You need to have a good supply of X-acto blades for things like enlarging the servo hole's and cutting covering. Covering is really tough on blades and you always want a nice sharp one. You will need thin, med. and thick C.A. depending on what you are gluing and some C.A. debonder to clean up after yourself especially with C.A. hinges. I would want some 5 and 30 min. epoxy. Some low tack painters tape is handy as is some canopy glue. That and the usual assorted hand tools and you should be pretty good to go... BTW, I love Hanger 9 ARF's, and E-Flite Platinum series...Check out Heads Up RC for all your motor, ESC, and any other supplies, they can't be beat!! Dave/ZZ
Latest blog entry: My wind killer
Canopy magnets !! Great idea - but the cause of so many lost canopy's.
I salvage magnets from other planes etc. and add more if I really want to stay with magnets. But my main remedy is to fit a spring pin catch. http://www.hobbyking.com/hobbycity/s...0pcs_bag_.html A quick and easy fix and works with wood or foam material ... get an old servo arm ... take a thin long self-tapper and fix it via the servo centre hole on fuselage close to canaopy edge. It then rotates on the screw to provide a tab to hold down canopy. Nothing fancy .. just using up old scrap !! The problem you had with the tube and misplaced end is common and is why you need a length of wire at hand for such jobs. Another trick is to gently rub around the area and often you will 'feel' the hole .... I don't know what you used for for your pull-pull - but one of the best is fishing trace and crimps. For servo end I use brass screw ends ... http://www.hobbyking.com/hobbycity/s...0pcs_set_.html Passing trace wire through and crimping ... then a normal clevis gives you connection to servo arm and adjustment. I love pull-pull for rudder ... used it on all my biplanes before. Nigel |
| Thread Tools | |
| Discussion Getting ready for my first quad build - any tips? | pberge | Multirotor Talk | 7 | Aug 30, 2012 10:04 AM |
| Discussion f22 dapron build.....my first....any tips. | blackbrabus | Foamies (Scratchbuilt) | 3 | May 15, 2012 09:34 PM |
| Discussion first time using a lipo larger than 1s...a little nervous...any tips? | electricrc68 | Batteries and Chargers | 8 | Apr 09, 2012 01:07 PM |
| Discussion My first ARF build- tips? | revenant | Foamies (Kits) | 3 | Mar 25, 2008 02:01 PM |
