Old Nov 13, 2012, 02:35 PM
TANGOSIERRAROM is offline
Find More Posts by TANGOSIERRAROM
James L
TANGOSIERRAROM's Avatar
Beck Row Mildenhall
Joined Mar 2009
Do these models just keep getting a bit bigger every time now Terry. Be honest now is this just because you are getting longer and longer sighted?
Seriously way too good to be considered a foamy you are moving into some new plain of modelling.
TANGOSIERRAROM is offline Find More Posts by TANGOSIERRAROM
Old Nov 14, 2012, 11:22 AM
pontious is online now
Find More Posts by pontious
pontious's Avatar
Bristol, Great Britain (UK)
Joined Jan 2001
I`m convinced my Kitchen is getting smaller.
Skinned remaining Tailboom sections.
Now for the wings.
pontious is online now Find More Posts by pontious
Old Nov 20, 2012, 05:03 AM
pontious's Avatar
Joined Jan 2001
Remember we only have the top half of the airframe at this point.
Pin down the wing, use the still free alloy tube (With end roughened) to bore aligned hole in wings one side at a time. Cut required length of tube & epoxy in place. I used 30 Min epoxy to allow to wick around contact points and form webs for strength.
Old Nov 24, 2012, 05:42 AM
pontious's Avatar
Joined Jan 2001
Fit ply wing incidence plates. Form and fit upper wing skins. Build lower wing structure and lighten by removing most of centre skin.
Old Nov 24, 2012, 05:53 AM
Doushiyou12 is offline
Find More Posts by Doushiyou12
Winter Is Coming
Doushiyou12's Avatar
Joined Feb 2010
Very nice work
Doushiyou12 is offline Find More Posts by Doushiyou12
Old Nov 26, 2012, 10:14 AM
pontious's Avatar
Joined Jan 2001
Fit & sand wing lead edges.
Old Nov 28, 2012, 02:53 AM
pontious's Avatar
Joined Jan 2001
Sand edges and cut out ailerons.Note guide holes previously made with piano wire after centre and before upper & lower skins added to accurately allign cuts.
Old Nov 28, 2012, 10:26 PM
Raptorfly is offline
Find More Posts by Raptorfly
Crash & Cry! Don't Fly
Raptorfly's Avatar
Australia
Joined Oct 2010
Wow. Love this build thread so I'm going to be watching. you are a very taltend man. I hope to learn a lot from you.
Raptorfly is offline Find More Posts by Raptorfly
Old Nov 29, 2012, 03:20 AM
pontious's Avatar
Joined Jan 2001
Hinge with Micropore tape.
Old Nov 30, 2012, 04:45 AM
pontious's Avatar
Joined Jan 2001
Fit Ply horns, Servos ,extension, leads ,safety keepers , control rods and test.
Wings finished.
Old Nov 30, 2012, 05:08 AM
domll is offline
Find More Posts by domll
domll's Avatar
Norwich.uk.
Joined Oct 2007
wow,really coming along now Terry.
domll is offline Find More Posts by domll
Old Nov 30, 2012, 07:01 AM
James L
Beck Row Mildenhall
Joined Mar 2009
Terry, can I ask why you put the horn and so pushrod and servo right at one end of the aileron?
Old Dec 01, 2012, 06:56 AM
pontious's Avatar
Joined Jan 2001
The main reason I suppose is that it gives the shortest leads, the meatiest part of the wing to fit the servo & Horn and being just a glorified park flyer I have no worries about force or flutter, it`s worked ok on the previous seven models. What`s your thinking ?
Started work on lower booms.
Old Dec 01, 2012, 02:43 PM
James L
Beck Row Mildenhall
Joined Mar 2009
Just wondered if with that length of aileron and the movement that might be in a tape hinge if putting the horn right at one end would mean the movement inboard would be more than the movement furthest outboard. I didn't know if that was clever or not, but thought it may be as it may reduce the risk of a tip stalling at low speeds.
As your thinking always works really well I wondered if that was one of your considerations or if it was shortest wires and no need to as the hinges are stiff enough as is the structure.
Old Dec 07, 2012, 05:37 AM
pontious's Avatar
Joined Jan 2001
I`ll go for that Tango.
Finished tail assy. just building plate to be cut off when required.
Just got my Xmas card from my Daughter.
Seeing a solicitor tomorrow. Where did she get that pic of me drinking in the Sgt`s Mess?
For Sale 1/5 Scale de Havilland Chipmunk - $350 OBO LukeZ Aircraft - Electric - Airplanes (FS/W) 2 Aug 23, 2012 09:59 AM
For Sale 1/5 Scale de Havilland Chipmunk - Best Offer Gets It LukeZ Aircraft - Electric - Airplanes (FS/W) 2 Aug 15, 2012 11:16 PM
Discussion HK De Havilland Vampire Fliegenmong Electric Ducted Fan Jet Talk 1 May 14, 2012 01:41 AM
Sold De Havilland Beaveer bill24orange Aircraft - Fuel - Airplanes (FS/W) 7 Apr 02, 2012 03:37 PM
de Havilland Sea Vixen FAW.2 drawings. bipeflyer Electric Ducted Fan Jet Talk 8 Sep 02, 2003 04:56 AM
