Old Nov 12, 2012, 06:57 AM
how much is offline
Find More Posts by how much
how much's Avatar
United Kingdom, England, Wigan
Joined Jul 2011
Originally Posted by Bart83 View Post
@Robert & Mike , thanks , the kind words are realy motivating
@ David , I used the wing profile selig 7055 as ivan and the airfoil outside of the outer nacelles has a leading edge cuff. the angle between the wing and the stab is approx 4degrees .
The motors are inline with the wing. i hope i can get that nose down sit like the real thing had.
Wich airfoil did you use ? the Göttingen like the real sunderland ?
Attachment 5295040
Cheers,
Bart
Bart
yes i went for the scale section, its looks right with its big blunt leading edge.
i also went for scale incidence angles being +7deg main plane, +4deg tail plane and +4deg motor thrustline, i want to get the "sit" in the air right.
as Sopwith Mike pointed out on yours, i have also gone for the more scale like deep "V" on the hull. based on the loose idea that the model is very light and wont sit as deep in the water as the real aircraft..... i hope!
only time will tell if these were the right decisions
keep up the excellent work
David
how much is offline Find More Posts by how much
Old Nov 12, 2012, 07:41 AM
cracksmeup is offline
Find More Posts by cracksmeup
cracksmeup's Avatar
United States, IL, Joliet
Joined Jun 2009
Short kit , plans. When the maiden is succesfull and the desing is without faults i make sure a short kit and plans are available . .
Sheeting done today . . . .
Attachment 5298459 Attachment 5298460 Attachment 5298461
Cheers ,
Bart
Thats some balsa bending around the bottom of the nose Bart ,i might have been able to do it but there would have been alot of swear words . She looks great Bart joe
cracksmeup is offline Find More Posts by cracksmeup
Old Nov 12, 2012, 10:40 PM
mogman is offline
Find More Posts by mogman
1/2 scale
Pitt Meadows. B.C. Canada
Joined Oct 2006
Hi Bart.
I have had the pleasure of seeing Ted Russel's "Empire" fly many times.
I also have the pleasure of obtaining Ted's 1/10 version of the Plane. (136")
It is probably 70-75% built, he ony sold it to me as he is moving soon and did not want to pack this with him.
It was set up for 4x 1.20 FS, but I only fly gas, so possibly 4 dle 20's or the like.
Also toying with the idea of electrics, but I have VERY little knowledge of the "black art".
The first item to address is getting the flaps to work in a scale manner, something Ted has played with for some time.
Hopefully, I will have some progress done in the new year, really looking forward to flying this. especially as a tribute or salute to Ted, as he has done so much for float flying in British Columbia.
Cheers,
Dave.
mogman is offline Find More Posts by mogman
Old Nov 12, 2012, 11:37 PM
Bart83 is offline
Find More Posts by Bart83
71% of the world is runway . .
Bart83's Avatar
Nederland, ZH, Oostvoorne
Joined Jun 2009
Originally Posted by mogman View Post
Hi Bart.
Cheers,
Dave.
Great !! did you read my first post ?? i have seen tTed's model on the cover of MAN in 1994 !! ever since then i wanted to build an empire. Do you know if there's is any video if ted's model? Hope you post a build thread of your great project. I think electrc is a must i combination with a good sound system. Flaps ? that will be hard the original had Gouge plaps and NOT fowler flaps, making them scale will be hard but not impossible. There is a great dutch modeller who has build a 1/10 sunderland an he has used fowler flaps , looks good though.
Cheers,
Bart
Description:
Description:
Description:
Description:
Bart83 is offline Find More Posts by Bart83
Old Nov 14, 2012, 03:47 AM
Bart83 is offline
Bart83's Avatar
Joined Jun 2009
And one step furher on sheeting :
Description: Name: S23 (72).jpg
Description: Name: S23 (73).jpg
Description:
Description: Name: S23 (75).jpg
Description:
Cheers,
Bart
Old Nov 14, 2012, 08:13 AM
cracksmeup's Avatar
Joined Jun 2009
Remember to pick out light sheeting for the tail ,thats where my weight went south on mine. She looks very clean and straight Bart i like how you put the stringers in ,i had some spots pucker in between formers from not having stringers put in and had to re wet them and hold to shape . joe
Old Nov 15, 2012, 04:25 AM
Bart83 is offline
Bart83's Avatar
Joined Jun 2009
@ Joe , i picked the lightest softest balsa from my stash for the aft sheeting. Busy froming the basla . . . .using the water boiler
Description: Name: S23 (77).jpg
Description: Name: S23 (78).jpg
Description:
Cheers,
Bart
Old Nov 15, 2012, 08:27 AM
Kuni is offline
Find More Posts by Kuni
Dresden, Germany, europe, planet earth
Joined Aug 2003
Hi Bart,
please make the bottom/side-junction as sharp and precise as you can. The planing performance will depend on how well (or not) the water can seperate at these edges!
