Old Nov 09, 2012, 02:39 PM
Bart83 is online now
Find More Posts by Bart83
71% of the world is runway . .
Bart83's Avatar
Nederland, ZH, Oostvoorne
Joined Jun 2009
mm my solent is not getting finished ever . . . my empire is i hope . . .
Howe about an update to your thread ? ?
Cheers,
Bart
Bart83 is online now Find More Posts by Bart83
Old Nov 09, 2012, 03:12 PM
how much is offline
Find More Posts by how much
how much's Avatar
United Kingdom, England, Wigan
Joined Jul 2011
Cheers,
Bart
sorry Bart.... i am in error
I believe we both started with a "Solent".... of the Ivan Persuasion
you ended up with an "Empire"
and i ended up with a "Sunderland"
my building board is clear.. my 72" Cub has at long last got its scratchbuilt floats..
my Sunderland... is back on the building board (Dining room table) it doesnt require much to get it finished... plus i have some time off work coming up!
David
how much is offline Find More Posts by how much
Old Nov 09, 2012, 05:35 PM
Bart83's Avatar
Joined Jun 2009
WOW !! that is looking great !! , cant wait to see it finished.
Wich props do you have mounted there ?
Good luck with the rest of the build
cheers,
Bart
Old Nov 10, 2012, 01:12 AM
how much is offline
how much's Avatar
Joined Jul 2011
Bart
props are the 3 blade gws 8 x 3.5 left and right hand pitch the model sounds fantastic when running and the thrust is off the scale
David
Old Nov 10, 2012, 02:12 AM
Bart83's Avatar
Joined Jun 2009
Ok, and wich motors you have running that ?
Hey David,
I have 880kv motors and i plan to use gws 9x7 3 blade props but they seem hard to get . . .
i now have 9x5 3 blade and measure the amps and thrust.
Cheers,
Bart
Old Nov 10, 2012, 11:38 AM
Bart83's Avatar
Joined Jun 2009
Not much done today ,
Build the front section of the hull and sanded them to shape.
Made a change to the desing : I made a new part for the cockpit bottom this one
is without notches for the formers to fit in this way it was a better fit. Got some work on the aft of the hull where the tailplanes are mounted on done but first i want to get the bottom hull sheeted.
Cheers,
Bart
Description: Name: S23 (57).jpg
Description:
Description: Name: S23 (59).jpg
Description:
Old Nov 10, 2012, 11:46 AM
Sopwith Mike is offline
Find More Posts by Sopwith Mike
Slip the surly bonds...
Sopwith Mike's Avatar
Christchurch,England
Joined Aug 2004
Both the Sunderland and the Empire are looking good. Next year is going to be a classic when these planes fly!
Sopwith Mike is offline Find More Posts by Sopwith Mike
Old Nov 10, 2012, 04:01 PM
Robert R is offline
Find More Posts by Robert R
It's a fine fiddly business.
Robert R's Avatar
United States, WA, Marysville
Joined May 2009
Bart,
Absolutely beautiful build. I love the fuselage.
Best,
Robert
Robert R is offline Find More Posts by Robert R
Latest blog entry: Mustang Sally Sea Trials
Old Nov 10, 2012, 04:35 PM
how much is offline
how much's Avatar
Joined Jul 2011
Bart
what incidence angles have you chosen for main plane and tail plane? and what thrust angle for the motors? and why?
just asking because i have chosen those of the full size which might shock a few on here.. (i have done this before on much larger scratchbuilts too mimick the full size)
David
Old Nov 10, 2012, 05:22 PM
Bart83's Avatar
Joined Jun 2009
@Robert & Mike , thanks , the kind words are realy motivating
@ David , I used the wing profile selig 7055 as ivan and the airfoil outside of the outer nacelles has a leading edge cuff. the angle between the wing and the stab is approx 4degrees .
The motors are inline with the wing. i hope i can get that nose down sit like the real thing had.
Wich airfoil did you use ? the Göttingen like the real sunderland ?
Description:
Cheers,
Bart
Old Nov 11, 2012, 11:19 AM
Bart83's Avatar
Joined Jun 2009
Got the first phase of the bottom sheeting done , t was hard to let the wood follow te curves of the hull formers. I made the wood softer by steaming it. Next is are the 2 sheets behind the step , these are also in 2.5mm balsa so again hard to form. Luckely the rest of the sheeting in done in 1.5mm balsa. Will need some filler on the seams
As picture's say more than words . . . . .
Description: Name: S23 (61).jpg
Description:
Description: Name: S23 (63).jpg
Description:
Description: Name: S23 (65).jpg
Description:
Cheers ,
Bart
Old Nov 11, 2012, 12:46 PM
Joined Aug 2004
None of this messing around with flatter sections on the hull then Bart - a full scale flying boat for you! Those of us who started with Ivan's models have been brought up on non-scale hull sections (much flatter, to encourage early planing and a stable platform when at rest). It will be very interesting to see how a scale hull performs.
Looking good so far!
Old Nov 11, 2012, 12:56 PM
Rudderman98 is offline
Find More Posts by Rudderman98
AMA 670207
Rudderman98's Avatar
United States, WA, Sumner
Joined Oct 2000
Bart,
Your progress is truly amazing! Very clean construction.
I, and I am sure others on this thread will be waiting in anticipation for it's maiden.
Put me down for plans and one short kit please.
Perry
Rudderman98 is offline Find More Posts by Rudderman98
Old Nov 11, 2012, 12:58 PM
huggie9999 is offline
Find More Posts by huggie9999
Ex-President @ HMM
huggie9999's Avatar
United States, CA, Hemet
Joined Oct 2006
Originally Posted by Rudderman98 View Post
Bart,
Perry
Same here!!!!!!!!!!!!!!!!!!
huggie9999 is offline Find More Posts by huggie9999
Old Nov 12, 2012, 03:34 AM
Bart83's Avatar
Joined Jun 2009
Short kit , plans. When the maiden is succesfull and the desing is without faults i make sure a short kit and plans are available . .
Sheeting done today . . . .
Description: Name: S23 (69).jpg
Description: Name: S23 (70).jpg
Description:
Cheers ,
Bart
Discussion Short Empire Class "C" kestrel2003 Waterplanes 51 Dec 09, 2007 04:33 AM
Sold ***Ivan Pettigrew Short Solent 400 Plans*** Rudderman98 Aircraft - Electric - Airplanes (FS/W) 0 Jan 07, 2007 05:20 PM
