Old Aug 25, 2012, 01:21 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
Intro to Multirotors, Theory, Build Log and Tips.
The goal of this guide is to provide a RC noob a tutorial on how to build a fairly standard quadcopter.
So, what is a quadcopter? Wikipedia says: "A quadcopter is a multicopter that is lifted and propelled by four rotors. Quadrotors are classified as rotorcraft, as opposed to fixed-wing aircraft, because their lift is generated by a set of revolving propellers. Unlike most helicopters, quadrotors generally use symmetrically pitched blades; these can be adjusted as a group, a property known as 'collective'. Control of vehicle motion is achieved by altering the rotation rate of one or more rotor discs, thereby changing its torque load and thrust/lift characteristics." Well, that sounds funny, what does it actually look like?
In this picture, you can easily see all the important parts of the quadcopter. The most obvious things are probably the motors and propellers. The motors spin around at a few thousand RPM and so as the props spin with the motors they produce thrust. Here are some typical motors and props:
Next you'll probably notice the frame. This is commonly wood, aluminum, carbon fiber or glass fiber and has some sort of center plate on which 4 arms are attached. On the ends of these arms, are the motors. Here are some common frames:
In the center of the frame is the flight controller, receiver and battery. Flight controller is connected to all of the motors, and the receiver. It controls the direction, height, and speed etc of the quadcopter, by, as wiki said, varying the RPMs of the motors (and therefor the amount of thrust). A picture of a FC (there are MANY different types of FCs):
Mounted on the arms between the motors and the center plate, you can see the motor controllers (called an ESC (electronic speed controller)) It is connected to the FC, battery, and motor. The three red wires at the top are connect to the motor and the red/black wires at the bottom go to the battery. The black three pin connector in the upper left of the pic below is connected to the FC so that the ESC can be controlled (and therefor the motor too).
The receiver connects to the FC and receives the signals from the transmitter that control the quadcopter. It has multiple channels for the different control inputs of the quadcopter:
The battery is a LiPo which has a higher power to weight ratio compared to a NiMH battery, for example.
A common TX is the second image below. In the first picture you can see the most important part of the TX; the "sticks". There are two sticks, and each can move left/right/up/down. These sticks control 4 different channels: rudder, throttle, aileron, elevator. These are based on airplane controls, but still make sense for a quadcopter. Rudder controls the Z axis of the quad, yaw, or spinning without moving left/right/forward/back etc. Throttle controls the RPM of the motors and thus making it go higher/move faster. Aileron is Y, roll, or tilting left/right. Elevator is X, pitch, or tilting forward/back. There are two main "modes" of a TX; mode 1 has the throttle stick on the right and ailerons on the left, and mode 2 is the opposite.
Theory
Materials
To build a quad you basically need:
4x motors
4x ESCs
4x Props (2 CW and 2 CCW)
1x LiPo battery monitor
1x Frame
1x FC
1x TX/RX
1x Battery Charger
1x Battery (extras are good)
Misc: wire, plugs, zipties, nuts/bolts, sodlering iron, general tools.
HobbyKing (to buy stuff)
RCGroups (help!)
Frame
Starting from scratch, the frame is probably the first thing to pick as its design/size depends on what you want to do and changes the rest of the build. 400mm to 700mm motor to motor fairly standard for most quads. Most times beginners build their frames out of aluminum or wood. More expensive(most times better) are made of carbon fiber. For your first quad, though, it'd be better to but a pre-fabricated frame. HobbyKing is now really starting to get into the quadcopter stuff and has quite a selection of frames now. But, whatever you do, don't buy one of those 10$ cheap wood frames as they break very easily. The rest of the frames there do look ok, but the motor mounts on the Talon style motor mounts are a bit weak; you can get some better ones off ebay. HK is not the only place, though, google will find you hundreds of frames. Dialfonzo, from the RCgroups forums, also has some nice frames.
DIY Frames
This image shows the parts that a frame requires:
Wood
A wood frame is probably the easiest for a beginner to DIY frames because wood is a easy material to work with. 3/8in to 3/4in square poplar or hardwood is what i have seen the most, but i think 3/8 is a bit to flexible and as i saw at the Home Depot, severely twisted. But, I found some nice 1/2in hardwood that wasn't twisted very much and it has worked fairly well. On any type of frame i still like to use two CF plates with the four arms squished between to create a X or + shape. The next important thing is how it's mounted. Currently, my wood arms have two holes in them spaced .75in apart with bolts going though it and the CF; I'm guessing that it will also crack down the center like the crappy CF square tube that HK sells, so, i recommend to use something that squeezes the arms between the center plates and not bolt into the arms. You can probably get away with mounting the motors directly to the arms if you extend the ends of the arms past the prop so that the props cant hit the ground in a crash.
Aluminum
This my favorite option and is very popular because it is easily accessible, fairly light, and strong: typically, 3/8 to 1in in square tube/tube is used. A good thing to note is the wall thickness of the tube; you want pretty much the thinnest you can get, otherwise the weight is too much most times. 1.64in or 1mm is good. Regular tubes are stronger than square tubes of the same specs. With Aluminum you can, with fewer issues, bolt the arms directly to the center plates, and the motors to the arms, unlike CF and wood.
Carbon Fiber
If you are going for CF, make sure you get the proper cross-weaved stuff. Even then, it'd be better not to drill into it; instead use clamping type mechanisms to hold the arms into the base and the motors onto the arms. If you get the CF square tube from HK which only has CF going one direction and you drill into it for the mounts, it will fail. Again, square tube would be better because it is not circular(of course haha) and you will know for sure that the motor are on straight.
Motors + Props
These two are inevitably intertwined (along with pretty much everything else in a quad) and greatly depend on what you want to do with your quad. Most times a frame will give recommendations for motors and props. Generally, the bigger the quad, the lower the Kv (how fast the bladed spins, stands for rpm/volt) and the bigger the prop. Smaller quads have a higher Kv (blade spins faster) and smaller props. This is because the quad doesn't have room for the bigger props, so it must use a higher Kv to achieve sufficient thrust. With bigger props, you have slower reaction times, but more stability. For choosing a motor, i would pick the props first. You will want to choose the biggest(most times) that will fit on your quad with at least few inches between the FC and other props. But, you can also spread the motors out even more for better stability, generally. Once you find the props, find a motor that can spin them with efficiency and a good amount of thrust. The total weight of your quad should be about 1/3 of the total motor thrust (2/3rds, for good measure, of 1/2 of the total thrust). flybrushless.com is a great place to look at for thrust data, and Google also works pretty well too. 700 to 800Kv is good for 11in props, 900 to about 1100kv is10in props, 1200 to 1300kv or so use 9in props, and so on. eCalc does a very good job at getting you in the ball park of how your quad will perform. The calculated hover throttle needs to be 50% or less. Oh, and, thrust depends on the voltage the motor is receiving. The higher the voltage, the higher the amperage/thrust/Kv, but the motor might not be able to handle that. All motors have a rating, its better not to go over it. Commonly, multirotors will be 11.1v or 3s. It is also very helpful to look at other people designs and how well they work.
