Old Nov 17, 2012, 01:17 PM
cracksmeup is offline
Find More Posts by cracksmeup
cracksmeup's Avatar
United States, IL, Joliet
Joined Jun 2009
Most of us planked the necells and tip floats because of to much compound curves to sheet ,some used foam blocks and fiberglassed them but once the sun hit them they had problems with bubbles. I planked mine and then mixed a little water with light weight drywall spackle and filled the small cracks . When dried and final sanded it turned out better than i thought it would.I hated planking at first but after doing alot of it ,its not bad . Looking good Bart ! joe
cracksmeup is offline Find More Posts by cracksmeup
Old Nov 17, 2012, 02:22 PM
Fast Freddy is offline
Find More Posts by Fast Freddy
Madison, WI
Joined Feb 2004
Bart, Just a suggestion. Make sure you waterproof the inside before all the sheeting is on. This will help prevent mold and wood rot in the future. Water will get in, it's just a matter of "when" not "if". Thinned dope, WBPU, or sanding sealer works well.
Fast Freddy is offline Find More Posts by Fast Freddy
Old Nov 18, 2012, 03:50 AM
Sopwith Mike is online now
Find More Posts by Sopwith Mike
Slip the surly bonds...
Sopwith Mike's Avatar
Christchurch,England
Joined Aug 2004
I like the way you have designed the planked area so you can use parallel-sided strips: so much easier than having to taper each one, and a technique to copy in future.
Sopwith Mike is online now Find More Posts by Sopwith Mike
Old Nov 20, 2012, 05:07 AM
Bart83 is online now
Find More Posts by Bart83
71% of the world is runway . .
Bart83's Avatar
Nederland, ZH, Oostvoorne
Joined Jun 2009
The empire stikes back . . . . .
Thanks Mike , i still need some filler on the very small seams . . .
Today another attempt to shape the nose , thirst one is messed up so i made a new set of nose formers and try again. Luckely there is no rain today so i can do it outside.
When you open google earth and you see a large dust cloud in the south west of the Netherlands. dont worry , it is me producing a lot of balsa dust
Description:
Cheers,
Bart
Bart83 is online now Find More Posts by Bart83
Old Nov 20, 2012, 05:28 AM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
she is coming along fantasticly well mate, can't wait to see her finished!
Craig
trumps is offline Find More Posts by trumps
Old Nov 20, 2012, 06:40 AM
Bart83's Avatar
Joined Jun 2009
@ Craig , Thanks !!!
Got the nose mounted and sanded , finer sanding will be done when the hull finished prior to covering.
Description: Name: S23 (89).jpg
Description: Name: S23 (90).jpg
Description: Name: S23 (91).jpg
Description:
Cheers,
Bart
Old Nov 20, 2012, 03:08 PM
Bart83's Avatar
Joined Jun 2009
Made some progress . .
assembled the formers of the upper front section and glued the wing sadlles on.
It was neccecary to reinforce some formers because the 1.5mm balsa is very weak and tends to bend out of shape very soon. . .
Did a loose fit of the cockpit window frame too se how it looks ( not glued yet . . )
Also made a start on the small piece of hull side sheeting.
Cant wait to go further , pitty i have to work tommorow . . . . .
Cheers,
Bart
Description: Boubler wing dowel supportName: S23 (101).jpg
Description: Name: S23 (100).jpg
Description: Front hull partName: S23 (96).jpg
Description: Wing saddles in placeName: S23 (97).jpg
Description:
Description: Name: S23 (93).jpg
Description: Its beginning to look like an empireName: S23 (95).jpg
Description: Name: S23 (94).jpg
Description: Name: S23 (98).jpg
Description:
Old Nov 20, 2012, 03:16 PM
GLM is offline
GLM
Find More Posts by GLM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
Cheers,
Bart
Attachment 5317078Attachment 5317079Attachment 5317080Attachment 5317081Attachment 5317082
Attachment 5317083Attachment 5317086Attachment 5317087Attachment 5317088Attachment 5317101
Man - this is looking good Bart!
Gary
GLM is offline Find More Posts by GLM
Old Nov 20, 2012, 03:32 PM
**neons** is offline
Find More Posts by **neons**
5,200 Led Lighted Bike-Bob P.
**neons**'s Avatar
USA, MA, Swansea
Joined Mar 2003
Your pictures are very good.That wood is is nicely cut. That is a time saver in construction. I can see where this plane will fly together before it flys again off the water. The construction is like looking at artwork. Good job on the whole plane from plans to where you are at now. This is a well planned build, literally speaking.
**Neons** Bob
**neons** is offline Find More Posts by **neons**
Old Nov 20, 2012, 03:42 PM
Kuni is offline
Find More Posts by Kuni
Dresden, Germany, europe, planet earth
Joined Aug 2003
Hi Bart,
do you plan to make this bird a kit in the future?
Regards,
Kuni
Kuni is offline Find More Posts by Kuni
Old Nov 20, 2012, 03:51 PM
Bart83's Avatar
Joined Jun 2009
Originally Posted by Kuni View Post
Hi Bart,
Regards,
Kuni
There is someting in the making . . . . more to tell wen the maiden is done and the desing is free of mistakes.
Cheers,
Bart
Old Nov 20, 2012, 03:53 PM
Bart83's Avatar
Joined Jun 2009
@ Gary , thanks man kind words are motivating !!
@ Bob , nice you are still following my tread , how is your mars ?
Cheers,
Bart
Old Nov 21, 2012, 05:34 AM
Bart83's Avatar
Joined Jun 2009
Got the side sheeting done and sanded a sharp edge on the hull bottom/side.
Also had my wife took a picture of me and the model so you all have a face to the words . .
Cheers,
Bart
Name: S23 (102).jpg
Description: Me and the model
Old Nov 21, 2012, 06:27 AM
Jürgen Be is offline
Find More Posts by Jürgen Be
Jürgen Be's Avatar
near Stuttgart, Germany
Joined Oct 2008
Great,
maybe I can see you and your Shorts, together with Paul, on some meetings in Germany next year. Would be nice.
Jürgen
Jürgen Be is offline Find More Posts by Jürgen Be
Old Nov 21, 2012, 09:03 AM
**neons**'s Avatar
USA, MA, Swansea
Joined Mar 2003
Hi Bart
She looks great and you have good reason to be smiling. It is so satisfyng to see a traditional build with sticks and sheets come together. I have 35 members in my club and only a few real builders with us now. We lost 4 old timers that built models the real way. Of course when my Martin Mars was at the stage where you are at I was planning the battery tray and control rod placements.That is where I swung from tradional to Depron foam sheeting above the wood. OOPS! I guess I said a bad word. Sorry.
I hung my Mars up. The weather is getting cold and I do not want to be on the water this time of years should a mishap occur. In the meantime I am active on land and getting ready for my next model. A ttraditional Proctor WWI Neuiport 28 -1/4 scale.build. I will be watching your plane also.
**Neons**Bob
Discussion Short Empire Class "C" kestrel2003 Waterplanes 51 Dec 09, 2007 04:33 AM
Sold ***Ivan Pettigrew Short Solent 400 Plans*** Rudderman98 Aircraft - Electric - Airplanes (FS/W) 0 Jan 07, 2007 05:20 PM
