Joined Nov 2012
will the rol be fixed also? I see that on lot of videos. I have tested alot the last week(1.03b3) and the r is not stabel. I have the reset the gyro everytime to be more stabil, but it still goes a litle wild and changes a bit after time ine the plane. Pitch is stable allways. Tested on the bench, reset gyro, connected (osd still connected with 3s) 4s battery, and rol change started to go f.eks -4 to -15 and bak (on the ground, not flying). Happends on both plane I got.
Croatia
Joined Aug 2010
just to be sure,
is storm ok for 5S main battery input via AMP sensor ? (21V when fully charged at startup) (camera and vtx would be at 12V second battery) see caps on pcb are for 16V max, but that's just maybe for 12V onboard that it operates at after it's voltage regulator. better to ask than to be sorry... I run it @ 4S in my plane... but a friend of mine would like to try it in his 5S plane |
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Nov 2011
Dr. Tom only way to know is check the value comming out from the AMP sensor, but i think max 16V according to the small 12v regulator,
I'm not sad at all over the crash, to be honest I dont mind the plane I just sad I lost the OSD!
France, RA, Lyon
Joined Oct 2012
Looks good. Unless you are using a pure glider, the ratio between motor battery and video/storm battery capacity could different that 1/1. My skywalker setup is 5000mAh for motor and esc and 1000mAh for Storm, video Tx, camera and rc Rx.
| Thread Tools | |
| Help! CYCLOPS OSD 1.5 GPS problem. | grassiew | Video Piloting (FPV/RPV) | 2 | Apr 26, 2013 08:30 PM |
| Discussion Use the CYCLOPS NOVA OSD System Auto-return function | Rc Heli Halle | Multirotor Talk | 14 | Dec 22, 2012 07:08 PM |
| For Sale For sale Cyclops OSD NOVA | Schmoopiebunny | FPV/RPV - Equipment and Vehicles (FS/W) | 26 | Mar 26, 2012 10:18 PM |
| For Sale Cyclops Easy OSD V1.6 New In Package | stewtheman | FPV/RPV - Equipment and Vehicles (FS/W) | 4 | Mar 22, 2012 11:08 PM |
| For Sale burned mainboard Cyclops nova osd parts for sale or trade | rellik demanon | FPV/RPV - Equipment and Vehicles (FS/W) | 11 | Mar 09, 2012 08:13 PM |