ESCs
This is probably one of the easiest things to pick out. These controls the motors depending on what signal the FC sends. After you've found your motors and how much current they're going to draw with the props you choose, you can choose the ESC. If one of your motors draws 18amps at full throttle, you wouldn't want a 18A ESC beacuse that would put a lot of stress on the ESC. Instead you would want to get a 25A ESC or even 30A. You should also get one that has a fast refresh rate; 400hz is really good and the Turnigy Plush/Basic are some of the most used on quads. Also pay attention to the voltage rating.
Battery
This may seem daunting to a beginner to pick out and may result in bad things if chosen incorrectly, but with a few tips it is quite easy to decide. First thing to consider is weight; it will most likely be the heaviest thing on your quad. If your battery is too heavy, it can badly affect your quad, and weight pretty much always is directly related to capacity. Since you know that your AUW should be about 1/3 of the total thrust of the motors and so the battery should be the last thing you pick to get to this total weight. Make sure you pick a 3s battery, for example, if you have 3s motors/ESCs.
Next thing to look at is amp draw. If you have four motors that draw 18A each, that's 72 amps total, and a 2200mah battery fits your weight and run time requirement, you would need at least a 32C battery as 2200mah = 2.2Ah and 72total amp draw divided by 2.2Ah is 32.7C (aka total amp draw divided by battery capacity in Amp hour). Again, like the ESCs, higher is better, so, maybe 45C? Continuing with that, lets find the flight time. (2.2Ah / 72A) * 60 = 1.88min. the equation is: (battery capacity in Amp hour divided by total amp draw) times 60. Those were calculations at 100% throttle. You can just use eCalc for most calculations, anyway.
if your quad weighs 1kg and your motors supply 4kg in total(1kg each) at max throttle. and the total amp draw is 72A. the hover amperage would be 72/4(the quad is 1/4th of the motor thrust) which is 18A hover thrust. so doing the flight time calculation again: (2.2Ah / 18A) * 60 = 7.33min hover time.
FC
This (the flight controller) greatly depends on your tastes; Arduino based such as MultiWii works for most people but it requires some tinkering to get working and is great after that. KK boards are very cheap, gyro only, and fairly typical for beginners. SM32 based FCs are more powerful and work a little better accordingly and are MultiWii compatible such as TimeCop's Free Flight board. But, for most people the additional processing power of STM32 doesn't really make a difference. Then there is the NAZA and Wookong which are the best for minimal setup required, besides RTF, of course.
Build
Here are my specs:
Turnigy Nano-Tech 2200mah 45-90C LiPo
Turnigy Accucel-6 50W 5A Balancer/Charger
Hacker 20-22L 17A brushless motors
10x4.5 CW(black, green)+CCW(black, green) props
Turnigy 25A Plush ESCs
Custom frame - aluminum arms/CF plate
Turnigy 9X 9ch 2.4ghz transmitter and receiver
Pololu MinIMU9-- L3G4200D Gyro, LSM303Accelerometer/Compass
Motors
I started out with the motors first. I had to do a few things to get them working for my particular build: put the propeller and base mounts on, cut off axles on the bottom, and put the bullet connectors and heat shrink on.
I dumped all the extra parts from the motors into a little container so I could find the stuff easier.
Cut off axle with air powered dremel.
Prop mount and bolts
A little locktite to keep the bolts in.
All the prop mounts done.
All done with bullet connectors and heatshrink!
ESCs
As you can see in the last image, these ESCs need to be connected in parallel with the battery. then the three red wires go to the motor. If the motor spins the wrong way, switch any two of the three red wires.
Soldered on bullet connectors. Make sure the heatshrink covers the whole female(ESC side) bullet connector so that they can short, but the female connector can still go in.
All done.
ESCs soldered together in parallel "spider" arrangement with XT60 connector. I soldered the ESCs together semi-permanently, but some may like bullet/XT60/etc connectors so that repairs are easier.
Custom Frame
This uses a 1.5mm CF center plate with four aluminum square tubes with holes drilled in them. I also took off the X motor mounts and mounted the motor directly to the arm which is way better and stronger. I have found that aluminum is the only material that i will drill holes into as wood and CF will crack, so, aluminum is my new favorite build material until i can get some proper boom/motor mounts for CF. The 4in PVC landing gear are awesome and were made of 3/8in wide pieces cut off of a 4in piece of pipe for each arm.
I cut a square piece of CF with the table saw (WITH A MASK) to the biggest square i could get from the HK 100x300x1.5mm CF sheet. then i drew lines from corner to corner to get nice 90deg lines in the center(the CF plate must be square for this to work ) then i measured in 1.5in on each line from the corner, and then i measured .5in from the corner again for the second arm hole. Then i took the arms(~8in each) and marked .5in and 1in from one side on all of them(to fit the plate. Finally, I marked 19mm spaced hoels at the opposite end of the arm for the motors. I marked and drilled for 3mm bolts except for the motor holes.
I was testing the BLHeli silabs firmware, sot that why there is not heatshrink on the ESCs in these pics. The ESC spider is laid centered on the bottom CF plate, then i put the arms on and made a CF-Alu-CF sandwich. Then i connected the motors to the ESCs, and the ESCs to the FC etc etc.
Battery
The battery came with bullet connectors, but i planned on using XT60 connectors. The charger also used the XT60 connector.
Original battery
The wires got a little close...
All done
Charger
Before cahrging any sort of LiPo, its good to know some background; They do explode! Also, read through this post at RCGroups forum. It gives a general overview of LiPos, how to charge them, and not make them blow up.
ATX PSU used to power charger using the included cables. Balance and main charge connectors from the battery are connected to the charger
When first turned on, the charger looks like this.
If LiPo is not already selected, press the Type button until the correct battery is selected, then press Enter.
Then it will look like this. Press "+" to go to LiPo Balance and then press Enter to select/loop through the charge settings, then "+" and "-" to change values. When ready to charge, press and hold the Enter button. Then Enter to confirm. After Charging has begun, press "+" to see individual cell voltage.
Props
You probably cant tell, but i have the props on upside down in the picture below of my first build. For some reason when i was putting them on, i didn't pay attention to the shape(like an airfoil) and put them on upside down. Most times the writing(most times a brand name and prop size/pitch) is facing up.
This caused a lack of power( loss of 50%!), and yaw issues. Here are some pics to help with prop orientation. Motor rotation is shown by the arrows around the motors.
This shows the direction that the motors need to spin!
Pusher/CW on front back, Tractor/CCW/ on left/right (for a "+" quad)
Connecting the FC!
The standard MWC board has four common areas: Power in , RX in, sensor hook ups, and ESC outputs. Lets use the MWC SE Lite board as an example.You will hopefully find some sort of diagram for any board you buy from the place you bought it.
Power
With this board, like most others, the power is supplied through one of the ESC outputs(bottom center, labeled M1-M6) through the ESCs internal BEC(a most times 5v power supply). So if you plug in a ESC with a 5v BEC, you got power! Also, you should check what voltage the BEC is and what voltage your board needs--they must be the same. Then the power is also sent through the FC to the RX via the 3pin servo connectors.
