Old Nov 07, 2012, 12:16 PM
**neons** is offline
Find More Posts by **neons**
5,200 Led Lighted Bike-Bob P.
**neons**'s Avatar
USA, MA, Swansea
Joined Mar 2003
Yikes, that is some wood for the start. I'll bet there will be many more sheets of wood also. Different thicknesses too. I guess it will need some bank account for all of it. These plans are the best I have seen. This is going to be some darn good build.
**Neons** Bob
**neons** is offline Find More Posts by **neons**
Old Nov 07, 2012, 12:17 PM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
http://www.hobby-lobby.com/scale_adj...ps_374_ctg.htm
^ scale props ^
warhead_71 is offline Find More Posts by warhead_71
Old Nov 07, 2012, 12:41 PM
cracksmeup is offline
Find More Posts by cracksmeup
cracksmeup's Avatar
United States, IL, Joliet
Joined Jun 2009
Wow that stick framing was fast Bart ,glad to see thos nice parts arrive . joe
cracksmeup is offline Find More Posts by cracksmeup
Old Nov 07, 2012, 05:01 PM
Bart83 is online now
Find More Posts by Bart83
71% of the world is runway . .
Bart83's Avatar
Nederland, ZH, Oostvoorne
Joined Jun 2009
Thanks everyone,
Some progress tonight , funny how you can assamble the different sub assamblies like lego without glue. Photo's of my progress.
Cheers,
Bart
Description: Name: S23 (41).jpg
Description: Name: S23 (43).jpg
Description:
Description: Name: S23 (44).jpg
Description: Name: S23 (45).jpg
Description:
Description: Name: S23 (47).jpg
Description:
Bart83 is online now Find More Posts by Bart83
Old Nov 08, 2012, 12:50 AM
wallis_100 is offline
Find More Posts by wallis_100
build like there is no 2moz
wallis_100's Avatar
United Kingdom, England, Bristol
Joined Apr 2009
Bart,
that is some very good CAD work, and i'm impressed by your 'skellington' approach to the hull bottom. very reminiscent of the full size, yet distinctivly ivan (and quick to build by the looks of it)
I'll be watching this like a hawk
scott
wallis_100 is offline Find More Posts by wallis_100
Old Nov 08, 2012, 01:56 PM
flyyyer is offline
Find More Posts by flyyyer
Guntalingen, Switzerland
Joined Sep 2004
Very nice! Now that RBC has cut one already, any chance for a short kit once it flies as well as it looks?
Lorenz
flyyyer is offline Find More Posts by flyyyer
Old Nov 08, 2012, 03:00 PM
Bart83's Avatar
Joined Jun 2009
Lorenz
RBC has cut 2 sets , PaulM here n RcGroups is building the second prototype.
When the 2 boats are completed and had a succesfull maiden and i have made some fine adjustments to my desing i plan to make the plans available.
Keep following this thread and you''ll notice when
Cheers,
Bart
Old Nov 09, 2012, 04:46 AM
Bart83's Avatar
Joined Jun 2009
And on with the hull . . . .and made a photo of some of the tools i use.
Cheers,
Bart
Description: Name: S23 (50).jpg
Description:
Description: Name: S23 (53).jpg
Description:
Old Nov 09, 2012, 07:27 AM
GeoffinIN is offline
Find More Posts by GeoffinIN
Two left thumbs
Muncie, IN
Joined Sep 2006
I like the way you've designed the nose so that a large nose block is not needed. That saves a lot of carving!
Who made the razor plane in your tool set?
Geoff
GeoffinIN is offline Find More Posts by GeoffinIN
Old Nov 09, 2012, 08:27 AM
**neons**'s Avatar
USA, MA, Swansea
Joined Mar 2003
Beautiful. That hull looks so nice. What a nice set of tools to break in also. I will mention that I hope you have considered some "Limber Holes" along the keel for water to pass through. If water traps behind each former it will cause a load of glue line damage and swelling if it does not dry out fast because of puddles. Just a thought to consider.
**Neons** Bob
Old Nov 09, 2012, 08:46 AM
Bart83's Avatar
Joined Jun 2009
@ GeoffinIN , the razor plane comes from Robbe. Some nose carvin needs to be done.
@ Neons great tip on the formers. Maybe it is an idea to give the inside of the hull some kind of treating.
Here are some pictures of the nose , without glue
Cheers,
Bart
Description: Name: S23 (54).jpg
Description:
Old Nov 09, 2012, 09:29 AM
Kuni is offline
Find More Posts by Kuni
Dresden, Germany, europe, planet earth
Joined Aug 2003
Hi Bart,
as I build my waterplane models also from wood (you have seen me in the german waterplane forum), I only can recommend waterproofing the whole wood structure with 2 coats dope/filler. I use this:
http://www.clou-shop.eu/g1-schnellsc...undierung.html
Regards,
Kuni
Kuni is offline Find More Posts by Kuni
Old Nov 09, 2012, 10:57 AM
Bart83's Avatar
Joined Jun 2009
Hey Kuni ,
Thanks lot for that tip , i wonder how much weight this treatment would add to the balsa structure.
Cheers,
Bart
Old Nov 09, 2012, 11:06 AM
Kuni is offline
Joined Aug 2003
Hi Bart,
not that much. But having a waterproof hull/fuselage is worth that gramms. I treat the whole airfram with that stuff, means the inside of wings, tail group etc.
You never know when the model has a "less than perfect" take-off or approach, and sometimes, when all goes wrong, some needs to pour water out of the wing...
Regards,
Kuni
Old Nov 09, 2012, 01:44 PM
how much is offline
Find More Posts by how much
how much's Avatar
United Kingdom, England, Wigan
Joined Jul 2011
Bart
your progress assembling your CNC cut parts is quite staggering...
you have "shamed" me into it...
my scratch built Sunderland is back on the building board..
there is no way your Solent will be finished before my Sunderland it has sat there 90% finished with all running gear and systems working...and un-touched for about 6 months
i hope the weather is awfull here in the UK for the next couple of weekends
David
how much is offline Find More Posts by how much
Discussion Short Empire Class "C" kestrel2003 Waterplanes 51 Dec 09, 2007 04:33 AM
Sold ***Ivan Pettigrew Short Solent 400 Plans*** Rudderman98 Aircraft - Electric - Airplanes (FS/W) 0 Jan 07, 2007 05:20 PM
