Old Aug 26, 2012, 08:19 AM
dbdukeboy is online now
Find More Posts by dbdukeboy
Newbe learning everyday!
dbdukeboy's Avatar
United States, OH, Parma Heights
Joined Aug 2012
Can I boost up my champs power
Im new to the hobby and love flying my micros,but when it is a little windy I will only fly my champ. I just wanted to know if I could safely put a motor from my t- 28 or polecat on the champ. I know the gear boxes are the same for all 3.
dbdukeboy is online now Find More Posts by dbdukeboy
Old Aug 26, 2012, 08:43 AM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
For best power, get a Nine Eagles Bravo SX motor. Only catch, it comes with a different pinion and motor connector, but with a little handy work both things can be fixed. Combined with a decent 240 mAh battery I understand you can make it climb vertically.
SoloProFan is online now Find More Posts by SoloProFan
Old Aug 26, 2012, 11:54 AM
Felt_ripper 23 is offline
Find More Posts by Felt_ripper 23
Dude, get me some ice cream!
Felt_ripper 23's Avatar
United States, MA, Amherst
Joined Apr 2012
The champ and t 28 have the same motor. The polecat motor is stronger, 'cause its coreless.
Felt_ripper 23 is offline Find More Posts by Felt_ripper 23
Old Aug 26, 2012, 12:14 PM
dbdukeboy's Avatar
Joined Aug 2012
But if I put a polecat motor in will it fry my receiver
Old Aug 26, 2012, 04:46 PM
Tim Wolff is online now
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
The Polecat motor will do just fine in the champ. The Gearbox and prop are the same in both the Champ and Polecat.
Also use a lightweight and quality battery like a 160 mA Thunder Power or Hyperion cell.
Tim Wolff is online now Find More Posts by Tim Wolff
Old Aug 26, 2012, 05:46 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
The Champ also has a coreless motor. You are probably thinking of brushless, a type of motor that usually has more power than those with brushes. But you can't just connect a brushless motor to a speedcontroller for brushed motors. Brushless speed controllers have 3 wires between motor and speedcontroller, and works quite differently. You can't test a brushless motor with just connecting it with a battery, for instance, it can't run without it's dedicated speed controller.
The stronger motor will not burn your Champ brick. Quite a few pilots have been using stronger motors on a stock Champ without any issues. Sure, you can't fit any size motor, you can overload the brick, but with those 8 mm motors there is no risk.
Old Aug 27, 2012, 06:58 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
uhhhh, no. All of the HH 8.4mm and 6mm are "coreless".
The Polecat and T-28 motors are identical spec (black bell), only the wire length is different. The Champ motor is Weaker (translucent white bell) and is the same spec as the orignal Sukhoi.
This higher powered motor is known as the "Mustang Motor" because the Mustang was the first application of the Black Belled motor.
UNGN is offline Find More Posts by UNGN
Old Aug 27, 2012, 12:21 PM
dbdukeboy's Avatar
Joined Aug 2012
Thanks for all the tips, now is it worth doing?
Old Aug 27, 2012, 04:08 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
A mustang motor will swap in with no mods. It will give better performance, but needs better batteries to make full thrust. Batteries that may work OK with the champ motor can choke on the Mustang motor.
Old Aug 27, 2012, 04:13 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
For people who think the Champ is just fine the way it is, no it's probably not worth doing.
For people who would like more power ( such as yourself) then yes it's probably worth doing.
But why stop there, if you go for a stronger motor you might as well get some quality batteries and even a GWS 5043 prop to try.
TODD
Yep I got some slow fingers. ^^^^^
I R Irv is offline Find More Posts by I R Irv
Old Aug 29, 2012, 11:30 AM
NEWBEFLYER is offline
Find More Posts by NEWBEFLYER
Crazy Canuck
NEWBEFLYER's Avatar
United States, VA, Woodbridge
Joined Apr 2007
My little Champ is beefed up with the Mustang motor and the 5043 prop and I have one of Jin's floats and boy does she "hop" in the air. I can do loops with her and some real funny barrel rolls. The Mustang motor greatly improves the flight envelope of the Champ.
NEWBEFLYER is offline Find More Posts by NEWBEFLYER
Old Aug 30, 2012, 04:21 AM
KaiWE is offline
Find More Posts by KaiWE
Low'n Slow is safest, right?
KaiWE's Avatar
Norge, Østfold, Fredrikstad
Joined Jun 2011
I have one Champ with the original motor and one with the Mustang-motor. My 11-year old son always call dibs on the one with the Mustang-motor, he claims that the other one is no fun in comparison
He loves to hand launch it vertically:
Felix (1 min 38 sec)
(This one is not one he's particularly proud of, was to windy, but thr only one I have on video )
KaiWE is offline Find More Posts by KaiWE
Old Oct 03, 2012, 02:55 PM
alset is offline
Find More Posts by alset
Gunbarrel, CO
Joined Dec 2006
Hmm... I bought a Champ fuselage with electronics and swapped the brick out for a 6400. I then put the Champ brick into a scratch built with a P-51 motor. I am using a 250mAh battery. What happens is the the motor cuts out even at half throttle, and sometimes won't restart. I've tried different p-51 motors. Same result. Can I assume that the brick is bad? elevator and rudder work OK. Thanks for any advice.
alset is offline Find More Posts by alset
Old Oct 03, 2012, 03:16 PM
alset is offline
Gunbarrel, CO
Joined Dec 2006
Well I just now plugged the Champ motor into the Champ brick and it works fine - no cutting out. My assumption is that the brick can't handle the 1.6 amps the P-51 needs - or the brick doesn't meet specs, but can just handle the Champ motor.
Old Oct 03, 2012, 04:10 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Could be the batteries. Even 250 batteries have to be in good shape to run a mustang motor.
Off brand, old or 12C batteries won't cut it
Question Can I run my KK2 board & ESC's off my Bench Power Supply? AcroFPV Multirotor Electronics 18 Aug 16, 2012 12:44 PM
Question How Can I Hook Up the Included Nav Lights On my Plane? ClevelandBaller Electric Plane Talk 11 Aug 13, 2012 10:49 PM
Help! Can I bind any receiver to my hz champ transmitter VuzeDroid Electric Plane Talk 1 Jul 13, 2012 12:16 AM
FAQ How can I set up my HoverFly GPS??? SebastianDns Hoverfly Technologies 1 May 06, 2012 01:23 PM
My E Boomerang needs a power boost any suggestions on motors Joe Elston Electric Plane Talk 0 Jul 24, 2001 06:37 PM