RX channels
This is really simple; just get some male to male servo cables and connect throttle from the RX to the throttle on the FC. Do the same for all the other channels. All MWC boards will have one AUX channel for selecting between level/acro, but the MWC SE and many other boards have two. The 5v from ESC goes through to the FC and then is sent to the RX through the cables that link the RX and FC.
Sensors
The MWC SE has the sensors built in to the board, so you don't have to work about adding them. Most IMUs that can be bought now have internal level shifters (because most IMUs are 3.3v and most FCs are 5v) and pullup resistors which make it 5v compatible. So, if you have one of these, you can just connect SDA to SDA, SCL to SCL, GND to GND, and 5v to Vcc in on the IMU and your done. Here is a thread by me that shows a few more IMUs.
ESC outputs
-simply plug the servo connector from the ESCs to the motor ports. Check to make sure you have the ESC in the correct port for its place on the quad, look here under Connecting Motors and Servos for what ESCs go to what port.
-Something worth mentioning is that there are two types of BECs: Switching and Linear. If you have ESCs with a switching BEC, you MUST remove the red(+5v) wire coming from all but one ESC. If you dont, your ESCs(specifically, the BEC inside) will get VERY hot. If you have linear BECs, you dont have to remove the red wire, but most people still do.
Programming/GUI
The MWC boards use a serial interface to program and to adjust settings in the GUI. Most times a FTDI adapter is used.
Software
TX Setup
Using the standard firmware that comes with the 9x, a few settings need to be changed for multiwii compatibility. Here is the instruction manual.
1. The sticks need to be set to Mode 2. (Menu/Sys Settings/Stick Set)
2. The TX should be in ACRO mode. (Menu/System Settings/Type)
3. You need to enable ch5, maybe ch6, and assign them to the switches so that you can switch between Accel/Gyro etc in flight. (Menu\Func\Aux-Ch)
4. It's not required, but you can calibrate the sticks value range:
-Push the right lower trim tab to the left (aileron on a mode 2 TX), and the left side trim tab up (Throttle trim on a mode 2 tx), and while holding them, turn the Tx on.
You will get a screen that shows the version number of the firmware, with four zeroes (0000) at the top of the screen.
-Center both sticks in their range in all axis, and press the menu button until it beeps and release. The screen number will change to 0001.
-Move the right stick to the upper right corner, and press menu, and you should get a beep, and the number on the screen will change to 0002.
-Put the right stick in the lower left corner, and press menu, and get a beep, and the number will change to 0003.
-Release the right stick, and put the left stick in the upper right corner, and press menu, get the beep, and the number will change to 0004.
-Put the left stick in the lower left corner, and press menu again, get the beep and the number will change to 0005.
-Center both sticks, and press menu, get the beep. You are done calibrating the sticks.
5. Some also say you need to set the ATV/servo range settings (Menu\Func\E. Trim):
pitch (elevator): 50%
roll (aileron): 50%
yaw (rudder): 100%
Initial gain pot values is 50%. Increase until it starts to oscillate rapidly, then back of until it is stable again. Fast forward flight needs lower gain. But I found mine to work just fine at 100%.
5. You can find the "DISPLAY" option in the Func menu, and that will display the values of the sticks so you know it is working.
6. Here is how to use the sticks on the TX to arm/disarm etc the quad with multiwii v2.0:
MWC GUI/more TX Setup
Basic MWC code config
-First, you need to get the latest MultiWii code and the latest Arduino IDE. Once you have the code open and have the config.h tab selected, you need to uncomment the orientation your quad will be in(QUADP, QUADX etc) under "The type of multicopter". Right below "type of multicopter", change I2C speed and I2C pullups if need be for your sensors. Then scroll down a bit until you find some #define lines for the gyro, acc, and mag. Like before uncomment the sensors you have or uncomment a board if yours is there. You could also search for RCAUXPIN and change that if you have a second auxiliary channel.
-If you have a ITG3200 or MPU6050 gyro, go to the Low pass filter setting section and un comment the 42Hz filter for your gyro. This can significantly stabilize your quad. I have the L3G4200D gyro which doesnt have LPF settings built into the code, but i found this post which has some code for my gyro that goes in the sensor tab of the code. Just find the old code and paste over it with the new code. But the best fix for reducing vibrations etc, is to fix it at the source--balance motors, props and get some good anti-vibration padding for the FC.
-#define MINTHROTTLE When you arm your quad, this is the value that is sent to the ESCs. it should be a little below the value that makes the motors spin up. This should be a little bit less than the min value of your throttle channel, aka,1095.
-#define MAXTHROTTLE This is the max value of the ESCs(aka full power); when the throttle stick is all the way up, this value is sent to the ESCs. Should be the max value of your throttle channel, AKA, 1905.
-#define MINCOMMAND is the value sent to the ESCs when disarmed. This should be below the minimum throttle, AKA 1095.
Setting up TX Channels in the GUI
-There are two main things we need to look at for now: transmitter channel values and the sensor data. First make sure the quad is disarmed and move all the sticks to their center positions. Now look at the TX channel values; they should all be around 1500 when centered. If not, go to your TX function menu and look for subtrim. Subtrim allows you to change where the center point is of the channels, so change the subtrim for each channel so that the values are at 1500. Then move each stick to its lower limit; it should be near 1095. If not, go to E. point in the function menu and change the percentages for each channel to change how low or high the channel value goes. If you move the selector to RUD(aka yaw), for example, you can move the yaw stick from side to side to select the high and low range value percentage. Use + and - to change the value. Do the same for each stick except for the upper limit of the channel value range; it should be 1905. Now all channels should have a midpoint of 1500 and lower limit of 1095 and a upper limit of 1905. If you cant for some reason change the center value of the TX channels, find the code #define MIDRC and change it to your center value. Also, if the channel values jump around a bit(jitter + or - a few) and cause minor drift, find #define DEADBAND and uncomment it to enable a deadband around the pitch/roll stick centers.
Check for Gyro Orientation
-Then click on the attitude meter so that it changes to pitch/roll indicators. Now, when you tilt your quad to the left, the roll line should tilt to the quad angle. Check the same for pitch(front/back tilting). If pitch/roll don't line up with the quad, then you'll need to change the GYRO_ORIENTATION part of the config code. It looks like this:
#define GYRO_ORIENTATION(X, Y, Z) {gyroADC[ROLL] = -Y; gyroADC[PITCH] = X; gyroADC[YAW] = Z;} Specifically, if it rolls right when you tilt it left, -Y would become Y.
So, say pitch and roll are switched, you need to change (X, Y, Z) to (Y, X, Z). Y is pitch, X is roll, and Z is Yaw. If roll was reversed(whwen you tilt the quad left, mw-wingui shows it tilting right, for example), you'd need to change gyroADC[ROLL] = -Y to gyroADC[ROLL] = Y. Note the "-" sign.
-If your quad is "yawing" the wrong way find the #define YAW_DIRECTION 1 part and comment it out and uncomment the #define YAW_DIRECTION -1 line. If you push the yaw stick right the front of the multirotor should turn right
Check for Motor Rotation
Look here under Connecting Motors and Servos to find motor rotation(arrows around the motors) for all types of multirotors. If the motor is spinning the wrong way, switch any two wires (of the three going to the motor) and it will reverse direction. It also shows, as i said before, the port that the ESCs should be connected to on the FC(numbers in the motors).
