Old Aug 24, 2012, 03:21 PM
GuerillaFilm is offline
Find More Posts by GuerillaFilm
GuerillaFilm's Avatar
Iceland
Joined May 2012
Which FPV Transmitter Battery Should I get?
It's my first time hooking up an FPV transmitter to my Naza F450 and I forgot to order a battery. What type and size battery should I get? Anyone recommend a certain brand?
Here a some pics of my transmitter and the battery connector:
This is the transmitter I got: http://www.hobby-wing.com/pfv-fever-...p-systems.html
GuerillaFilm is offline Find More Posts by GuerillaFilm
Old Aug 24, 2012, 04:00 PM
terabyte is offline
Find More Posts by terabyte
United States, FL, Fort Lauderdale
Joined Jul 2012
just use a ubec which will allow you to use the same batt as your quad but clean up the power so there are no problems with your video Tx and dirty power.
terabyte is offline Find More Posts by terabyte
Old Aug 24, 2012, 05:54 PM
Iceland
Joined May 2012
I just bought this one: http://www.amazon.com/gp/product/B00...ag=lifinpho-20
It's a little big, but I hope it works. Looks like it has the same connector.
Old Aug 24, 2012, 06:01 PM
snelan is offline
Find More Posts by snelan
snelan's Avatar
Joined Jul 2012
I just use 850mah 3 cells (Turnigy I believe) from HobbyKing. They are like $8 each or so.
I know, I know, a little old school to use a separate battery, but hey, it gets the job done! (Also I don't feel like getting a voltage regulator).
snelan is offline Find More Posts by snelan
Old Nov 05, 2012, 05:44 PM
claudiovast is offline
Find More Posts by claudiovast
Joined Nov 2012
is that the 5.8G 500mW?? I just but it and I want to know if a can connect it directly to my main battery (nano tech 3S 2650 30-70C) that I use on my quadcopter or shoud I buy a smaller battery for the FPV Tx and wich on?? 2S? 3S? 500, 800mah? Its saids that it can handle from 7 to 15 v ... What is the down side from pulling power from the main battery to the Tx ?
claudiovast is offline Find More Posts by claudiovast
Old Nov 06, 2012, 06:23 PM
ican3d is online now
Find More Posts by ican3d
flying ninja!
ican3d's Avatar
Joined Jun 2011
You can connect directly to main battery but you'll get too much noise on your videos eg: lines on your cam screen. Best bet use separate batt or regulator. I use 3S 850mah 35c nano-tech on 200mw 5.8ghz vtx module.
ican3d is online now Find More Posts by ican3d
Old Nov 13, 2012, 05:32 PM
Joined Nov 2012
thanks
Old Nov 13, 2012, 07:30 PM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
You need two items to get power and no interference. This usually works 100% for me, as long as you mind your video wires vs power wire routing:
this one: http://www.hobbyking.com/hobbyking/s...r_Adapter.html
and this one (splice in more wire and wrap it around this at least 4 times): http://www.readymaderc.com/store/ind...roducts_id=325
(ie you run it off your main flight battery)
note: that 500mW transmitter has a reputation for blowing up, so most folks recommend against using it for FPV. I bought one too, but have never used it after discovering this problem.
Ican3D is using too much battery. if you really want to run a separate bat, just get a 500mah or even less, and don't need even 8C let alone 30C. Heck I run a 200mW transmitter and cam off a tiny 6 gram 300mah 1S battery, and it goes for 40 min.
BCSaltchucker is offline Find More Posts by BCSaltchucker
Question YS-X6 16 way pnt version OR WooKong M, which should I get? ovnilab Multirotor Electronics 5 Aug 26, 2012 02:30 AM
Discussion Hmmm, which PZ warbird should I get? jtaylor996 Electric Warbirds 14 Jul 05, 2012 10:31 PM
Discussion which plane should i get? 10inja FPV Aircraft 13 Jun 19, 2012 04:32 AM
Discussion Which Paraboard Should I get & is EPBuddy Safe? Crash Expert Batteries and Chargers 8 Mar 05, 2012 07:56 PM
Discussion Which Bird should I get for FPV mixgreens FPV Talk 4 Jul 14, 2008 08:39 PM
