Old Oct 20, 2012, 07:13 PM
skeppley is offline
Find More Posts by skeppley
2 Turbos...Nope 1 Big one
skeppley's Avatar
United States, PA, Lake Wynonah
Joined Aug 2004
Originally Posted by CatBird View Post
People looking for additional batteries might try these:
http://www.valuehobby.com/power-syst...placement.html
I have 8 of their earlier batteries marked 15C, and they transformed my micro Sukhoi. They even work remarkably well in my nCPX, despite being two years old now. At $1.69 and shipped from the US, 4 batteries is at most a $10 mistake.
Bill
I have a bunch of these and they work pretty well. I set the timer for 3:30 and can beat them pretty good most of the time. Definitely a good cheap alternative
skeppley is offline Find More Posts by skeppley
Old Oct 20, 2012, 07:15 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
At thirteen bucks a motor, it seems like a brushless mod would be a no-brainer over the long run.
Could the ESC flashing be done with the USB AVR programmer that I bought for doing bigger ESCs, or do the tiny ones need something different?
Piece is offline Find More Posts by Piece
Old Oct 20, 2012, 07:35 PM
ruzam is offline
Find More Posts by ruzam
Go small or go home
ruzam's Avatar
Canada, SK, Regina
Joined Mar 2008
Long run, short run, who cares. I just want a reliable motor that I don't have to coddle so it 'maybe' lasts a few more flights. Watching motors die on the msrx got tired real fast. At least the msrx motor was easy to get at and replace.
If I can eliminate the motor as maintenance point, it's worth. Don't even care much if a BL has more power or less, as long as it still flies with a comparable flight time.
HK recently came out with brushless ESC for 'micro helis'. For example http://www.hobbyking.com/hobbyking/s...elicopter.html It's (looks like) a fully plug and play brushed to brushless conversion board for the mcpx, just add motor. No custom firmware, no flashing, no soldering.
My bet is it won't be long before plug and play ESCs are also available for msrx/ncpx size helis too. Then it'll be easier and cheaper than ever to convert.
ruzam is offline Find More Posts by ruzam
Old Oct 20, 2012, 07:44 PM
J_skaggs is offline
Find More Posts by J_skaggs
United States, CA
Joined Jan 2012
If there was a reliable, plug and play, inexpensive brushless option available I would probably jump on it too just for the cost savings as I'm on my third nano motor in a little over a month.
J_skaggs is offline Find More Posts by J_skaggs
Old Oct 20, 2012, 08:07 PM
shahram72 is online now
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
It looks like it just plugs into the motor port so why would this not work on the nano? I'm sure someone will try soon.
shahram72 is online now Find More Posts by shahram72
Old Oct 20, 2012, 08:08 PM
Donaldsneffe is offline
Find More Posts by Donaldsneffe
Vienna calling...
Donaldsneffe's Avatar
÷sterreich, Wien
Joined Aug 2010
Still struggeling on brushless conversion (base plate) and waiting for AstroidDesigns solution - so what to do with the Nano?
Does not fly better, but is prettier
Canopies and TDR landing skids by Frank Lachmund.
TDR 29.8 g, Logo XXtreme 30 g.
With some of their "big brothers":
Donaldsneffe is offline Find More Posts by Donaldsneffe
Old Oct 20, 2012, 08:25 PM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
Yes. I believe there is a thread on it over at HeliFreak.
But just grab the Toolstick from HobbyKing. It's available there now for about $10. Then you can use the BLHeli Setup GUI for easier programming.
Daryoon is offline Find More Posts by Daryoon
Old Oct 20, 2012, 08:27 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
I am fairly sure that is a custom firmware and that they use blheli but don't give credit to where it is do. If it doesn't have a converter you can almost be assured it is pre-flashed with blheli code.
You can make a plug in play like this for the nano but probably won't be out for sale with the 3a esc for another few months.
