Old Aug 26, 2012, 06:37 AM
solars is offline
Find More Posts by solars
Dornbirn / Austria
Joined Mar 2008
How to optimize for duration?
Hi there,
I'm very impressed by the 'long duration' quad threads and videos. For a photo/video project, I want a quad with an optimized flight time (no acrobatics or any kind of excessive reserves).
I wondered how, in general, the experts here start with the target platform and this goal in mind and keep adding components? I had a look at the multicopter calculator and am curious about how you teak it
I would guess:
1. Build the frame + components as light as possible (base)
2. Find low KV motors
3. Fill up the remaining payload with lipos until hover efficiency is near to optimum efficiency?
I'm curious how you would do this..
solars is offline Find More Posts by solars
Old Aug 26, 2012, 07:23 AM
hamburger is online now
Find More Posts by hamburger
Hamburger
hamburger's Avatar
Joined Jan 2010
Selec motors with only minimal excessive power beyond copter weoght. Aim for 2 to 1 ratio or even 1.5 to 1.
hamburger is online now Find More Posts by hamburger
Old Aug 26, 2012, 07:24 AM
Hamburger
hamburger's Avatar
Joined Jan 2010
Use large diameter blades woth low pitch
Old Aug 26, 2012, 12:05 PM
solars is offline
Dornbirn / Austria
Joined Mar 2008
how would you calculate this? based on what?
Old Aug 26, 2012, 12:22 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
Once you go below 2:1 the coptor becomes difficult to control but the lower the ratio the longer the flight time. If you are going to actually fly it rather than hover stay with no lower than 2:1. Experience and testing has shown the above to be true and ecalc seems to back it up.
pug398 is offline Find More Posts by pug398
Old Aug 26, 2012, 12:41 PM
TS00 is offline
Find More Posts by TS00
Ape-pilot Extraordinaire
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
+1 for the thrust/weight ratio. This is because these motors have peak efficiency at ~85% of their max power output. So you need to be running close to that most of the flight to get long durations.
TS00 is offline Find More Posts by TS00
Old Aug 26, 2012, 12:45 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
No calculate, estimate.
Every motor page has somewhere a manufacturer notes, like: prop 11x5, 1000 grams thrust, this is supposed at full throttle
Assuming you can trust this... because usually the prop type is not specified, assume APC, then you do some math... if one motor thrust is 1000 grams, then 2 motors will hover 2000 grams, at full throttle, so 4 motors will hover 2000 grams at half throttle. This is 2:1 rule.
However, for high efficiency, the 50% area in a typical motor diagram is not the best where to hover, the 25-40% area is where a BL motor tops its efficiency. See graph bellow for better understanding, the red plot.
The graph above is valid for ANY brushless motor, any brand, power, and kv.
renatoa is online now Find More Posts by renatoa
Old Aug 26, 2012, 12:46 PM
Joined Sep 2007
85% ?!!! lol
Based on what ?
Old Aug 26, 2012, 12:48 PM
TS00 is offline
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
Originally Posted by RENATOA View Post
85% ?!!! lol
Based on what ?
On about a zillion graphs that people pointed me at when I asked a similar question on the motors subforum.
I don't claim divine knowledge here, so please feel free to correct me.
Old Aug 26, 2012, 12:51 PM
TS00 is offline
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
You're suggesting peak efficiency is at 25% - 40% what - power or rpm? It doesn't match up with other graphs I've seen, and it doesn't match my experience of using different power motors on the same frame.
Old Aug 26, 2012, 12:55 PM
Joined Sep 2007
Please, post link to such graph.
The above can be seen in any manufacturer page who post this diagram, and also any propulsion calculator (ecalc) draws something similar.
You have on that graph power, rpm, and Amp. The last is the X axis, and this graphs are drawn usually versus Amp.
Other interesting article on this subject, based on similar shaped graphs:
http://diydrones.com/profiles/blogs/motor-efficiency
Old Aug 26, 2012, 01:02 PM
solars is offline
Dornbirn / Austria
Joined Mar 2008
TS00 is it possible that you are confusing the values? usually ~85% is the actual efficiency given by the calculators, e.g. if you use: http://www.ecalc.ch/xcoptercalc_e.htm
I think renatoa is referring to _where_ this peak is, e.g. at 25% of power if I understand right
if I think right, the goal is, to get the efficiency in motor @ hover as close to the optimum efficiency in this calculator, by doing what renatoa suggests. then you are hovering as efficient as possible.
@Renatoa, thanks for the explanation - you are right, either the motor is in the database, or it is missing and the description does not list all the necessary values this is a bit of a pain
Old Aug 26, 2012, 01:06 PM
TS00 is offline
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
I think the confusion stems from the fact that you can plot efficiency against any one of a number of variables. The graph you posted shows efficiency v. current, with a peak between 30-50%.
This graph shows efficiency v. rmp:
The peak is much later.
Same here:
Old Aug 26, 2012, 01:10 PM
pug398 is offline
VA
Joined Nov 2009
don't worry about it guys. With his first post sounds like he is on the right track and he will see for himself what the efficiency range is for different motors as it is usually listed. ecalc will also simulate all of that for him. First thing is to guesstimate coptor weight and then juggle motors, props and battery from there while at the same time recalculating weight based on new config. 30 minutes should be a good target.
Old Aug 26, 2012, 01:19 PM
solars is offline
Dornbirn / Austria
Joined Mar 2008
don't stop them from contributing!