ESC Setup
This is done after the TX channels are set to 1095/1500/1905.
To set the throttle range of the ESCs:
Do this for each ESC. You can also get/make a 1-4 adapter so you can program all of them at once.
1. Connect the ESC to the throttle channel of the receiver (In my case it was ch3). Make sure the motor is connected to the ESC, as it produces the diagnostic beeps, but no props on because a malfunction may cause a prop to go spinning around at 100% throttle...
2. Turn on the radio and put the throttle stick to maximum position
3. Now connect the ESC to the battery
4. The motor should do a 1 2 3 beep followed by two short beeps. Immediately after the two
short beeps, put the throttle stick down all the way, the motors should make 3 short beeps
(representing the 3 cells of the battery) and then finally make a 1 long beep, indicating that the
throttle range has been set (calibrated).
To configure the other ESC settings(this can be done before the TX channels are 1095/1500/1905, though):
There are two options here: a programming card or using "throttle stick programming". I somehow forgot to put the programming card in my shopping cart from the HK wish list, so, i had to use the second method. Its pretty similar to setting the throttle range until step 4.
1. Connect the ESC to the throttle channel of the receive (In my case it was ch3). Make sure the motor is connected to the ESC, as it produces the diagnostic beeps, but no props on because a malfunction may cause a prop to go spinning around at 100% throttle...
4. Wait for a musical tune from the ESC
5. After the tone should be a sequence of beeps: setting after "(...)" is what it should be
one short beep is the brake setting(off, on) off
two short beeps is battery type(Li-xx, Ni-xx) Ni-xx
three short beeps is cut off type(Soft-Cut, Cut-off) Soft-Cut
four short beeps is cut off voltage(Low, Med, High) Low
one long is startup mode(Normal, Soft, Very Soft) Normal
one long and a short beep is timing(Low, Med, High) Med is typical.
one long and two short is factory reset
two long beeps is end setup mode and resumes normal operation.
Then it plays the musical tone and loops through the beeps again.
6. To select a setting to change, wait until right after the correct beep code(step 5), and then quickly bring the throttle stick down. This selects the setting.
7. Now, the ESC should beep a few times depending on how many options the particular setting has. To set the option(in parentheses in step 5), just move the throttle stick back up immediately after the correct option beep. The ESC will then continue with the sequence of beeps until it is unconnected or the "exit setup" setting is selected.
That was probably confusing, watch this video instead.
Before you Fly
General checks:
-make sure all connections are tight
-TX in the right mode etc
-nothing loose
-etc
-do training in flight sim:
Follow this guide: HobbyKing Forums - How-to: Using your transmitter for simulator use. Make sure you turn on training mode( Menu/ Func/Trainer), and don't turn on the TX power when using it for the simulator as it seems to not work(will turn on automatically when the the audio cable is plugged in). That was how it worked at first, but then it stopped working and the power switch, along with the trainer switch, had to be on for it to work! Its so weird. After i got the er9x firmware on it, i have had no issues!
sirbow2 is offline Find More Posts by sirbow2
Old Aug 25, 2012, 01:22 PM
sirbow2 is offline
Emress
Joined Nov 2011
Post Setup "Stuff"
Battery Mod
This is almost a must do because the stock AA holder is very unreliable and can become disconnected during flight(yikes, quad on the loose...). I've seen two main fixes for this; Li-Ion batteries, or Li-Fe/Po transmitter packs. I got a Turnigy 2650mAh 3S 1C LLF Tx Pack (Futaba/JR) because this one gives the most space in the battery box for the connectors!
My TX LiPo in the 9x
Trainer Mode Fix
I did this mod so that i don't have to unplug the transmitter module in the TX every time I want to do trainer mode or use the 9x for a simulator.
First, take out all the screws in the back of the case
and unplug the cable connecting the two halves.
Look at the back half and find the trace pointed to in the picture.
Cut the trace with an knife and make sure that it is cut with a multimeter. Now, you have two options; you can put a 1k resistor in between the two blue circled solder points, or, you can scrape off the light green part above and below the trace until you hit copper, and then solder the 1k resistor on the two scraped off places.
Done!
er9x Firmware
This mod replaces the stock Turnigy firmware and replaces it with the er9x firmware which has way more features, and maybe even the best part; it disables the beeper if you want! This requires a AVR ISP of some sort; i used a Arduino, but those other fancy ones work too . You''ll obviously need to crack open your case, so you might as well do the trainer mode fix at the same time.
Inside the TX
Once you have your TX open, solder wires onto the labeled solder pads.
Then, label the other ends of the wires so you don't mix them up later(that would be bad).
You can either just have a cable that comes out(through a pre-made hole in the battery compartment), or you can cut a little hole in the case a put a standard ISP header in there like i did..
Now you need to get the Arduino ready. ...And this is where it went all wrong. Apparently the Arduino ISP sketch that is provided with the IDE isn't fully working in 1.0, so i had to change a few things to get it to work.
1. The serial buffer size needs to be changed so that the Arduino can keep up with the data(er9x firmware) being sent to it over serial. To do this, find your arduino directory(arduino-1.0 somewhere), then go to: arduino-1.0\hardware\arduino\cores\arduino\ and open HardwareSerial.cpp in a text editor. Search for #define SERIAL_BUFFER_SIZE and change its value from 64 to 128.
2. The current Arduino ISP sketch cant handle the large EEPROM, so use this sketch instead. Upload it now:
Code:
// this sketch turns the Arduino into a AVRISP
// using the following pins:
// 10: slave reset
// 11: MOSI
// 12: MISO
// 13: SCK
// Put an LED (with resistor) on the following pins:
// 9: Heartbeat - shows the programmer is running
// 8: Error - Lights up if something goes wrong (use red if that makes sense)
// 7: Programming - In communication with the slave
// October 2010 by Randall Bohn
// - Write to EEPROM > 256 bytes
// - Better use of LEDs:
// -- Flash LED_PMODE on each flash commit
// -- Flash LED_PMODE while writing EEPROM (both give visual feedback of writing progress)
// - Light LED_ERR whenever we hit a STK_NOSYNC. Turn it off when back in sync.
// October 2009 by David A. Mellis
// - Added support for the read signature command
// February 2009 by Randall Bohn
// - Added support for writing to EEPROM (what took so long?)
// Windows users should consider WinAVR's avrdude instead of the
// avrdude included with Arduino software.
