Dumb question. The bullet blades are installed with the "Blade" logo facing upward, right (just like the non-bullet blades)? That is, the bullets lead the blade? I've installed them this way but have to wait an hour or so for the kids to go to bed before I can try it out.
Latest blog entry: Fitting a Bravo SX fuselage to a GW 9958...
Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Thanks.
Two more flights on it tonight. Just practiced tail-in hovering and box patterns.* Switched to the bullet blades * Tightened up the blades just a smidge so that they weren't so darned floppy * Removed all expo from my DX6i * Lowered D/R down to 70% on all ELEV/AILE/RUDD * Changed canopy and tail to blue (Ah....much better LOL) It flew very, very well. The TBE I was seeing definitely seems to have gone away now that I'm not trying to chase the heli around with a mushy center stick. Time to do two more flights before bedtime.
One immediate advantage of tightening up the blades is that the heli doesn't shudder like crazy when I land and zero the throttle anymore.
Is there any balancing needed on the Nano? I was running some Glacier batteries that fit lose in the slot and the battery slipped all the way back and was just hanging on. This had to change CG and the heli flew better with the added weight on the tail. I’m going to try some tape on the tail for weight. What is the correct method to check CG?
Usually correct CG would be at the center of the swash. On a bigger heli you could hold the bird by the main blades sideways with the motor moved (pinion moved away so main gear/shaft move freely) to check CG.
Though some will argue CG isn't that big of a deal with a 3-axis gyro and personally I would never add dead weight to a UM/Nano. Here's a quick 3 min video on it, though I have to admit I did not watch the video all the way through, just a quick youtube search.
Yup, the second method shown in the video is how I balance heli. Even on these micro. Works on both flybarred and flybarless helis.
Because with the main shaft and bearing, you essentially have a built in balancer. ![]() I agree with queadlunnrau. Don't add dead weight. So, instead of adding weight, simply mark how far the battery should be slide in to keep that center of gravity close to centered. When the tail and nose is in balance, you can rotate the heli to point at any position. i.e. 3o'clock, 5o'clock, 7o'clock, and it will stay stuck there. Though the video said you can check balance with the gear in place. I personally feel it's important to disengage the gears. It's simple to do this if you push up on the motor a little bit till the two gear are not meshed anymore. And oh, a tip: Have some of those liquid electrical tape on hand. It's like $5 or so at Home Depot...and it's great for nicks in insulations and using as "glue" to keep the motor in place. Easy to peel off when unneeded. It's basically the same stuff that Blade Heli uses. Good to have around and the 4oz container seems to last forever. Use a toothpick to apply. Just don't get high off the smell. Also good for the feathering shaft nut. You did check that on your new NCPX didn't you? Otherwise, you may find the blades flying off one day. Also good for the main gear.
High Orbit.....
Joined Jun 2009
Liquid electric insulation! Nice idea!
I was just about to ask what you guys were using to hold but not glue parts in place. I started noticing for some reason the tail boom started rotating from 90*. Even when I snug it in place powering up it slowly rolled right. I'll a little liq tape on the tip and see how long it holds ups. Nice tips on the feathering bar too. I pulled it, rolled it on the flat of my vice with a square and put it back together. Smooth as silk! Even when you wack these puppies around its so effortless to get them true again. |
United States, NY, Coram
Joined Jul 2012
One more time:
Hey!!! anyone order the mega power batteries from heli direct? They were on sale for $.99 each so I picked up 5 of them. They aren't taking a charge in the e-flight charger. It is the only charger I have for these batteries so I don't know if it is the charger or the batteries. I tried 3 different sets of AA batteries in the charger too thinking it was those but it wasn't. Anyone get those batteries?? |
Hoo boy. Not yet. I've heard a fair amount about it but don't know much about it yet. I gather from the discussion here that is what those little extra tools that come with the Nano are for. I haven't gone looking for Youtube videos on how to do this just yet but I probably should, huh?
BTW - those batteries are cheap for a reason. They're only 15c, and the factory cells are 25c. They are extremely low-performance cells, which means they will perform very poorly in this application. Modern UM LiPos are 25c or higher. Also - if you're serious about the RC hobby, do yourself a huge favor & pick up a decent hobby-grade multi-chemistry charger that displays charge info. Also pick up some adapter cables. You will be very glad that you did. Joel |
| Thread Tools | |
| Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter | zadaw | Micro Helis | 5181 | May 13, 2013 01:16 PM |
| Discussion is there anything better than mcpx v2 at same or smaller size? | Legendary_Agent | 3D Electric Heli Flying | 33 | Feb 24, 2012 08:46 PM |
| Question What’s Better than a Blade CP and Smaller than a Trex? | HavingFun2002 | Micro Helis | 74 | Mar 05, 2006 05:07 PM |