Also the step: a sharp edge is needed for good flow-seperation. If the model "sticks" later, the reason is often a soft, round-sanded chine...
Regards,
Kuni
Kuni is offline Find More Posts by Kuni
Old Nov 15, 2012, 09:15 AM
cracksmeup's Avatar
Joined Jun 2009
Attachment 5304775 Attachment 5304776 Attachment 5304777
Cheers,
Bart
Your fansy there with the boiler . lol I just had a mixture of water and amoina in a windex spray bottle to spritz it till wet ,then bend. I have since gotten high teck and took my girfriends hair curler steamer . She has asked me several times if i have seen it and i shake my head no. joe
Old Nov 15, 2012, 11:52 AM
Bart83 is offline
Bart83's Avatar
Joined Jun 2009
@ Kuni , Thanks for the tips's
@ Joe , Today i found out that moisturizing the balsa using a small sponge and warm water with dishwashing soap gave me good results. The soap foam from the sponge penetrates the balsa grain easy and makes it softer.
I also hear great things about the amonia drain but im affraid the chemicals weaken the balsa perminent.
bought hobbico balsa filler today , gonna need it
Cheers,
Bart
Old Nov 15, 2012, 12:10 PM
cracksmeup's Avatar
Joined Jun 2009
Cheers,
Bart
I have used amoina with water mixture for a long time and had no bad effects .When i get lazy i even use windex with amoina straight from the bottle . Each builder has his own methods or works best for him and i like watching all of them . I have used your sponge method after i sprits it with the spray bottle ,if i get carried away i get my weekly bath too. joe
Old Nov 15, 2012, 03:01 PM
Bart83 is offline
Bart83's Avatar
Joined Jun 2009
You lucky bastard !! i only get to bath the second day of cristmas
Take a shower on the even days though , do not make a lot of clothes dirty too
( one bad habbit i picked up in the royal dutch army ) LOL
Here are some pics of todays progress , plan to make the sheeting smooth tommorow. There is a light bump in the aft sheeting , the stringer underneath is a bit too fat out , have to find a way to make it smooth. Maybe i'll glue an additional former insde the dent.
Cheers ,
Bart
Description: Name: S23 (80).jpg
Description: Name: S23 (82).jpg
Description: Name: S23 (81).jpg
Description:
Old Nov 15, 2012, 03:04 PM
cracksmeup's Avatar
Joined Jun 2009
Cheers ,
Bart
Attachment 5305566 Attachment 5305567 Attachment 5305568 Attachment 5305569
I use the same windex spray bottle on my cloths for a couple extra days . lol
Old Nov 16, 2012, 07:41 AM
Bart83 is offline
Bart83's Avatar
Joined Jun 2009
Drawn some molds for vacuumforming i thick this is the best way for the cowls and dummy''s.
Name: S23 (116).jpg
Description: Molds for vacuumforming
Cheers,
Bart
Old Nov 17, 2012, 12:49 PM
Bart83 is offline
Bart83's Avatar
Joined Jun 2009
Made a start on the nose sheeting. Next is applying the side sheeting ( bottom half only ) , filling the seams and sand the sheeting smooth.
For this complex round form i found it impossible to do it in 1 piece so i used several strips of balsa
Cheers,
Bart
Description: Name: S23 (85).jpg
Description: Name: S23 (86).jpg
Description:
Discussion Short Empire Class "C" kestrel2003 Waterplanes 51 Dec 09, 2007 04:33 AM
Sold ***Ivan Pettigrew Short Solent 400 Plans*** Rudderman98 Aircraft - Electric - Airplanes (FS/W) 0 Jan 07, 2007 05:20 PM