// January 2008 by Randall Bohn
// - Thanks to Amplificar for helping me with the STK500 protocol
// - The AVRISP/STK500 (mk I) protocol is used in the arduino bootloader
// - The SPI functions herein were developed for the AVR910_ARD programmer
// - More information at http://code.google.com/p/mega-isp
#include "pins_arduino.h"  // defines SS,MOSI,MISO,SCK
#define SCK 13
#define MISO 12
#define MOSI 11
#define RESET 10
#define LED_HB 9
#define LED_ERR 8
#define LED_PMODE 7
#define PROG_FLICKER true
#define HWVER 2
#define SWMAJ 1
#define SWMIN 18
// STK Definitions
#define STK_OK 0x10
#define STK_FAILED 0x11
#define STK_UNKNOWN 0x12
#define STK_INSYNC 0x14
#define STK_NOSYNC 0x15
#define CRC_EOP 0x20 //ok it is a space...
void pulse(int pin, int times);
void setup() {
  Serial.begin(19200);
  pinMode(LED_PMODE, OUTPUT);
  pulse(LED_PMODE, 2);
  pinMode(LED_ERR, OUTPUT);
  pulse(LED_ERR, 2);
  pinMode(LED_HB, OUTPUT);
  pulse(LED_HB, 2);
int error=0;
int pmode=0;
// address for reading and writing, set by 'U' command
int here;
uint8_t buff[256]; // global block storage
#define beget16(addr) (*addr * 256 + *(addr+1) )
typedef struct param {
  uint8_t devicecode;
  uint8_t revision;
  uint8_t progtype;
  uint8_t parmode;
  uint8_t polling;
  uint8_t selftimed;
  uint8_t lockbytes;
  uint8_t fusebytes;
  int flashpoll;
  int eeprompoll;
  int pagesize;
  int eepromsize;
  int flashsize;
parameter;
parameter param;
// this provides a heartbeat on pin 9, so you can tell the software is running.
uint8_t hbval=128;
int8_t hbdelta=8;
void heartbeat() {
  if (hbval > 192) hbdelta = -hbdelta;
  if (hbval < 32) hbdelta = -hbdelta;
  hbval += hbdelta;
  analogWrite(LED_HB, hbval);
  delay(40);
void loop(void) {
  // is pmode active?
  if (pmode) digitalWrite(LED_PMODE, HIGH);
  else digitalWrite(LED_PMODE, LOW);
  // is there an error?
  if (error) digitalWrite(LED_ERR, HIGH);
  else digitalWrite(LED_ERR, LOW);
  // light the heartbeat LED
  heartbeat();
  if (Serial.available()) {
    avrisp();
uint8_t getch() {
  while(!Serial.available());
  return Serial.read();
void fill(int n) {
  for (int x = 0; x < n; x++) {
    buff[x] = getch();
#define PTIME 30
void pulse(int pin, int times) {
  do {
    digitalWrite(pin, HIGH);
    delay(PTIME);
    digitalWrite(pin, LOW);
    delay(PTIME);
  while (times--);
void prog_lamp(int state) {
  if (PROG_FLICKER)
    digitalWrite(LED_PMODE, state);
void spi_init() {
  uint8_t x;
  SPCR = 0x53;
  x=SPSR;
  x=SPDR;
void spi_wait() {
  do {
  while (!(SPSR & (1 << SPIF)));
uint8_t spi_send(uint8_t b) {
  uint8_t reply;
  SPDR=b;
  spi_wait();
  reply = SPDR;
  return reply;
uint8_t spi_transaction(uint8_t a, uint8_t b, uint8_t c, uint8_t d) {
  uint8_t n;
  spi_send(a);
  n=spi_send(b);
  //if (n != a) error = -1;
  n=spi_send(c);
  return spi_send(d);
void empty_reply() {
  if (CRC_EOP == getch()) {
    Serial.print((char)STK_INSYNC);
    Serial.print((char)STK_OK);
  } else {
    error++;
    Serial.print((char)STK_NOSYNC);
void breply(uint8_t b) {
    Serial.print((char)b);
  else {
    error++;
void get_version(uint8_t c) {
  switch(c) {
  case 0x80:
    breply(HWVER);
    break;
  case 0x81:
    breply(SWMAJ);
    break;
  case 0x82:
    breply(SWMIN);
    break;
  case 0x93:
    breply('S'); // serial programmer
    break;
  default:
    breply(0);
void set_parameters() {
  // call this after reading paramter packet into buff[]
  param.devicecode = buff[0];
  param.revision = buff[1];
  param.progtype = buff[2];
  param.parmode = buff[3];
  param.polling = buff[4];
  param.selftimed = buff[5];
  param.lockbytes = buff[6];
  param.fusebytes = buff[7];
  param.flashpoll = buff[8];
  // ignore buff[9] (= buff[8])
  // following are 16 bits (big endian)
  param.eeprompoll = beget16(&buff[10]);
  param.pagesize = beget16(&buff[12]);
  param.eepromsize = beget16(&buff[14]);
  // 32 bits flashsize (big endian)
  param.flashsize = buff[16] * 0x01000000
    + buff[17] * 0x00010000
    + buff[18] * 0x00000100
    + buff[19];
void start_pmode() {
  spi_init();
  // following delays may not work on all targets...
  pinMode(RESET, OUTPUT);
  digitalWrite(RESET, HIGH);
  pinMode(SCK, OUTPUT);
  digitalWrite(SCK, LOW);
  delay(50);
  digitalWrite(RESET, LOW);
  delay(50);
  pinMode(MISO, INPUT);
  pinMode(MOSI, OUTPUT);
  spi_transaction(0xAC, 0x53, 0x00, 0x00);
  pmode = 1;
void end_pmode() {
  pinMode(MOSI, INPUT);
  pinMode(SCK, INPUT);
  pinMode(RESET, INPUT);
  pmode = 0;
void universal() {
  int w;
  uint8_t ch;
  fill(4);
  ch = spi_transaction(buff[0], buff[1], buff[2], buff[3]);
  breply(ch);
void flash(uint8_t hilo, int addr, uint8_t data) {
  spi_transaction(0x40+8*hilo,
  addr>>8 & 0xFF,
  addr & 0xFF,
  data);
void commit(int addr) {
  if (PROG_FLICKER) prog_lamp(LOW);
  spi_transaction(0x4C, (addr >> 8) & 0xFF, addr & 0xFF, 0);
  if (PROG_FLICKER) {
    delay(PTIME);
    prog_lamp(HIGH);
//#define _current_page(x) (here & 0xFFFFE0)
int current_page(int addr) {
  if (param.pagesize == 32) return here & 0xFFFFFFF0;
  if (param.pagesize == 64) return here & 0xFFFFFFE0;
  if (param.pagesize == 128) return here & 0xFFFFFFC0;
  if (param.pagesize == 256) return here & 0xFFFFFF80;
  return here;
void write_flash(int length) {
  fill(length);
    Serial.print((char) STK_INSYNC);
    Serial.print((char) write_flash_pages(length));
  } else {
    error++;
    Serial.print((char) STK_NOSYNC);
uint8_t write_flash_pages(int length) {
  int x = 0;
  int page = current_page(here);
  while (x < length) {
    if (page != current_page(here)) {
      commit(page);
    flash(LOW, here, buff[x++]);
    flash(HIGH, here, buff[x++]);
    here++;
  commit(page);
  return STK_OK;
#define EECHUNK (32)
uint8_t write_eeprom(int length) {
  // here is a word address, get the byte address
  int start = here * 2;
  int remaining = length;
  if (length > param.eepromsize) {
    error++;
    return STK_FAILED;
  while (remaining > EECHUNK) {
    write_eeprom_chunk(start, EECHUNK);
    start += EECHUNK;
    remaining -= EECHUNK;
  write_eeprom_chunk(start, remaining);
  return STK_OK;
// write (length) bytes, (start) is a byte address
