Old Nov 19, 2012, 06:46 PM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
Originally Posted by Santley View Post
Did you check if the main drive gear has dropped down? There would be slop in the shaft.
Yeah i have done that
Pitch curve
LOW 25% 50% 75% high 40%50% 65% 80% 100% EXPO INH
throttle LOW 25% 50% 75% High 0% 40% 60% 80% 100% expo INH
Mal
kushal_22 is offline Find More Posts by kushal_22
Old Nov 19, 2012, 06:56 PM
jpconard is offline
Find More Posts by jpconard
Joined Feb 2007
how many flips do most of you get before running out of power? I finally got blackflip technique down and did 6 or so in a row (across a couple batteries). About the 4th flip I'm out of pos. collective power. I had on a 6" tailboom (solid 1.8mm) along with V911 tail motor, and V911 canopy, so a little weight added. 2 batteries came with it about 2 months ago, my 3rd is from months ago and is noticeably weaker. On 2nd motor and think it is OK.
Makes me debate adding any aluminum parts, but not sure if they add much weight. Rakon shows rotor head only adds .01 grams. Not sure about grips and swashplate. Haven't broke rotor head, but have broke 1 grip and swash arms.
jpconard is offline Find More Posts by jpconard
Old Nov 19, 2012, 07:36 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Pitch curve
Mal
I think you answered your own question in that you have set it with no expo where 30-50% expo is common. Setting the D/R to have less range doesn't make it less twitchy at center.
In fact I'd have a hard time not overlapping elv into ail or ail into elv with any movement of the stick.
Start with 30% expo and go from there.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Nov 19, 2012, 08:05 PM
ruzam is offline
Find More Posts by ruzam
Go small or go home
ruzam's Avatar
Canada, SK, Regina
Joined Mar 2008
I don't know about the other transmitters, but on the dx6i there is no expo for pitch/throttle curves. Expo only applies to aileron, elevator and rudder. Not pitch or throttle.
ruzam is offline Find More Posts by ruzam
Old Nov 19, 2012, 08:16 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
I get 2.5-3 minutes of constant flipping on a stock nano.
indoorheli is offline Find More Posts by indoorheli
Old Nov 19, 2012, 08:19 PM
indoorheli's Avatar
Joined Sep 2007
I thought the dx6I had pitch expo...the other tx's do(8,10,18).
Old Nov 19, 2012, 08:20 PM
Jam-ehz is offline
Find More Posts by Jam-ehz
Jam-ehz's Avatar
Canada, ON, Toronto
Joined Sep 2004
Originally Posted by turboparker View Post
Yeah, there's an app for that.
Joel
That's exactly what you can do with the throttle/pitch curves.. Instead of a linear set of numbers, 0/25/50/75/100, just set them more gradually at first, then ramp it up.. 0/15/30/60/100
Jam-ehz is offline Find More Posts by Jam-ehz
Old Nov 19, 2012, 08:35 PM
indoorheli's Avatar
Joined Sep 2007
I am having problems with my Nano getting up off the ground and into a hover and also wanting to drop drastically in a turn or when flaring to stop FF i have checked the Obvious things i will be looking at the main shaft to see if that is bent
Mal
if your main shaft has no slop then my bet would be that you don't have 0 pitch at center stick and instead have negative pitch.
Old Nov 19, 2012, 08:50 PM
jpconard is offline
Joined Feb 2007
Thanks, I'll go pick up a battery tomorrow see if it helps. Hope my 2nd motor is not going out. Went over it, put back on stock tail boom, original canopy.
Old Nov 19, 2012, 09:28 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
So my 2.5-3 Min. in the 50F temps is normal then. I was doing about 5-6 flips and then some faster circuits.
Just got some good bearing oil at the LHS 45 miles away on the way home from the big city tonight. It's a hypo oiler so was really nice to pinpoint a two small drops on the main shaft bearings and the motor bottom and the Swash area. Can't wait to try it out and see how she does.
Ok, understand on the 300X frame issue. I read that awhile back when I was heavily following the 300X thread.
I removed my tailboom this AM and tonight got it straightened and thin CA'd and reinstalled. Everything looks totally good to fly again now. Just need some time.
heritageflyer is offline Find More Posts by heritageflyer
Old Nov 19, 2012, 10:21 PM
RoboHeli is online now
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
Has anybody put a tach on the Nano to see what their headspeed is at various throttle positions? I was comparing my Nano to another one tonight and I noticed what appeared to be a higher pitch from the motor of the second one when it was flying. Same transmitter & settings for both. Just wondering whether my head speed is just lower somehow. :/
RoboHeli is online now Find More Posts by RoboHeli
Old Nov 19, 2012, 10:58 PM
23DM is offline
Find More Posts by 23DM
MCX2..120SR..NCPX..MQX..D X7s
23DM's Avatar
United States, OR, Salem
Joined May 2012
Packing up my 30 day old Nano to send it back to HH. She flew fine until yesterday when suddenly she would not link up to my DX6i. Tried it all with no joy.
No clue as to why as the only damage incurred was a broken tail boom 2 weeks ago. Here's hoping that HH will do me a solid...
23DM is offline Find More Posts by 23DM
Old Nov 20, 2012, 12:02 AM
High Orbit.....
Joined Jun 2009
Sorry my stupid... your correct. I read what he wrote but was thinking unstable needed more expo on his 3 axis forgetting he posted the pitch/throttle.
I've been reading the various concerns about this heli being twitchy unstable and not being a great heli pilot having really only 3 years on an Align 450, I find the opposite; its very predictable but certainly not hands off.
I've lost count of how many flights I've done throughout the house for the past month but there are times I can even let go of the sticks with little drift. This does need more collective control handling I find and with my 9503 I have 5 throttle/pitch curves and all axis throttle mix to help. But the moment I whack it into something, any precise settings gets changed.
So you just have to fly the thing with a good manual feel for collective input.
Some mention trouble on takeoff... the down pitch in norm pushes it around at odd angles. So I'm quicker to spool up at mid stick where the blades are neutral. After that it feathers off the ground quite stably.
Old Nov 20, 2012, 12:07 AM
MarcusMX233 is online now
Find More Posts by MarcusMX233
MarcusMX233's Avatar
United States, TN, Johnson City
Joined Oct 2011
Here some crappy vids of my mild and wild brushless nanos. On the mild setup Iuse hyperion 180mah batteries and a 75% flat throttle curve. On the wild setup I use 240mah hyperion betteries and the mcpx tail boom with a 75% flat throttle curve. Sorry about the bad quality.
Brushless nano cpx wild (1 min 38 sec)
MarcusMX233 is online now Find More Posts by MarcusMX233
Old Nov 20, 2012, 12:30 AM
Joined Oct 2011
Brushless nano cpx mild (1 min 52 sec)
Nano cpx brushless mild vid#2 (1 min 31 sec)
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6160 May 20, 2016 04:10 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
