Old Aug 24, 2012, 03:34 PM
ElIntocable is offline
Find More Posts by ElIntocable
7.62x51
ElIntocable's Avatar
United States, LA, Shreveport
Joined Jul 2010
New Product
JR XG11 Owner's Thread
I figured I'd start a thread where users can share tips and tricks.
The UPS guy dropped it off about 20 minutes ago. You can see in the pics that it's a beefy radio compared to the DX8. I included a picture comparing the AR8000 to the the RG1131B. Here are some pics:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
ETA: If someone was curious as to what size a Pelican case they would need for the XG11, the 1450 is what you're looking for. I bought the 1450 and I also bought the 1550 to use a double case for days I'm taking the XG11 and DX8. I have the Spektrum single aircraft transmitter case from HH. The foam gets torn pretty easy and it's not as durable as a Pelican; granted the Pelican is more. I will continue to use the Spektrum case until I need to replace it with a 1450.
ElIntocable is offline Find More Posts by ElIntocable
Old Aug 25, 2012, 05:24 AM
Howard L is offline
Find More Posts by Howard L
United States, FL, Melbourne
Joined Jul 2005
The roller on my new XG11 has a good bit of play in both direcctions of rotation and makes the roller feel soft in use rather than crisp. I don't remember this being the case on past JR radios. Am I alone or is this part of the package.
Howard
Howard L is offline Find More Posts by Howard L
Old Aug 28, 2012, 11:40 AM
7.62x51
Joined Jul 2010
Howard
Mine definitely has a crisp feel with no play in the roller.
Old Aug 29, 2012, 12:16 AM
vlad_vy is offline
Find More Posts by vlad_vy
Joined Dec 2011
Mine has a good bit of play in both directions of rotation.
vlad_vy is offline Find More Posts by vlad_vy
Old Aug 29, 2012, 05:56 AM
Howard L is offline
Joined Jul 2005
Based on the two different responses I am guessing that both conditions may be the reality. The back and forth slop sure makes a difference in the tactile feel/feedback of the roller. It would sure be nice to hear from more folks about their respective XG11 and then to hear from JR about what it is suppose to be. Does anyone know of a JR team member that could act as an ombudsman on this issue? Thanks
Howard
Old Aug 29, 2012, 05:23 PM
SIRCOL is offline
Find More Posts by SIRCOL
Old and grumpy
SIRCOL's Avatar
Australia, QLD, Gold Coast
Joined Aug 2010
mine has a lot of movement nearly one flute on the roller
much more than my dsx9
SIRCOL is offline Find More Posts by SIRCOL
Old Aug 30, 2012, 05:28 AM
Howard L is offline
Joined Jul 2005
That pretty much describes how mine is also.
Howard
Old Aug 30, 2012, 06:36 AM
swk550 is online now
Find More Posts by swk550
United States, TX, Humble
Joined Aug 2004
I received my XG11 yesterday. The roller has the same "slop" as my trusty older 11X radio. I never had an issue scrolling the menu with the roller.
I was able to insert my SD card from the 11X into the XG11. I had no problem downloading the models I plan to fly on the XG11. Today i'll need to check sub-trims and make final set-ups on the XG11.
I did notice the XG11 had more of a light gun metal color as compared to the 11X chrome front plate.
Mine did come in the Mode 2 configuration. I did install the throttle ratchet and the travel limiters. It was easy to recalibrate all of the gimble movements. The manual has good instructions. It is much better than the 11X manual.
Binding is different, but easy. Just follow the instructions in the manual.
swk550 is online now Find More Posts by swk550
Old Aug 30, 2012, 11:42 PM
gjr. is offline
Find More Posts by gjr.
Glen
Nashville,TN
Joined Jan 2005
What is the breakdown of switch types on the transmitter? How many are 2 way, 3 way, and spring loaded? I did not see this information in the manual.
gjr. is offline Find More Posts by gjr.
Old Aug 31, 2012, 04:42 AM
SIRCOL is offline
Old and grumpy
SIRCOL's Avatar
Joined Aug 2010
trainer----------- spring loaded switch
throttle hold --- 2 pos switch
6 -----------------3 pos switch
total 8 switches
Old Sep 02, 2012, 05:10 AM
FLYINGBOXER is offline
Find More Posts by FLYINGBOXER
Fly to live, live to fly
FLYINGBOXER's Avatar
United States, FL, Miami
Joined Nov 2010
The play this roller has its completely normal, and its the same feeling that my previous jr 11x has.. As everybody knows its based on the same platform as the 11x, so no surprises here, therefore its an assurance that everything in this transmitter model was tested before...
Mine is working superb. 3 months with it and everything ok.. I am very happy with it...
I have a question to everyone else with the xg11 sold by HH (as mine was bought overseas at Rc711.com and its a native mode 1 converted to mode 2 by myself), how is the switch layout??, I mean the distribution of it, ie. trainer in the back left, rudder dual rate, t hold switch etc...
Thanks...
FLYINGBOXER is offline Find More Posts by FLYINGBOXER
Old Sep 02, 2012, 09:42 AM
Joined Aug 2004
My XG11 came as mode 2 from HH. The rudder dual rate switch is on the left hand side and the snap (spring loaded) and gear switches are on the right hand side. The elevator, aileron, flap and Aux 2 switch locations are the same location as the 11X. So far I am completely pleased with the quality of the XG11. When I used the 11X SD card to download some models to the XG11, all went fine. Some of the sub trims had to be adjusted. I did notice the mix functions in the XG11 program differently. The manual is much better and after a bit of trial and error, I got my mixes the same. In the air my Vanquish pattern plane felt the same.
I've got my red sticks extended full out. Is there a replacement stick that can give me and extra 6 to 10 mm (.25" to .375"in length?
Old Sep 02, 2012, 10:03 AM
Evan D is offline
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Since this is the "official" thread for this radio (I really hate people labeling things like that since it really isn't official in any way) can you compare it to other radios such as a 9503 or DX-18 as far as features, gimble spacing, switch placement, weight, programing, and both retail and on the street pricing.
Evan D is offline Find More Posts by Evan D
Old Sep 02, 2012, 08:35 PM
7.62x51
Joined Jul 2010
It's official in the sense that's its the first thread since it's been available. No need in having numerous threads on the same radio. Further, you can find weight and most of the comparisons by going online and taking a quick gander at the manuals. I know, that requires some effort, but it does provide results! :-)
Old Sep 13, 2012, 02:51 PM
7.62x51
Joined Jul 2010
After some thumbing time with my XG11, I have a very small amount of play with my roller.
Discussion Official Eflite UMX Mig 15 DF Owners Thread NitroCharged Micro EDF Jets and Power Systems 5608 Jan 10, 2016 02:28 AM
New Product New XG11 DMSS from JR hayataro Radios 189 Apr 06, 2014 04:39 PM
New Product JR XG6, XG8, XG11 in USA! Rudra Radios 79 Nov 16, 2013 12:47 PM
Discussion The Official Teen Chit Chat Thread (Always Off Topic) Alex Schauer Chit Chat 31697 Aug 27, 2013 07:56 PM
Discussion JR XG11 using 2 RG813B receivers piperjon Radios 6 Apr 18, 2012 06:54 AM
