Espritmodel.com Heli Air
Old Oct 13, 2012, 01:50 PM
Out of sight, not out of mind
octane81's Avatar
Antarctica
Joined Oct 2010
its a good healthy nano tech ... totalt IR under 10
octane81 is offline Find More Posts by octane81
octane81's Avatar
Antarctica
Joined Oct 2010
Originally Posted by LUIS LOPEZ View Post
hi octane81, how did you conect the rssi cable? did you use a resistence between the osd and rx dragonlink?
connect only with ground + signal ... no need for resistor as DL have bufferd rssi output
Old Oct 13, 2012, 11:41 PM
living on air .....now :}
hpcoolahan's Avatar
Australia, NSW, Yamba
Joined Oct 2008
Octane , did you disconect everything from the board and pull out of the plane before you updated it , or did you do it in the plane with everything still conected???
Cheers
Patrick
hpcoolahan is offline Find More Posts by hpcoolahan
Old Oct 14, 2012, 07:00 AM
octane81's Avatar
Antarctica
Joined Oct 2010
I disconnected everything and took it out of the plane , just keep the power from current sensor. I needed to remove it from the plane because the OSD needs to be level and still for the update to be successful ... if not you will get a gyro error screen after you load the fw.
Old Oct 14, 2012, 10:30 AM
Thanks octane81 i will conect the rssi as you have conected.
LUIS LOPEZ is offline Find More Posts by LUIS LOPEZ
Old Oct 14, 2012, 12:13 PM
Joined Aug 2012
Has anyone else had any GPS dropouts, mine has failed in both flights today. Started fine, but after 5 or so mins started to drop out then home location went "elseware". Has 10" separation from Vtx, is that enough? What are the main causes of GPS dropout.
mawright89 is offline Find More Posts by mawright89
Old Oct 14, 2012, 12:19 PM
Joined Mar 2012
check out this video, it is long but if you watch it, his GPS also looses lock as well mid flight, perhaps this is the same person posting...
Storm OSD Testing Continues .........On My Bixler 1 Test Plane. (21 min 35 sec)
mrracer98 is offline Find More Posts by mrracer98
Old Oct 14, 2012, 01:45 PM
Joined Aug 2012
nope, not me but similar problem. What do we recon, proximity to Vtx, cable connection or send it back?
mine came with on of the components loose on the rear of the board but still connected by the tracks so I made sure it wouldn't come off by putting a little servo tape under it, would that void warranty as I didn't return immediately?
Old Oct 14, 2012, 02:46 PM
Joined Mar 2012
Take pic of it and post... was it the main board or GPS module? Perhaps it has something to do with it...
Old Oct 14, 2012, 03:23 PM
Joined Aug 2012
It is the underside of the main board. A black cylindrical component which seems to have a coil of wire in it. don't have a camera just the moment, but will try and find a way asap.
Old Oct 15, 2012, 10:13 PM
Joined Oct 2012
does anybody wants to take pics of how they mounted their storm osd on theyre planes ? i have one and trying to figure out the best way to mount it and balance it on my skywalker. thanks alot. also how do you connect to get an rssi value ? thanks again.
ls1elite is offline Find More Posts by ls1elite
Old Oct 15, 2012, 10:16 PM
Joined Oct 2012
and i know this is out of topic but for those having problems with theyre control boards that the "ok" button does not work , i just fixed mines . all one needs to do is flip the storm osd over and check that there are no sodder between the pins on the osd . the pins are the ones where the control board connects to on the storm osd board. so they are going to be on the storm osd board. i simply carefully removed the sodder beteween the pins. and now it works perfect. note: i will not be responsible if one damages theyre storm osd , try this at youre own risk. im simply putting this out there to help others since bevrc dosent have any type of customer support.
Old Oct 16, 2012, 10:54 AM
octane81's Avatar
Antarctica
Joined Oct 2010
rssi .. connect only signal and ground .. then setup max and min in osd menu , for min you need to turn off your radio before clicking ok
Old Oct 17, 2012, 09:14 AM
Joined Mar 2012
So I got my storm. Everything works from a QC standpoint. It does function appropriately as well but my mechanical centers on my control surfaces are off quite a bit. Also what is the appropriate sequence of setting this up... This is my first AP.
Heres what I did:
1)reset gyro while plane is level.
2)adjust pitch and roll trims.
3)fly model trimmed out
4)center servos in menu
It seemed to have issues sometimes related to altitude while on RTH as did octane's video... I dont know if the barometer sensor has too much airflow within the cabin of the plane or not enough? Perhaps it is all due to the fact my plane is so out of trim.... I believe the CG is off as well as it flies with an upward angle to maintain altitude, It is a skywalker and I have had troubles with it often... I am going to build a new bixler and put this in it. I am used to those aircraft and have flown them for years... I am guessing it will work much better...
Looking over the video. In heading and altitude lock mode it functions perfectly. I just have to get my mechanical trims set and parameters for gain and pitch.... should work good....
Old Oct 17, 2012, 09:26 AM
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Heres what I did:
It seemed to have issues sometimes related to altitude while on RTH as did octane's video... I dont know if the barometer sensor has too much airflow within the cabin of the plane or not enough? Perhaps it is all due to the fact my plane is so out of trim.... i dont know
It could be too much, but very unlikely to not be enough airflow unless you have it sealed in a plastic bag. I dont have the Storm, but I taped a piece sponge over my DOSD baro to dampen out the airflow.
Most likely you need to get the plane mechanically trimmed with small control throws.
Post a video to show your issue so we know what your talking about. I don't remember Octane's issue, I thought he was just flying around terrain lower than launch altitude.
iskess is online now Find More Posts by iskess
Help! CYCLOPS OSD 1.5 GPS problem. grassiew Video Piloting (FPV/RPV) 2 Apr 26, 2013 08:30 PM
Discussion Use the CYCLOPS NOVA OSD System Auto-return function Rc Heli Halle Multirotor Talk 14 Dec 22, 2012 07:08 PM
For Sale For sale Cyclops OSD NOVA Schmoopiebunny FPV/RPV - Equipment and Vehicles (FS/W) 26 Mar 26, 2012 10:18 PM
For Sale Cyclops Easy OSD V1.6 New In Package stewtheman FPV/RPV - Equipment and Vehicles (FS/W) 4 Mar 22, 2012 11:08 PM
For Sale burned mainboard Cyclops nova osd parts for sale or trade rellik demanon FPV/RPV - Equipment and Vehicles (FS/W) 11 Mar 09, 2012 08:13 PM
