Old Aug 30, 2012, 03:10 PM
Joined Mar 2008
Originally Posted by SAB View Post
All the info I've seen on this motor show it using 6S batteries.
Here's the Google translated Hacker link:
http://translate.google.com/translat...p%3D32&act=url
Steve
I am going to order one Mythos 125.
I have been looking fo info about a60-6xs and the only websites that I found about running this brusless in 8s wer:
http://www.adchobbystore.com/3DHS-72...-V3_p_339.html
http://www.adchobbystore.com/Hacker-...tor_p_627.html
I think this would be a good option because you can updat eto (s.
rquinones is offline Find More Posts by rquinones
Old Aug 30, 2012, 08:03 PM
DFC~ We Do Flyin' Right
bsbauman's Avatar
USA, GA, Atlanta
Joined Nov 2008
This has been painful reading this thread... I am on the fence and want one SO bad, but I have also wanted a 2m Vanquish for some time as well.
I just cannot figure out where to put my money
bsbauman is offline Find More Posts by bsbauman
Latest blog entry: Burned Retina Shorts
Old Aug 30, 2012, 08:42 PM
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Originally Posted by redfly05 View Post
Hello Guys, this is my first post!
Congratulations to the discussion, it is very interesting!
I have the first configuration recommended by Sebart (Hacker A60 6XS, ESC Hacker Spin 125, Xoar 20x13 prop, Zippy 5000 30C) and waiting for the Mythos125 I tried it on a Funtana X100 (4700gr).
I tried a flight pattern of 8 minutes and both power consumption seemed to me good. In the end I had a remaining battery by about 21%.
Is this a 6S or 8S setup (I am assuming 6S)? I like the numbers, very promising...
Jack
jfetter is offline Find More Posts by jfetter
Old Aug 30, 2012, 08:48 PM
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Originally Posted by Koosie View Post
Hi,
Not 100% sure about 8S for the A60-6XS, I am having a tough time finding an actual specification on the motor or a proper manual.
Is 8S too much for it?
Yes, I think 8S is too much. The motor kV is 370, so if you go 8S and you factor a 10% voltage drop, that's 30.24 volts. So the motor RPM (unloaded) would be 11,188, that's very high for an 18" or 20" prop...
Jack
Old Aug 30, 2012, 08:50 PM
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Just try and hang on for another week, wait for some video and make an informed decision my friend (unlike me!) ;-)
Jack
Old Aug 31, 2012, 01:37 AM
Joined Aug 2012
Jack
Hi Jack,
my setup is 6S!
Now I will continue testing with my new battery pack: GensAce 5300mAh 6S 30C!
See you!
Sergio
redfly05 is offline Find More Posts by redfly05
Old Aug 31, 2012, 01:50 AM
KE your cub.
Curare's Avatar
in the gutter, again....
Joined Jun 2005
Well guys I just went and picked up mine, boy what a fuselage, it looks waaay bigger than my windS 110.
Now, back to the motor issue. Putting everything together the clearance required between the back of the spinner and the firewall (total motor length) is 79-80mm. This is great if you're using the 5XS and 6s, but I already have a stack of 6s stuff, which I'd like to continue to use. THis really limits engine choice for good efficency. I'm not sure I like the idea of running a 6XS on 8s swinging a 18x8 to keep the amps down, but unless theres another motor, around 250KV that'll fit I don't know what I can do.
Curare is offline Find More Posts by Curare
Old Aug 31, 2012, 04:43 AM
Joined Mar 2008
I I have been doing research in order to see the brushless options.
i used the Flight calculator from CastleCreations that its quite realistics, I check it with Castle bec and Hacker Brushless in my Winds 110 and the results were much the same as real ones.
What I could see is that Hacker Brushless 6XS is not for 8s, I think
Old Aug 31, 2012, 05:57 AM
KE your cub.
Curare's Avatar
Joined Jun 2005
That confirms my suspicions.
I'm thinking of fitting an AXI 5325/18 or 20 in there for some zing. Thoughts?
Old Aug 31, 2012, 07:04 AM
Joined Mar 2008
Less power than hacker A60-6XS running on 6S
Axi power limits 80-85A
Old Aug 31, 2012, 09:54 AM
KE your cub.
Curare's Avatar
Joined Jun 2005
I'm slowly changing my mind to 6s...
very slowly...
Old Aug 31, 2012, 10:04 AM
SAB
United States, NY, Watervliet
Joined Jan 2007
As I mentioned previously in this thread the Motrofly 5320-300 (from Subsonic Planes) might be a good option for 8S, quite a short motor, only 15g more than the Hacker XS & rated at 2800W on 8S (APCe 20x10). I've not used this motor myself but a buddy has one in a Slick 71" running 8S & getting 2400W (on a 20x8 I think) & is very happy with it.
Steve
SAB is offline Find More Posts by SAB
Old Aug 31, 2012, 10:05 AM
media, pennsylvania, united states
Joined Aug 2006
very slowly...
Why?
luckymacy is offline Find More Posts by luckymacy
Old Aug 31, 2012, 11:03 AM
United States, MI, Saginaw Charter Township
Joined Feb 2007
Prop clearance with a 20 inch prop is 3 1/2 inches on the wheels. Checked last night.
RCBRUSKI65 is offline Find More Posts by RCBRUSKI65
Old Aug 31, 2012, 11:19 AM
Joined Mar 2008
This are my winds 110 settings. I hace check them with my castle esc data log and are quite precise.
Zippy 4500 8s 25c
Hacker A50-16l
Castle ice 100
Apc 18x10
Total weight = 4.400grams
Static thrust 7182g
Motor power 1512w
Rev 6922
Build Log Turnigy (TECHone) Mythos Build Thread The_Mongrel Australia 13 Feb 13, 2013 07:59 PM
Build Log SebArt Sukhoi 29S 140E Build Thread... jfetter 3D Flying 436 Jan 01, 2013 04:06 PM
For Sale NEW SebArt Mytho S 125E FREE SHIPPING DiscountLipos Aircraft - Electric - Airplanes (FS/W) 9 Aug 29, 2012 05:00 PM
Mini-Review New Sebart KatanaS 30e - Build Thread/Mini-Review Bill K. 3D Flying 1063 Oct 24, 2011 10:59 AM
Mini-Review New SebArt KatanaS 50E - Build Thread/Mini Review Bill K. Sport Planes 334 Oct 04, 2010 03:44 AM
