Old Aug 25, 2012, 06:19 AM
s.hantiu is offline
Find More Posts by s.hantiu
Joined Aug 2012
What kind of engines and propels should i buy?
Ok till now i have this:
-a nice frame (40 cm from one engine to other)
- 3S3P battery - 15.000 mah
-a total lbs of 2000 grams (actually 1800) but i already added the engines weight.
So what kind of engines and propellers do you suggest me for:
-fast speed
-to make it hover a very big time in the air?
s.hantiu is offline Find More Posts by s.hantiu
Old Aug 26, 2012, 04:12 AM
s.hantiu is offline
Joined Aug 2012
hahaha no answer for this one?
Old Aug 27, 2012, 03:10 AM
jsxx is offline
Find More Posts by jsxx
jsxx's Avatar
Wielka Brytania, Anglia, Derbyshire
Joined Jan 2011
-fast speed
How big is your battery?
2kg is way too much for 400 size quad.
jsxx is offline Find More Posts by jsxx
Old Sep 01, 2012, 01:34 PM
s.hantiu is offline
Joined Aug 2012
The 3 battery is waving around 1200 grams. You think i should buy a bigger frame ?
Old Sep 02, 2012, 10:22 AM
rampa202 is offline
Find More Posts by rampa202
United States, MD, Annapolis
Joined Jun 2011
Something is not right if the battery is 2/3rds the AUW of you quad. 15,000 mAh is more appropriate for an 800mm frame and some big motors I would think. I am going to be using 16,000 mAh on an 800 mm hexa with very powerful motors (3KG thrust each.)
Russ
rampa202 is offline Find More Posts by rampa202
Old Sep 02, 2012, 11:07 AM
s.hantiu is offline
Joined Aug 2012
By the way how much time do you think you could fly? Also from what a range can you see the quad by your eyes? 1 mile ?
Old Sep 02, 2012, 02:39 PM
jsxx is offline
jsxx's Avatar
Joined Jan 2011
Flight time should be around 3hours and 4.78 miles range ^_^
Old Sep 02, 2012, 03:11 PM
hexa is offline
Find More Posts by hexa
hexa's Avatar
United Kingdom, Scotland, Edinburgh
Joined Nov 2010
Are you building a b52 bomber?
hexa is offline Find More Posts by hexa
Old Sep 02, 2012, 03:15 PM
jsxx is offline
jsxx's Avatar
Joined Jan 2011
Build plane if you want to do long range. I multirotors are not for distance flying
Question What brand ESC should I buy? AZimmerer Power Systems 6 Jul 17, 2012 12:41 AM
Discussion What should i buy next??? smitty919 Parkflyers 6 Jun 28, 2012 01:19 PM
Help! What Kind Of Electric Plane Should I Buy ?? Help!!! zohaibim Electric Plane Talk 1 Nov 19, 2005 01:01 AM
Help! what kind of radio should i buy for cessna gas plane HELP! zohaibim Fuel Plane Talk 9 Nov 16, 2005 04:51 PM