uint8_t write_eeprom_chunk(int start, int length) {
  // this writes byte-by-byte,
  // page writing may be faster (4 bytes at a time)
  fill(length);
  prog_lamp(LOW);
  for (int x = 0; x < length; x++) {
    int addr = start+x;
    spi_transaction(0xC0, (addr>>8) & 0xFF, addr & 0xFF, buff[x]);
    delay(45);
  prog_lamp(HIGH);
  return STK_OK;
void program_page() {
  char result = (char) STK_FAILED;
  int length = 256 * getch() + getch();
  char memtype = getch();
  // flash memory @here, (length) bytes
  if (memtype == 'F') {
    write_flash(length);
    return;
  if (memtype == 'E') {
    result = (char)write_eeprom(length);
      Serial.print(result);
    } else {
      error++;
    return;
  Serial.print((char)STK_FAILED);
  return;
uint8_t flash_read(uint8_t hilo, int addr) {
  return spi_transaction(0x20 + hilo * 8,
    (addr >> 8) & 0xFF,
    addr & 0xFF,
    0);
char flash_read_page(int length) {
  for (int x = 0; x < length; x+=2) {
    uint8_t low = flash_read(LOW, here);
    Serial.print((char) low);
    uint8_t high = flash_read(HIGH, here);
    Serial.print((char) high);
    here++;
  return STK_OK;
char eeprom_read_page(int length) {
  // here again we have a word address
    int addr = start + x;
    uint8_t ee = spi_transaction(0xA0, (addr >> 8) & 0xFF, addr & 0xFF, 0xFF);
    Serial.print((char) ee);
  return STK_OK;
void read_page() {
  char result = (char)STK_FAILED;
  if (CRC_EOP != getch()) {
    error++;
    return;
  if (memtype == 'F') result = flash_read_page(length);
  if (memtype == 'E') result = eeprom_read_page(length);
  return;
void read_signature() {
    error++;
    return;
  uint8_t high = spi_transaction(0x30, 0x00, 0x00, 0x00);
  uint8_t middle = spi_transaction(0x30, 0x00, 0x01, 0x00);
  Serial.print((char) middle);
  uint8_t low = spi_transaction(0x30, 0x00, 0x02, 0x00);
  Serial.print((char) STK_OK);
int avrisp() {
  uint8_t data, low, high;
  uint8_t ch = getch();
  switch (ch) {
  case '0': // signon
    error = 0;
    empty_reply();
    break;
  case '1':
    if (getch() == CRC_EOP) {
      Serial.print("AVR ISP");
    break;
  case 'A':
    get_version(getch());
    break;
  case 'B':
    fill(20);
    set_parameters();
    empty_reply();
    break;
  case 'E': // extended parameters - ignore for now
    fill(5);
    empty_reply();
    break;
  case 'P':
    start_pmode();
    empty_reply();
    break;
  case 'U': // set address (word)
    here = getch() + 256 * getch();
    empty_reply();
    break;
  case 0x60: //STK_PROG_FLASH
    low = getch();
    high = getch();
    empty_reply();
    break;
  case 0x61: //STK_PROG_DATA
    data = getch();
    empty_reply();
    break;
  case 0x64: //STK_PROG_PAGE
    program_page();
    break;
  case 0x74: //STK_READ_PAGE 't'
    read_page();
    break;
  case 'V': //0x56
    universal();
    break;
  case 'Q': //0x51
    error=0;
    end_pmode();
    empty_reply();
    break;
  case 0x75: //STK_READ_SIGN 'u'
    read_signature();
    break;
  // expecting a command, not CRC_EOP
  // this is how we can get back in sync
  case CRC_EOP:
    error++;
    break;
  // anything else we will return STK_UNKNOWN
  default:
    error++;
      Serial.print((char)STK_UNKNOWN);
    else
Now for the Arduino hardware side:
1. Unplug your Arduino form the computer and connect the wires from the TX that you just soldered as follows:
Arduino Pin: 9x transmitter
10: RST
11: MOSI
12: MISO
13: SCK
5v: 5v
Gnd: Gnd
2. Put a 120ohm resistor between +5v and Reset on the Arduino. This stops the Arduino from rebooting in the ISP process.
Next up is the er9x firmware buring software.
1. Download and isntall it from here.
2. When you open it, it should ask if you want to download the latest er9x firmware, click yes.
3. Go to burn->configure in the eepe software
select the avrisp programmer.
select m64 mcu.
select port your Arduino is connected to.
type -b 19200 in extra arguments.
4. You should probably backup the firmware, memory and EEPROM using the options in the burn menu( i didn't...oops) in case of an issue with the er9x firmware.
5. Go to burn->Flash Firmware to TX and select the firmware you saved from step 2.
6. Should say complete after a minute or two!
MWC ER9x Setup
First, you need to calibrate the sticks so that the TX knows how far the sticks can move. My values were completely wrong when i first flashed the er9x firmware, so this is required.
1. Press and hold the + button for a second to get into the radio setup menu.
2. Press + again to get to screen 6/6
3. Follow onscreen instructions.
Next, I changed some cosmetic settings.
1. go to the Radio Setup menu again and go to 1/6, Use the UP/DN buttons to move between options.
2. Set the Owner Name by moving to it and then pressing Menu. Now use UP/DN to change the character and +/- to change position in the name.
3. I also changed the Beeper(how loud it is), Battery Warning(good for use with LiPos), and Inactivity Alarm(if i forget to turn it off ) options here. You can change the TX Mode at the very last option(default is 2).
Now for the more useful mixing, trim, channel setup.
1. From the home screen, press and hold the - button for a second to get into the Model Setup screen.
2. All of the lines should be blank and the first one having a * next to it meaning it is selected.
3. Now press - to go to 2/10; Name, Trim Inc, Proto PPM, E. Limits, and Trainer are the settings you might have to change.
4. Go to the 10/10 menu and select the Simple 4Ch Template; its a good way to start.
5. Go to 5/10; this has tons of features, but all we want to do is change which channels output what signal. Move down until Ch1 is selected, then press menu. The top option of the menu is the only one that needs to be changed. I choose AIL(roll) because the Ch1 port on the RX is connected to the roll pin on the MWC board. Once you have the correct setting, press exit. Now go down until Ch2 is underlined and do the same as you did for Ch1. And then for Ch3, Ch4, Ch5(AUX 1 for me), Ch6(AUX 2 for me).
AIL is roll, ELE is pitch, THR is throttle, RUD is yaw, P1 is the Hov.Pit pot, P2 is the Gear pot, P3 is the Pit. Trim pot.
