Old Dec 07, 2012, 10:09 AM
RDV is offline
RDV
Find More Posts by RDV
RDV
RDV's Avatar
BRISTOL UK
Joined Apr 2003
I see, finally you get the recognition you justly deserve. (josh)
RDV is offline Find More Posts by RDV
Old Dec 07, 2012, 11:32 AM
pontious is offline
Find More Posts by pontious
pontious's Avatar
Bristol, Great Britain (UK)
Joined Jan 2001
It`s a fitup.
pontious is offline Find More Posts by pontious
Old Dec 08, 2012, 12:26 AM
hole digger is offline
Find More Posts by hole digger
hole digger
hole digger's Avatar
USA, CA, Los Angeles
Joined Aug 2002
Terry,
Can't tell you how much I enjoy your build threads and your building skills. Everytime I jump in and take a peak it's just totally enjoyable.
I think we should take up a pool to build you a bigger kitchen.
Pete
hole digger is offline Find More Posts by hole digger
Old Dec 08, 2012, 02:40 AM
pontious is offline
pontious's Avatar
Joined Jan 2001
Thank you Pete that is very kind of you and cheers me up to know that I give a little pleasure to someone so far away.Kitchens Rule!!!
Old Dec 08, 2012, 09:53 PM
pontious is offline
pontious's Avatar
Joined Jan 2001
Started building the fuselage underside.
Have sent for my main Xmas present. Going up to two 90`s for this one.
Old Dec 08, 2012, 09:58 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Sounds good, who's/which/what 90's?
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Dec 09, 2012, 03:06 AM
pontious is offline
pontious's Avatar
Joined Jan 2001
Fly Fly 92mm with 1500kv outrunner on 6 Cells for 58A giving 1.8 kg thrust.I have one in my SAbre and they are half the price of the previous 70mm fans which are no longer available.
Old Dec 11, 2012, 04:08 AM
pontious is offline
pontious's Avatar
Joined Jan 2001
U/C required next.
Fit longer legs and lightweight 4.5" main wheels and substitute one supplied mainwheel for the nosewheel.
Old Dec 11, 2012, 04:57 AM
richb77uk is offline
Find More Posts by richb77uk
Joined May 2010
Wow
All that from a 3 view!
I doff my hat to you sir.
Excellent work and I will be following it keenly
richb77uk is offline Find More Posts by richb77uk
Old Dec 13, 2012, 03:55 AM
pontious is offline
pontious's Avatar
Joined Jan 2001
More U/C work.
Old Dec 13, 2012, 06:17 AM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
Looking great, with all these sea vixen pictures/builds/ i might just have to take another look at those stations i posted awhile back.
Awesome work Pontious
Just out of curiosity.
Do you always use always match the landing gear locations this way?
The reason im asking, as i recently finished a frogfoot and found i had to place mine a little further back from real locations so the nose wasnt popping up, so quick.
I know that 1/1/2-1/3/4 in behind cg is a great start but i had to move mine back even further.
i just stuck everything in her, and used a dowel across the plane where the wheels would be and check. before hacking into the foam
D_FAST is offline Find More Posts by D_FAST
Old Dec 13, 2012, 10:40 AM
pontious is offline
pontious's Avatar
Joined Jan 2001
My philosophy right or wrong is that as I have always built these models to nearly true scale I have put the under cart in the scale position and adjusted the c of g to a position on the front of the main doors. It seems to have worked so far although I have always made a small scale chuckie to confirm.All my maidens for 8 models have required little or no trim or cg adjustment.
Old Dec 13, 2012, 05:37 PM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
excellent good to know.
Old Dec 14, 2012, 02:34 PM
pontious is offline
pontious's Avatar
Joined Jan 2001
Make 1/8" ply mount plate .Build mounting box and epoxy plate to box. Test retraction.
Note strengthening for boom joiners.
Old Dec 18, 2012, 03:36 AM
pontious is offline
pontious's Avatar
Joined Jan 2001
Fit extension leads for retract and aileron and continue with wing root construction ready for skinning.
For Sale 1/5 Scale de Havilland Chipmunk - $350 OBO LukeZ Aircraft - Electric - Airplanes (FS/W) 2 Aug 23, 2012 09:59 AM
For Sale 1/5 Scale de Havilland Chipmunk - Best Offer Gets It LukeZ Aircraft - Electric - Airplanes (FS/W) 2 Aug 15, 2012 11:16 PM
Discussion HK De Havilland Vampire Fliegenmong Electric Ducted Fan Jet Talk 1 May 14, 2012 01:41 AM
Sold De Havilland Beaveer bill24orange Aircraft - Fuel - Airplanes (FS/W) 7 Apr 02, 2012 03:37 PM
de Havilland Sea Vixen FAW.2 drawings. bipeflyer Electric Ducted Fan Jet Talk 8 Sep 02, 2003 04:56 AM
