Joined Aug 2005
i think the current a little bit high. so if use over 500mW video transmitter i suggest use a small wire short circuit. |
Croatia
Joined Aug 2010
and it gives up to 1000mA (1A), voltage is stable even during launch (MAX motor amps), during flight, and at the end of flight when main battery is discharged, no oscillations in FPV voltage: http://tinyurl.com/storm12vpowersupply and not going through OSD, as V-in, CAM and VTX out is bridged in parallel. ![]() only the ground somewhere away was the issue. But thank you very much for founding a solution, now the OSD is really rock solid. Quote:
so you could try it. |
Joined Aug 2005
Beginning energized the moment the current will high |
Croatia
Joined Aug 2010
Good to know for the future pcb design ![]() did the 'wire mod' to my Nova too, just in case... ![]() storm osd is really best-buy with RTH and AP heading/alt lock modes + direct support from manufacturer ![]() ----------------------------------------------------------- EDIT: after doing the '3 wire' mod, I noticed the calibration routine works better! meaning the users that do have problems with acc calibrations or gyro drift... could try it too. before mod, I got error every first time it calibrated, only second time it did succed, video of it: http://tinyurl.com/cvu4zpb but with 3 wire mod, it works OK from first time. every time! |
Austin, TX
Joined Jan 2009
also, doing what you suggest will only calibrate the gyro to fly the plane tilted at 15 or more degrees since you cal'd it tilted that much.... something is wrong with the ACCs for them to be off by that much... |
Joined Aug 2005
Joined Nov 2012
I plan to use the single (1) battery setup using a 3cell battery. My Video TX is 400mW.
Question 1: Will my system be OK? Because my vTX is less than 600mW.. Or will I need to solder the extra wire as pictured in extralines diagram in post #692? Question 2: If we use a 2 battery setup and a VTX of 600+mW, do you still recommend soldering solution in post #692? |
Joined Aug 2005
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Nov 2011
few week back i was saying having video problem today tested it again this is the result
I have no idea why, vtx work fine when i bypassed the OSD, I even bought a new VTX still the same problem, previously i was using single battery setup, now even with separate battery for OSD/vtx it still occurring like in the video |
Croatia
Joined Aug 2010
OK, so if you don't have interferrence when video is bypassing OSD,
seems the noise from your esc is getting to your OSD somehow. there are at least 3 ways for it: - over 12V supply for OSD - over AMP sensor wires that go directly to OSD for voltage readout - over servo connectors (from ESC's BEC) how do you power your OSD? did you try to add some ferrite over amp sensor wires that go to OSD, or simply unplug it for test flight? did you try to unplug servo wires and fly manually from 'rx-servo' and observe interferrences? I've put ferrite cores on everything that gets into OSD, No interferrences of any kind even at full thottle, and before that I had a lot |
Joined Nov 2011
yeap to the extreme i have at least 7 ferrite ring in total in my plane i even use the sepic step up regulator for constant clean 12v for the board wierd thing is only happen after few min in flight reset the board all back to normal after few min started to distorted again
Croatia
Joined Aug 2010
you have step up regulator to power OSD board?
they are known to cause noise, because they are switching type, maybe you should try linear, they are 'RF clean'. (yes it is not as efficient, but the fpv current is not that high anyway, mostly <500mA) here it is more deeply explained, you can go with LM7812 VR, it works good, I fly with it. http://rcexplorer.se/blog/2012/08/tr...v2-6hv-update/ but if you use 2 batteries setup, why dont you just plug the second(3S lipo) to OSD PW in, and feed it(together with cam and vtx if they work on 12V) that way? you don't need any regulators that way and some other thing, did you do the '3 wire mod' on OSD? it fixes some voltage oscillations... maybe it could fix your problems too. |
| Thread Tools | |
| Help! CYCLOPS OSD 1.5 GPS problem. | grassiew | Video Piloting (FPV/RPV) | 2 | Apr 26, 2013 08:30 PM |
| Discussion Use the CYCLOPS NOVA OSD System Auto-return function | Rc Heli Halle | Multirotor Talk | 14 | Dec 22, 2012 07:08 PM |
| For Sale For sale Cyclops OSD NOVA | Schmoopiebunny | FPV/RPV - Equipment and Vehicles (FS/W) | 26 | Mar 26, 2012 10:18 PM |
| For Sale Cyclops Easy OSD V1.6 New In Package | stewtheman | FPV/RPV - Equipment and Vehicles (FS/W) | 4 | Mar 22, 2012 11:08 PM |
| For Sale burned mainboard Cyclops nova osd parts for sale or trade | rellik demanon | FPV/RPV - Equipment and Vehicles (FS/W) | 11 | Mar 09, 2012 08:13 PM |
