Old Oct 18, 2012, 02:11 AM
Teckos is offline
Find More Posts by Teckos
Teckos's Avatar
Joined Jan 2009
Originally Posted by Deltaalphalima1 View Post
I love my new nano but i am having trouble with the tail twitching as if the gain is too high
I have checked the main bearings and they are fine and used both set of tail blades
But still no luck
Anyone have any ideas?
I would check for bent tail motor shaft, dented main gear, unbalanced damaged main blades. If all is in order I would check also the main grip tightness (tight but not too much otherwise they bind and don't rotate smoothly) and see if the feathering shaft isn't bent.
Teckos is offline Find More Posts by Teckos
Old Oct 18, 2012, 09:12 AM
shahram72 is online now
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
OK, I am programming my DX6i now for the nano. Why does it have 10% throttle accross the board for throttle hold? Shouldn't that be zero so that if we hit that the motor isn't trying to turn? I guess it's to maintain a kind of auto, but I'm tempted to set this to zero.
OK, I got it bound now, have not flown yet, but the servos are humming just sitting on a perfectly still table. My Solo pro servos with go active if you move the heli, but not just sitting on the table. Should they be doing this? With the heli perfectly still?
OK, tried to hover in my living room, it tries to shoot off back and to the left, way too fast to call a drift. Need to get it outside.
shahram72 is online now Find More Posts by shahram72
Old Oct 18, 2012, 09:31 AM
gs550t1981 is offline
Find More Posts by gs550t1981
Beginner Pilot
United States, NY, Coram
Joined Jul 2012
Throttle hold across the board is always o% throttle. And the humming is perfectly normal. You will love this heli,,,,,, It's freakin awesome!!!!
gs550t1981 is offline Find More Posts by gs550t1981
Old Oct 18, 2012, 09:58 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
After a month, is the verdict still the same on this heli??
Still debating on gettting one, even though I have an MCPX.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Oct 18, 2012, 10:00 AM
Joined Sep 2011
That's what I thought, but the manual says otherwise. Well now my battery alarm in my DX6i is going off! Arggh! I took the day off but am going to the fair with family later so it will have to wait for Saturday.
I hope I found the right charger for my DX6i. 150mah negative tip 5.5v
Old Oct 18, 2012, 10:04 AM
rcflyair is offline
Find More Posts by rcflyair
rcflyair's Avatar
United States, OK, Ada
Joined Jun 2007
In a pinch, you can just take the back cover off the dx6i, take out the rechargeables, and plop some AA Alkaline batteries in there.....
rcflyair is offline Find More Posts by rcflyair
Old Oct 18, 2012, 10:13 AM
Joined Sep 2011
I forgot they were just AA's in there!!!! Thanks.
Old Oct 18, 2012, 10:16 AM
Deltaalphalima1 is offline
Find More Posts by Deltaalphalima1
Joined Sep 2012
I think the feathering shaft is bent so i will get a new one and see if that will help
Deltaalphalima1 is offline Find More Posts by Deltaalphalima1
Old Oct 18, 2012, 10:34 AM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
the verdict is you have been missing out on this heli for a month
indoorheli is offline Find More Posts by indoorheli
Old Oct 18, 2012, 10:39 AM
You down with EPP?
Houston, Tx
Joined May 2009
Trying to understand why the nano is better than the mcpx?
Please elaborate
Old Oct 18, 2012, 10:47 AM
indoorheli's Avatar
Joined Sep 2007
For a start it is lighter, more robust, solid tail and more 3d capable out of the box. If you also look at all the videos it is apparent more people feel comfortable flipping and flying it inside than the mcpx.
Old Oct 18, 2012, 10:53 AM
Joined Sep 2011
OK did 2 flights in light changing winds. It rotates on takeoff before the tail holds so that's tough for a new to catch and counter, especially in the wind. Also the tail wags a bit at times but it was windy out. And it yaws a bit left under punches. I thought you guys said the tail could keep up... need to try it again in low wind conditions.
Old Oct 18, 2012, 10:58 AM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
+1 I watched all the vids on this thread and it is Superior to the mCPX in flight qualities and durability. Reason I sold my mCPX and want a Nano soon.... Almost there....
heritageflyer is offline Find More Posts by heritageflyer
Old Oct 18, 2012, 11:07 AM
indoorheli's Avatar
Joined Sep 2007
If the tail wags or shows any sign of loss during a pitch pump then you have a mechanical issue somewhere in your heli. Could be the tail blade, motor, feathering shaft, loose skids or canopy, out of balance blades, vibrations around the swash or something else minor that you are missing.
I have ran a brushless on 8t (crazy power) and the motor and pinion combo amplified issues that i didn't see before. So at first the tail blew until i corrected the heli mechanically. Once I did a look over the tail was solid again
Old Oct 18, 2012, 11:16 AM
MacManOhio is offline
Find More Posts by MacManOhio
Joined Oct 2012
Originally Posted by 210 View Post
Here's a video of my RTF nano cpx. It's all stock out of the box with the dx4e on high rates.
http://www.youtube.com/watch?v=b7x2JyhTzOM&feature=plcp
Still looks like an injured dragonfly on meth. I just can't understand the 3D mania.
MacManOhio is offline Find More Posts by MacManOhio
Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter zadaw Micro Helis 6139 Apr 16, 2016 11:21 PM
Discussion is there anything better than mcpx v2 at same or smaller size? Legendary_Agent 3D Electric Heli Flying 33 Feb 24, 2012 08:46 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