6. Go to 6/10; this allows you to change Subtrim(what the center value of the stick is when centered), and End Points(what the values are for when the stick is all the way UP/DN or L/R.) Subtrim for each channel needs to be at 1500, and the low point needs to be 1000, high point 2000. They wont be perfect, but get them as close as possible(you can set a dead zone with the MWC code if you need too). The first column is Subtrim, next is low point, last is high point. The row is for each channel that you just set is step 5. So, use UN/DN to move between channels, and +/- to move between Subtrim/low/high, Menu to select value to change, then +/- to change value, Menu to finalize value. This is where the MWC computer GUI comes in; it allows you to see in live time where the center is of each channel and how high/low they go. So, get your quad all powered up and connected to the GUI.
a. Move all sticks(and AUX pots) to center, and then set the subtrim with +/- for each channel so that all values in the GUI are very close to 1500.
b. Setting low/high points; for Ch1 I choose AIL(roll), so ill select the low point for Ch1, move the AIL(roll) stick all the way to the left, then adjust the vlaue with +/- until it is at 1000 int the GUI for roll. Then I'll select the high point and move the stick all the way to the right and then adjust the vlaue with +/- until it is at 2000 int the GUI for roll.
Aux Switches/Channels
Here i will go through how to setup two Aux channels(5+6) for the 3pos F.MODE switch and the 2Pos AIL switch.
1. Go to the Mixer(5/10) and go down so that your first Aux channel(most likely CH5) is underlined and hold menu(this creates a MIX in CH5).
2. Source should be Half, Weight -100, then go down to Switch, and change it to ID0. Go back to the previous menu(EXIT button).
3. Make sure CH5 is underlined again and hold menu. This creates another MIX in CH5.
4. Source should be Half, Weight 100, then go down to Switch, and change it to ID2. Go back to the previous menu.
5. Done with 3Pos.
6. Move the cursor so that CH6 is underlined and hold menu.
7. Source should be FULL, Weight 100, then go down to Switch, and change it to AIL. This is not the AIL stick, it is the AIL switch; this also applies for the ELE, THR, RUD switches. Look at page 9 of the manual PDF to see the names of the switches(or just look on the TX). Go back to the previous menu.
8. Done! Now go to the main screen and press DN until you get to the screen that shows you the current values of the channels. Test the switches. Now you can go into the MitiWii config GUI and change the function of the switches.
What about Trainer mode?
1. After i got all of the stuff setup for regular control, i went back to 1/10 in the Model Setup menu, moved to the model I made, and held down Menu(this duplicates the model). Then i changed the name to Trainer or something so i could distinguish between the two. Then i went to the Radio Setup 1/6, and turned on trainer mode.
2. 2/6 of Radio Setup is the Trainer menu. The THR on the left stands for your THR channel. Change OFF to := if you want the trainer to have complete control of the channel, += means they have partial control. Change the % to the percentage of the channel you want the trainer to control. Then change the ch1 to the channel of the trainer that is THR(or AIL or whatever).
9x TX Module Upgrade
This is pretty much essential for any form of FPV or "peace of mind" and there are two options(IMO): FrSky or UHF. FrSky is better, but only goes about 2.5km max(some new antennas might help), so it wold be for close FPV or LOS. UHF is the best and definitely more expensive, but can give you tens of km of range which is very good for FPV.
EzUHF install:
1. Get the UHF TX, and the UHF RX from HK.
2. Unplug the stock TX module from the back of the TX and cut the antenna wire(colored gray on the 9x).
3. Now you need to connect the UHF TX to the 9x. You can either do this by getting a Trainer port Adapter(then you have to power the TX from the DC barrel jack), or you can modify the servo style connector from the picture of the UHF TX link from HK.
The Trainer port one is self-explanatory: Plug in the adapter to the Trainer port of the 9x and the other end to the "R/C Tx PPM In" port on the UHF TX.
The second option is more complex, but better in the end. Below is the pin-out of the JR style connector in the TX module compartment of the 9x:
Cutoff the 3pin connector the the servo style connector, and somehow connect:
Black -> GND
Red-> Bat+
White -> MOD(PPM)
4. Now you have to somehow attach the new UHF TX to the 9x case.
5. Connect the Antenna to the UHF TX and you are now done with basic setup. But, if you used the Trainer port to connect the UHF TX, you need a male to male DC barrel jack extender cable to connect the UHF TX and the 9x. Connect one side of the cable to the UHF TX and the other to the side of the 9x (another barrel jack). The jack on the 9x links directly to the battery, so you must put a switch in there s o you don't drain the battery with the UHF TX even when the 9x is off.
6. Finally, you can read the manual for the rest (binding etc)
FrSky Install:
FPV
General Problems
ESC smokes: try switching the bad ESC with a working one to see if it is the ESC or motor(if the new ESC smokes, it is the motor and if the new ESC doesn't smoke, it was just a bad ESC) OR switch the motor with another known good one. if the ESC still smokes then it is the ESC, if it doesnt smoke again, it was the motor(touching phases), but that requires that the ESC works (the one that smoked).
PID Tuning
This will make your quad way more stable. I can guarantee that everyone's PID settings are different because all quads are slightly different in structure. Here are some guides until i figure out how to explain it: http://www.rcgroups.com/forums/showthread.php?t=1375728
http://www.rcgroups.com/forums/showt...&#post17216625
http://www.rcgroups.com/forums/showp...postcount=7460
http://www.rcgroups.com/forums/showt...5#post17311692
Here are some short how-to statements:
P: This is probably the easiest. if the quad oscillates by shaking it or in flight, lower P. if it doesn't oscillate then increase P until it does and the decrease a bit until it is stable.
I: "An easy way I found to get the "I" value right.. I run up the motors while holding it above my head then pull back some pitch to tilt the quad up at the front, if it falls back level again then I will increase I until it just stays there.."
D: This is how fast the multirotor moved on the axis. if it is sluggish, increase D (remember, that means a LOWER number as it is a negative value). If you have oscillations you can either decrease D (remember, that means a HIGHER number as it is a negative value - i.e. further negative from zero) or P.
"PID" Stand
This is a most times wooden stand that limits the quad to one axis of rotation(pitch or roll). It limits the quad to one axis(roll or pitch) and is used to do PID tuning. Mine is quite simple; just a "+" shaped base with two support 2x4s that have some 1/2in PVC mounts for the quad arms.
After doing some more tuning, i find it easier to just go fly it after making changes rather than using this thing.
ESC Flashing
Flashing the ESCs with a after market will provide a much more stable multirotor. Check out the Atmel(by Britt) or the Silabs(by me) flashing guides at oddcopter.com.
Prop Balancing
This is quite simple too; a square base with two hard drive magnets mounted about 4in away from each other on some scrap wood. In the center is a simple piece of all thread ground to a point to reduce the friction on the one end that does touch the magnet(one end is floating, one is on the magnet).
To balance the props, find which side is heavier using the balancer and add some sticky tape to the tip of the leading edge of the lighter side. Some people also remove some material on the heavy side instead.
ACC Tuning
The ACC(accelerometer) keeps the quad at a constant level, except for pitch/roll stick input and then snaps back to level, and always needs trimming from default settings. You can do ACC trimming without a PID stand, it just probably harder. To trim the accelerometer so that it holds the quad level, do the following;
1. Put the quad into level mode with the Aux channel and attempt to lift off. It will most likely not lift-off level. Note which side(or sides) that lift of first.
2. Disable the motors(double check), and move the throttle to 100%.
3. If your right motor lifted off first, for example, you need to trim in that direction. So, move the roll stick to the right, hold it for about a second, and then bring it back to center. This is one "tick" and if you have a LED on your FC, you will see it blink for each tick.
