Old Aug 26, 2012, 06:36 AM
Nīmā is offline
Find More Posts by Nīmā
No ceiling for my altitude
Nīmā's Avatar
Iran, Tehran
Joined Dec 2009
Composite :: Epoxy Resin or Polyester Resin
Hi all.
In this thread, I want to get some information from you modelers and UAS designers.
For beginning ...
In your opinion ...
Which one is better for a simple drone with these specifications:
Fuselage length: 1200 mm
Wingspan: 2400 mm
Characteristic distance: 250 mm
Payloads: Just common UAV tools like OSD, AP, FPV and ... .
Just a simple drone, but with less MTOW ...
Epoxy Resin or Polyester Resin ?
Nīmā is offline Find More Posts by Nīmā
Old Aug 26, 2012, 09:15 AM
alex.mc is offline
Find More Posts by alex.mc
Joined Dec 2005
If you can obtain good quality Epoxy resin systems, then use them. Polyester is giving way to Vinylester, but they are still inferior to Epoxy systems for aviation use currently.
alex.mc is offline Find More Posts by alex.mc
Old Aug 26, 2012, 12:09 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
The decision can depend on the capabilities of your shop and glass transition (Tg) requirements of your resin. The main advantage of a vinyl ester resin is that the resin can reach a Tg of 180 to 200*F with a room temperature cure. It is quite easy to get certain epoxy resins to reach that same Tg but you will have to heat cure the layup in some kind of oven. If the Tg isn't that important then you can use a room temp cured epoxy and have good results as it while be tougher.
wyowindworks is offline Find More Posts by wyowindworks
Old Aug 26, 2012, 12:44 PM
jirvin_4505 is offline
Find More Posts by jirvin_4505
working to the closest cm
jirvin_4505's Avatar
brisbane australia
Joined Nov 2002
Originally Posted by Nīmā View Post
Hi all.
For beginning ...
In your opinion ...
Wingspan: 2400 mm
How simple a drone???
Buy a ready made foamy.
How many do you want to make?
What is MTOW?
Where do you want to use the epoxy or polyester?
I don't fully understand the question.
Cheers Jeff
jirvin_4505 is offline Find More Posts by jirvin_4505
Old Aug 27, 2012, 02:34 AM
Nīmā is offline
Nīmā's Avatar
Iran, Tehran
Joined Dec 2009
Thank you for your guidance.
It was useful for beginning!
Originally Posted by jirvin_4505 View Post
1. How simple a drone???
2. How many do you want to make?
3. What is MTOW?
4. Where do you want to use the epoxy or polyester?
Cheers Jeff
1. I have my own design!
2. Just one for preliminary flight tests
3. MTOW=Wto=Weight=Maximum Take Off Weight
I want a composite with less weight.
4. At home! I have a place just for my r/c projects at my home.
Question Polyester resin or Epoxy deefman Dock Talk 2 Oct 15, 2007 05:21 PM
Epoxy or Polyester resin?? spitfirem9 Slope 6 Mar 02, 2005 01:56 AM
