Old Feb 12, 2013, 10:25 AM
jfetter is offline
Find More Posts by jfetter
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Originally Posted by Curare View Post
I'm getting that feeling
Gas?
jfetter is offline Find More Posts by jfetter
Old Feb 12, 2013, 08:10 PM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
Haha!
Curare is offline Find More Posts by Curare
Old Feb 13, 2013, 04:23 AM
gibbo9000 is offline
Find More Posts by gibbo9000
Joined Oct 2012
The other quite competitive option with the A60 6XS is 8s 5,800mah (I used Zippy Compact 25c), a 19 x 8 prop, and throttle curve dialled back to limit current/power to around 2,500 Watts. It is at the high end of rev range so I found prop choice critical - I liked PT Carbon or Xoar Beech good. - Gibbo
gibbo9000 is offline Find More Posts by gibbo9000
Old Feb 13, 2013, 07:58 PM
Curare is offline
KE your cub.
Curare's Avatar
Joined Jun 2005
Yeah, I saw that you'd done that, doesn't fill me with joy though.
Seriously considering buying a A60-7XS and going for 8S with a 20x11 or something.
Old Feb 14, 2013, 03:58 AM
Joined Oct 2012
Sentiment shared - which is why I went to 300kv Motrolfly instead . . . . (pre Hacker 7S)
Old Feb 14, 2013, 04:28 PM
Curare is offline
KE your cub.
Curare's Avatar
Joined Jun 2005
I probably would have done the same, but now that the 7xs is around, I might go for it.
*phones modelflight*
Old Feb 17, 2013, 03:56 AM
Dan 73 is offline
Find More Posts by Dan 73
Joined Oct 2011
Hello, owners Mytho S.
I bought the Lindinger.at one rcmodel Mytho S 125 E.
It came very well packed and in good condition.
I weighed all the components and weighs about 2665 grams.
I think I'll feed 8-9 cell battery and will put this engine;
http://www.hobbyking.com/hobbyking/s..._10_Glow_.html
What do you have?
The ruder servo think I will mount the tail fuselage for better balancing plane and being closer to ruder I will have more precise control.
You where you mounted servo ruder?
Excuse my english difficult.
Dan 73 is offline Find More Posts by Dan 73
Old Feb 17, 2013, 05:23 AM
bossee is offline
Find More Posts by bossee
Bo Edström, Sweden
Joined Jan 2009
Hi,
That Hobbyking motor does not cost much for sure. How good it actually is I have no knowledge of. But it's specification to be able to handle max 60 amp maybe will be to low I think but it depend what prop you will use.
I have a MythoS 125E myself and I will use a Hacker A60-7XS motor:
http://www.hacker-motor-shop.com/e-v...&t=3&c=32&p=32
I will use 8 cells.
I will mount my rudderservo in the tail for short connection to the rudder. The balance for proper Center of Gravity will probably be no problem despite rudderservo in the tail. There is plenty of room to move the LiPo battery forward if needed.
I will use Futaba S9551 (at 6 volt) digital servo that I already have or maybe a Futaba BLS551 (at 6 volt) servo for rudder servo.
For elevator servos and aileron servod I will use Futaba BLS153 since I have them already and thay will be enough for this plane.
ESC I have not decided 100% yet but maybe a Hacker MasterMezon without BEC.
For receiver battery I will use a Futaba FPFR2F1800 (1800 mAh) LiFe (2 cell 6.6 volt) 105 gram.
/Bo
bossee is offline Find More Posts by bossee
Old Mar 11, 2013, 02:39 PM
Den24 is offline
Find More Posts by Den24
Joined Mar 2013
Hello, all greetings from Russia! Colleagues who from you tried the A60-7xs motor on MythoS 125E? It would be desirable to learn your opinion. Thanks in advance. (excuse for my English).
Den24 is offline Find More Posts by Den24
Old Apr 15, 2013, 01:51 PM
Nikola84 is offline
Find More Posts by Nikola84
just fly
Nikola84's Avatar
Serbia
Joined Oct 2006
Hi folks,
I really like this plane. What are you think about C50-13XL in this plane? Does can fit with prop 21x13?
Does anyone tried this?
Nikola
Nikola84 is offline Find More Posts by Nikola84
Old Apr 15, 2013, 02:11 PM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Originally Posted by Nikola84 View Post
Hi folks,
Nikola
There is no room for the traditional Hacker geared in-runners unless you do significant mods...
Jack
Old May 10, 2013, 03:11 PM
Dan 73 is offline
Joined Oct 2011
Hi, guys.
I finished my model assembled Mytho S 125 E.
We have already made five flights.
I fly with batteries 10 s
Since I have not made ​​a general impression, and there are satisfied.
I start training for F3A-P13 program.
Old May 16, 2013, 08:42 PM
TN Walker is offline
Find More Posts by TN Walker
Joined Dec 2012
I'm looking for some current feedback on the Mythos 125e from a pattern flyer that is running a10s set-up. Also would like to know the capacity of the packs he is using and whether it has been enough capacity to fly for approx 7-7 1/2 minutes and which motor and esc he is using. I am looking for a capable practice plane that can be used to fly Masters. Thanks, TN Walker
TN Walker is offline Find More Posts by TN Walker
Old May 16, 2013, 08:51 PM
Joined Dec 2012
Also, if anyone bought their Mythos 125E from Discountlipos, what was their experience with this companies sales and service, etc? Thanks again.........
Old May 23, 2013, 04:08 PM
SAB is offline
SAB
Find More Posts by SAB
SAB
United Kingdom, Inverclyde
Joined Jan 2007
Had a few flights on my Mythos, running 8S 5000 packs with Hacker A60-5S
My main concern is the pull to canopy in KE - both sides. This is usualy indicative of too forward a CG but I've put the CG as far back as I can (about the rearmost position - 220mm from LE) & it still shows. Can't go any further back as my motor is over 100g heavier than the XS motor plus my batteries are heavier (vs. a 6S set-up). I need about a 10% R-E mix to rid the KE canopy pull which is more than I would wish. I'm carying only slight up elevator trim (2 clicks).
Jack F. I note in an earlier post that you needed 15% to fix the same issue.
So what has everone else done with the CG & the need for KE mixing, thanks.
Steve
SAB is offline Find More Posts by SAB
Mini-Review New Sebart KatanaS 30e - Build Thread/Mini-Review Bill K. 3D Flying 1097 Nov 22, 2015 04:22 PM
Build Log SebArt Sukhoi 29S 140E Build Thread... jfetter 3D Flying 438 Mar 31, 2014 11:31 PM
Build Log Turnigy (TECHone) Mythos Build Thread The_Mongrel Australia 13 Feb 13, 2013 07:59 PM
For Sale NEW SebArt Mytho S 125E FREE SHIPPING DiscountLipos Aircraft - Electric - Airplanes (FS/W) 9 Aug 29, 2012 05:00 PM
Mini-Review New SebArt KatanaS 50E - Build Thread/Mini Review Bill K. Sport Planes 334 Oct 04, 2010 03:44 AM