4. This one tick may not be enough, so you need to arm the motors again and see if it is level. If not level, repeat #3.
Motor Rewinding
Rewinding a motor isn't that hard, just look at this site. You need to make sure you have the correct number of turns on each tooth, the correct termination(delta or wye), correct wire size, and the winding type(LRK,dLRK, ABC).
In my case:
The motor was originally 924kV, so from this picture i can tell that i need 12 turns and delta termination(delta because that's what the motor was when i took it apart). For wire size: the bigger the better, but you must still be able to fit all the windings on the teeth, and in my case someone said 25AWG would work. I went to a nearby 3E and got some 25AWG clear enameled magnet wire. The motor had 12 teeth and 14 magnet, so i had to use the dLRK winding method. Always wind the wire clockwise on the stator tooth(that is unless you're doing dLRK in which some are CCW).
Done rewinding...you can see the sharpie mark i used for marking a tooth as the starting point.
My (re)Builds
First
I learned A LOT from this first build of my quad copter
- the arm mount/center hub idea didn't work to well, neither did the motor mounts.
- get some CF mounts for the arms (for center plate and motors) that don't put holes in the CF arms.
-still haven't really decided on a battery holder on landing gear.
-pay attention to how you put the props on
-thoroughly research prop + amp draw.
I put some blue tape roughly where I needed to cut and then marked exactly where i needed with a pencil.
Done cutting
Again used blue tape so that i can mark my holes. Both pieces of CF are taped together so that the holes will line up perfectly.
3/8in(10mm) "+" pencil colored shape is where the square tube would sit when assembled. Not perfectly lined up holes, but it worked out fine.
CF pieces will assemble to the blue highlighted CF piece.
Motor mounted.
Done!
Second Build
Made a few changes:
-using pool noodles for landing gear
-props on correctly :P
-smaller battery; the 4000mah works pretty good too. the flights are really long
-drilled four holes into the arms so that i cant bolt it directly to the frame and motors (bad idea).
-FC a bit cleaner, still need to mount better.
Third Build
-Still using CF, but had dowel and guerrilla glue inserts- really strong!
-Real battery holder.
-Proper FC mount.
Dowel and guerrilla glue insert
Hiding the power spider in between the CF plates this time!
Looks much better.
Battery strap holder.
New proper FC mount.
Need to tie down motor wires, ESCs, and RX.
Fourth Build
-This is the current build and is in the build log section above
After thoughts...
Always double check your prop orientation--it can cause many issues if you think you have them on right when they aren't(guess how i know...).
Be nice to your motors! Don't put the props on upside down/too big of props and cause the to burn out. Some other motor alternatives for this size of quad are the: Turnigy 2217 16turn, KD A22-20L, A20-20L, or Turnigy D3530/14. The 22-20Ls would probably the most powerful of the bunch. flybrushless and ecalc are very helpful for finding the right prop.
Get a 2200mah 3s LiPo(or so) instead of a 4000mah like i did. The 2200 is about 40% of the weight and so the motors don't have to work as hard to lift the quad, thus have lower amp draw, and the quad will be more agile, but not fly as long because of the lower capacity.
I would recommend this IOI FC board for multiwii as it is even cheaper than my DIY FC solution was and has more sensors!
Hide the ESCs in the center of the frame as it looks so much nicer!
Get some F-30A(almost the cheapest for good multi use) ESCs and flash them with SimonK firmware
Unless you have access to a CNC or similar, it's a good idea not to build your first frame .
Old Aug 25, 2012, 01:28 PM
sirbow2 is offline
Emress
Joined Nov 2011
This guide was copied from my blog so that it is easier to acess and will help more people. still being converted...
hope you enjoy it!
Old Aug 25, 2012, 02:27 PM
TS00 is offline
Find More Posts by TS00
Ape-pilot Extraordinaire
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
Very nice writeup.
What are those blue motors?
TS00 is offline Find More Posts by TS00
Old Aug 25, 2012, 03:10 PM
sirbow2 is offline
Emress
Joined Nov 2011
Originally Posted by TS00 View Post
Very nice writeup.
they are hacker clone 20-22l (as said in the build).
Old Aug 25, 2012, 03:11 PM
TS00 is offline
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
Sorry, missed that bit. Do you like them?
Old Aug 25, 2012, 07:39 PM
sirbow2 is offline
Emress
Joined Nov 2011
yeah. worked great for mine. very well balanced out of the box.
Old Aug 27, 2012, 07:41 AM
CH33ZEBURG3R is offline
Find More Posts by CH33ZEBURG3R
Australia, VIC, Frankston
Joined Jul 2012
Nice work, i'll be reading up on a few things before i fly, first i'll get some simulator practice in.
Good read ;o)
CH33ZEBURG3R is offline Find More Posts by CH33ZEBURG3R
Old Aug 27, 2012, 03:30 PM
cr8tive_leo is offline
Find More Posts by cr8tive_leo
cr8tive_leo's Avatar
Canada, ON, Cochrane District
Joined Oct 2011
Since when does a 9x have 6v? either 3.3 or 5v. Where did 6v come into play?
Nice write up btw.
cr8tive_leo is offline Find More Posts by cr8tive_leo
Old Aug 27, 2012, 04:17 PM
sirbow2 is offline
Emress
Joined Nov 2011
that's just some random image not of a 9x. a JR compatible one, though. just checked mine. there is nothing on that pin. will update.
Old Aug 28, 2012, 05:15 AM
dogz85 is offline
Find More Posts by dogz85
Australia, VIC, Shepparton
Joined Jun 2008
great guide, needs a sticky
dogz85 is offline Find More Posts by dogz85
Old Sep 11, 2012, 08:38 PM
WinterDevil is offline
Find More Posts by WinterDevil
WinterDevil's Avatar
Canada, QC, Sherbrooke
Joined Aug 2012
wow.. this is a great beginers post, I was looking for something like this thank you!
WinterDevil is offline Find More Posts by WinterDevil
Old Nov 10, 2013, 06:02 PM
adrixs3103 is offline
Find More Posts by adrixs3103
Joined Nov 2013
Hello
I was just wondering i am getting a MultiWii pro FC is that good for this type of quadcopters? thank you.
adrixs3103 is offline Find More Posts by adrixs3103
Old Nov 10, 2013, 07:04 PM
sirbow2 is offline
Emress
Joined Nov 2011
yep. maybe not the best for beginners, though
Old Nov 10, 2013, 07:09 PM
Joined Nov 2013
Hello
And what do you recommend for beginners?
I am not a beginners though i was graduating from eng and this is a part of my senior project
Build Log Freewing 90mm F/A-18E Super Hornet build log, tips, tweaks, troubleshooting Mike_Then Foamy EDFs 4776 May 26, 2016 12:05 AM
Link RC kite build logs.. show your kite and link it to your build log davereap RC Paragliders and Kites 19 Mar 31, 2016 06:03 PM
Discussion Building tips or web logs for Aerosente Petrel anyone? tugboatq Scale Sailplanes 3 Dec 04, 2010 01:59 AM
Discussion Theory/testing of Nemisis type tip shape? kcaldwel Modeling Science 1 Jan 06, 2008 12:05 PM
