Old Sep 10, 2012, 10:24 AM
DG1000 is offline
Find More Posts by DG1000
Joined Oct 2008
Bart
What an impressing project! Just subscribed to your thread
Having no experience at using CAD I am very interested in your lessons learnt during design and build stage using CAD.
Good luck for your project
Rolf
DG1000 is offline Find More Posts by DG1000
Old Sep 10, 2012, 07:06 PM
Bart83 is online now
Find More Posts by Bart83
71% of the world is runway . .
Bart83's Avatar
Nederland, ZH, Oostvoorne
Joined Jun 2009
Originally Posted by DG1000 View Post
Bart
Rolf
Thanks !! ,
Maybe this weekend i can make a tutorial on drawing the float for example.
Greets,
Bart
Bart83 is online now Find More Posts by Bart83
Old Sep 10, 2012, 07:33 PM
Mr_McGlue is offline
Find More Posts by Mr_McGlue
Mr_McGlue's Avatar
United States, CA, Long Beach
Joined Sep 2011
That would be cool to see.
Robert
Originally Posted by Bart83 View Post
Thanks !! ,
Greets,
Bart
Mr_McGlue is offline Find More Posts by Mr_McGlue
Old Sep 16, 2012, 04:19 PM
Bart83's Avatar
Joined Jun 2009
Did not have a lot time this weekend but here are the pictures of what i have done.
Description: Tail construction
Description: Rendered
Description: shaded
Description: Parts & plan
Greets,
Bart
Old Sep 17, 2012, 06:24 PM
Bart83's Avatar
Joined Jun 2009
Started on the hull framework. . . . . . . . . I now suffer from square eyes!!!
But im happy with the result.....
Made a piece of the plan , bottom , top and side view of framework for easy construction. Only costs a lot of paper.
Description: Framed box hull
Description: Plan for boxframe
Greets,
Bart
Old Sep 18, 2012, 02:31 AM
LukeZ is offline
Find More Posts by LukeZ
LukeZ's Avatar
Joined May 2001
Nice work Bart. At first I wondered why you'd bother doing the cad for a stick fuse... but I think you are right, the precise plans alone would be worth the effort. It was also probably a prerequisite step for the formers to come.
Keep it up! It's only time you're spending now.
Luke
LukeZ is offline Find More Posts by LukeZ
Old Sep 18, 2012, 03:15 AM
Bart83's Avatar
Joined Jun 2009
Youre right there Luke, next step is the top and bottom formers etc.
The CAD plan is the main reason why i did this but also it was a great exercise for my as i still have a lot to learn on working with Rhino.
By looking at the plan now i think i have made a minor mistake : When you build the side of the framework over the side view plan it is let say 150cm or 60 inch lengt from nose to tail ( example ).
Then when you ad the cross formers to join the side's the side's will bend and so become shorter than the 60 inch in the side view.
made a simple paint drawing to explain.
Description:
Have to find a way to make this right . . . . . . . . . . . . . .
Greets ,
Bart
Old Sep 18, 2012, 04:34 AM
Pete1978 is offline
Find More Posts by Pete1978
Lincoln, UK
Joined Jun 2005
I don't know much about Rhino but back in the dim and distant when I was a CAD draughtsman, it was possible to start with a plan view of the basic box and then 'interrogate' the program to discover the arc length of one side. This dimension could then be used to lay out the length of one fuselage 'ladder' (side) flat. Keep up the good work, the Empire boats were very elegant aircraft!
Pete1978 is offline Find More Posts by Pete1978
Old Sep 18, 2012, 11:02 AM
cracksmeup is offline
Find More Posts by cracksmeup
cracksmeup's Avatar
United States, IL, Joliet
Joined Jun 2009
Bart ,dont forget the curved side pieces Ivan had us add to the uprights on the fuse to give the fuse its round shape and get rid of the boxy look. joe
cracksmeup is offline Find More Posts by cracksmeup
Old Sep 19, 2012, 02:11 AM
LukeZ is offline
LukeZ's Avatar
Joined May 2001
In practice, by which I mean during the building phase, I think you will find the bend to be so minor as to make the change in length negligible due to any curvature.
But if you are going to all the trouble to draw it in CAD, of course it is worth getting it precisely correct. I'm not sure how you would do this in Rhino but I'm guessing there should be some kind of "ruler" tool, as Pete says.
Luke
Old Sep 19, 2012, 04:08 AM
Bart83's Avatar
Joined Jun 2009
@Joe : Thanks for the heads up but as you can see from the sections in the drawing by Len Whalley the side's were flat and sloped inwards to te front top. The Hull side's of the S.45 Solent had much more roundings then the S.23.
Solent
Description: Hull Shape
Description:
Empire sections
@ Luke , Think im gonne read through the list of commands and see what are my options.
Question : Could annyone post a picture of the NASA leading edge cuff ? want to see it in detail.
Greets,
Bart
Old Sep 19, 2012, 11:02 AM
GLM is online now
GLM
Find More Posts by GLM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
Hi Guys,
I hope this is the answer to the question.
This is my process to Un-roll in Rhino.
1. Build your model.
2. Create a silhouette with the command of the same name.
3. Use the Silhouette to create surfaces.
4. Use the Un-Roll develop-able surface tool.
Hope this helps
Cheers!
Gary
GLM is online now Find More Posts by GLM
Old Sep 19, 2012, 11:33 AM
cracksmeup's Avatar
Joined Jun 2009
Hey Bart you are right about it being alot flatter sides and seeing your side by side pictures i did not relize the sunderland was that flat. joe
Old Sep 19, 2012, 02:14 PM
Bart83's Avatar
Joined Jun 2009
@ GLM , thanks , gonna try it tommorow
@ Joe , Sunderland Short S.23 Empire
Greets,
Bart
Old Sep 19, 2012, 03:46 PM
cracksmeup's Avatar
Joined Jun 2009
HaHa yea i got Daves sunderland going on to and getting the two of you confused . My mind might be slipping a little but my flying thumbs are still working just fine. lol joe
Discussion Short Empire Class "C" kestrel2003 Waterplanes 51 Dec 09, 2007 05:33 AM
Sold ***Ivan Pettigrew Short Solent 400 Plans*** Rudderman98 Aircraft - Electric - Airplanes (FS/W) 0 Jan 07, 2007 06:20 PM
