end...I modded the Nano CP X frame to accept 2mm square rods instead.
There's more meat to it and should help reduce the frequency of fractures due to the thin wall of the keyed part of the Nano round tail boom. ![]() More info about the mod here: http://www.hacksmods.com/2012/11/bla...tail-boom-mod/
(Rear Servo) SPMSH2026L 2.1 g Linear Long, 38mm Lead That's what I ordered, one each. Yes, my left side servo screw/slider is locked up solid. Debonder did not help, so it is not just stray CA in there. Froze up, stuck in the middle. |
Been making good progress with flipping the nano keeping it in a very tight area.
Was flipping it 2-3' above the ground repeatedly but around the 6th or 7th flip drove the tail boom into the ground. You guessed it, split my first tail boom. Going to try a little CA. I flew the remaining battery and 2 more without any degrade in performance, thankfully. |
United States, CA, Baldwin Park
Joined Jun 2004
When I see them come back in stock I'll get a couple mechanics only. I don't think the Board is fried so will keep it for a spare.
That's awesome! ![]() ![]() Are you honing your mad 3D skillz? Is that how you're breaking those tail booms? Can't wait to see some vids of you doing piro flips and hurricanes at your field. ![]() ![]()
Latest blog entry: Fitting a Bravo SX fuselage to a GW 9958...
| Thread Tools | |
| Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter | zadaw | Micro Helis | 5181 | May 13, 2013 01:16 PM |
| Discussion is there anything better than mcpx v2 at same or smaller size? | Legendary_Agent | 3D Electric Heli Flying | 33 | Feb 24, 2012 08:46 PM |
| Question What’s Better than a Blade CP and Smaller than a Trex? | HavingFun2002 | Micro Helis | 74 | Mar 05, 2006 05:07 PM |