Right now it is pretty cheap to go brushless at $10 for an esc and $15-30 for a motor $10 more if you dont have a usb stick to flash with. But once you have one you can flash and upgrade lots of stuff
Imo way to much weight for a good conversion on the nano where every gram is equal to 3.5% weight gain. My esc is around .5 grams
indoorheli is offline Find More Posts by indoorheli
Old Oct 20, 2012, 08:49 PM
slo-fly is offline
Find More Posts by slo-fly
certified crash instructor
Scottsdale Arizona
Joined Dec 2009
I'm almost finished installing a sukhoi xp brushed motor with 9 tooth pinion in the nano. Not sure what will happen but I'll let you know shortly.
slo-fly is offline Find More Posts by slo-fly
Old Oct 20, 2012, 08:50 PM
ruzam is offline
Go small or go home
ruzam's Avatar
Canada, SK, Regina
Joined Mar 2008
Here we go:
http://www.hobbyking.com/hobbyking/s..._100_etc_.html
This is a 'dual' brushless ESC for the mcpx. The main motor is a 10A and the tail motor is a 3A. The interesting part is that it 'looks' like the ESC is built as two completely separate ESCs sharing the same board. It 'looks' like you could cut the thing in two with a dremel and have both a 3A nano brushless ESC and a 10A mcpx brushless ESC (no programming required). That's a 'two for' if you happen to be considering an mcpx upgrade also.
But without seeing both sides of the board, it's hard to say for sure if it can be simply cut in two. HK also sells a dual brushed to brushless 'converter' (a dual version of the 'Steve' without the 'ESC'). So the other side of the board might be a single chip dual converter that would make this inseparable.
Old Oct 20, 2012, 09:01 PM
indoorheli's Avatar
Joined Sep 2007
Instead of trying to split something how about
This http://www.hobbyking.com/hobbyking/s..._ESC_3_5A.html Or this http://www.hobbyking.com/hobbyking/s...idProduct=9667
with one of these http://www.hobbyking.com/hobbyking/s...opter_ESC.html
ChrisFlysRC is offline
Find More Posts by ChrisFlysRC
United States, PA, Lebanon
Joined Oct 2007
EFlite Nano CPX
I have checked XHeli, wowhobbies, helipal and other RC Heli site and want the best Micro Flybarless heli on the market. XHeli most are sold out by Walkera. I want to get started off right in the world of RC Helicopters so I can enjoy flying learning. I have a simulator and its a G5.
I have been flying RC airplanes for over 5 years and want to find a fun, durable micro heli thats a blast to fly. Id like one for indoors and also to fly outdoors.
Id like to get flying a 400 size Heli in the near future like next spring or earlier after I fly this smaller Heli. Id like to fly only flybarless heli due to lower part and reliability
Also I need alot of batterys so when I fly indoors in colder weather I have alot of lipos to keep flying. What's the best website to keep me in stock with smaller one cell lipos?
EFlite seems to have one of the best smaller helis in the video and add.
Maybe I just answered my own questions and found a good RC micro Heli.
For all you experienced Heli flyers what do you think? XHeli or EFlite where is the best to buy? Also finding replacment parts is a priority since I am flying indoors. Maybe this EFlite heli is so durable maybe I wont need any replacement part. Here is the video. Thanks for any answers. Just seeing the video shows it looks like it would definitely be a blast to fly and enjoy.
http://www.bladehelis.com/ProdInfo/Files/BLH3300-HI.wmv
ChrisFlysRC is offline Find More Posts by ChrisFlysRC
Old Oct 20, 2012, 09:41 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
Would be great to have a plug and play brushless setup.
brushless55 is offline Find More Posts by brushless55
Old Oct 20, 2012, 10:18 PM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
skids and frames ...
I am sure you all know the airtime skids for the nano are available by now ...
And talking about changing nano "looks" ...
I really wonder when the first upgrade frame will be available, so that one can fly without the constant fear the dang canopy posts break if you cough the wrong way at them
erdnuckel2's Avatar
Joined Mar 2009
being worked on in Germany (and in Switzerland as well ...)
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6139 Apr 16, 2016 11:21 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
