what is the USB device for Firmware update?
If you download the v.1.02 firmware from http://www.bevrc.com/download/STORM%...%20upgrade.zip it describes how to install the firmware. It has a driver for what looks like a special USB device that connects to 4 pin holes on the main OSD board. See the attached pic. Does anyone know where to get this board? I have one of these USBasp devices from HobbyKing. I wonder if it could be wired to work with this. Anyone know?
Here is a pic: ![]() I still want to know if the USBasp device from HobbyKing can be used to flash it. Anyone know? ![]() The HK device has 10 pins, with a 6-pin adapter. The Storm OSD only has 4 pin holes shown for upgrade. Perhaps there is a way to connect these? |
Everything seems to be working well. Nice job Yang. If I may nitpick a little, I have some suggestions. I find the altitude and speed ladders useless and a waste of space. They should work like the compass does, where the compass headings move along with the scale. All heads up displays show the numbers moving along the ladder so the scale has some meaning. Seeing little white hash marks move alone doesn't really tell me anything. See the attached examples so that you no what I mean. My issue with the simple display screen is that flashing H for home. I find the flashing very distracting, and should be used only for warnings like low battery or low RSSI. Is there another way to indicate that Home is behind other than flashing? Maybe a different symbol? I think you should just have a home arrow on the simple display, no compass needed. I hope you will continue to take suggestions and make this great OSD even better. Thank you. |
I did some tests today , can someone explain these test results?
Why does osd and watt meter show that a 2200mAh battery is empty at only about 1527mAh? I stopped the test at 1527mAh , because the voltage dropped very fast under 10v, and I didnt want to destroy it. OSD and watt meter show same result .. Im ![]() ![]() ![]()
Joined Mar 2012
You put in more than you discharged because the balancer over feeds and wastes off mAh to acheive a full charge. I never have, but perhaps you could discharge around 1500 mAh again and then do a straight no balance charge and see what you get (seems pretty hard on your batts though/borderline dangerous). maybe it will be closer to the amt discharged if you dont balance it... Again I have never tried it.... |
Joined Mar 2012
i got theorys but i am sure electrical engineer knows something on here we dont. Id venture to guess it has something to do with the way the charger reads vs what the put into the battery's gotta be different...
| Thread Tools | |
| Help! CYCLOPS OSD 1.5 GPS problem. | grassiew | Video Piloting (FPV/RPV) | 2 | Apr 26, 2013 08:30 PM |
| Discussion Use the CYCLOPS NOVA OSD System Auto-return function | Rc Heli Halle | Multirotor Talk | 14 | Dec 22, 2012 07:08 PM |
| For Sale For sale Cyclops OSD NOVA | Schmoopiebunny | FPV/RPV - Equipment and Vehicles (FS/W) | 26 | Mar 26, 2012 10:18 PM |
| For Sale Cyclops Easy OSD V1.6 New In Package | stewtheman | FPV/RPV - Equipment and Vehicles (FS/W) | 4 | Mar 22, 2012 11:08 PM |
| For Sale burned mainboard Cyclops nova osd parts for sale or trade | rellik demanon | FPV/RPV - Equipment and Vehicles (FS/W) | 11 | Mar 09, 2012 08:13 PM |
