Old Aug 24, 2012, 09:20 AM
nosmo king is offline
Find More Posts by nosmo king
nosmo king's Avatar
The Netherlands, ZH, Rotterdam
Joined Jan 2007
Question
Anybody know how to connect a second led to a DJI NAZA
Hi,
The V-SEN unit has a led, displaying signals from the DJI NAZA. I would like to connect a second led which I can place within my FPV camera view. So I can also see the signals on my screen.
First I was thinking of a optical fibre cable, but I think adding a second led is easier. Has anyone tried this?
Ido
nosmo king is offline Find More Posts by nosmo king
Old Aug 24, 2012, 09:35 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Yes, the led connector is just voltage for each individual led color + GND
so just splice the original 4 piece cable and add another rgb led. Might want to use a resistor for each color as well, so you dont burn it out.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Aug 24, 2012, 03:34 PM
nosmo king's Avatar
Joined Jan 2007
Cool, thanks for your answer timecop. that shouldn't be too difficult
Old Aug 24, 2012, 03:38 PM
Keddy is offline
Find More Posts by Keddy
Canada, ON, St. Catharines
Joined Jul 2012
Cool, I've wondered this as well.
You could also find which wire does the red LED for low voltage. And just have that one in your FPV view so that you don't constantly have a blinking LED in your eyes.
Keddy is offline Find More Posts by Keddy
Old Aug 24, 2012, 04:44 PM
nosmo king's Avatar
Joined Jan 2007
But I would like to know if my quad holds altitude or not, or if its descending or climbing slowly.
Would of course be really nice if if shows up on my OSD, but thats not possible at the moment. Hopefully the OSD - Naza project will be a succes
There are also LED's that work on 5V as they have an internal resistor build in.
I'll try to figure out tomorrow what voltage the naza unit returns, i'm guessing 5v
Old Aug 25, 2012, 04:14 AM
nosmo king's Avatar
Joined Jan 2007
nope, its not 5v, but how it all works dont really know, my small electronics knowledge is not so good.
The right (4) pin is the ground, 2nd pin is red, 3rd is green, yellow is mixed with 2 & 3 I think
but voltages... and what type of led i need, dont have a clue
Old Aug 25, 2012, 04:19 AM
timecop is offline
Joined Dec 2010
it's probably pwm. just connect one led and see what it does. If it's too bright add a resistor.
it's common gnd and 3 signals for each color.
Old Aug 25, 2012, 04:20 AM
nosmo king's Avatar
Joined Jan 2007
but what kind of led do i need, or are all leds the same voltage?
Old Aug 25, 2012, 04:22 AM
timecop is offline
Joined Dec 2010
doesn't matter for your purposes. use a 1k resistor in series of you are worried about burning the led.
use any led, can even do 3 of same color.
Old Aug 25, 2012, 04:23 AM
nosmo king's Avatar
Joined Jan 2007
ok thanks, I will swing by the electroshop today
Old Aug 25, 2012, 09:27 AM
Sad Sack is offline
Find More Posts by Sad Sack
What's a servo?
Australia, QLD, Brisbane
Joined Nov 2008
Just some clarification on this topic though, would this require hacking into the V-SEN module ( to parallel a LED to the V-SEN LED ) or could you splice straight off the wires that lead too the FC?
Sad Sack is offline Find More Posts by Sad Sack
Old Aug 25, 2012, 09:36 AM
Keddy is offline
Joined Jul 2012
I think the VU just houses the LED.
The Naza feeds signal up the 4 wire cable. So you'd be able to tap into the 4 wire cable to branch off other LEDs.
Old Aug 25, 2012, 09:50 AM
nosmo king's Avatar
Joined Jan 2007
Ok, got it working now, bought some leds and used the following pin layout
pin 4 = gnd
pin 2 = red
pin 3 = green
pin 2&3 = yellow
pin 1 = ?
Looking back at it, it was pretty easy. Now I have 2 small leds's showing on my FPV screen.
Old Aug 25, 2012, 09:54 AM
Keddy is offline
Joined Jul 2012
Which pin are you calling 1?
When your looking at the Naza is it the left one?
Old Aug 25, 2012, 09:57 AM
nosmo king's Avatar
Joined Jan 2007
yes, looking at the naza, its the left one.
Come to think of it, It would have been better to call that nr 4, on the connector there is a small 1 printed on it, which is the ground, in my case I call it 4.
Discussion DJI Naza vs DJI WK-M - What do you get for the extra $860?? brianshell Multirotor Talk 96 Jul 19, 2013 08:15 AM
Discussion How to connect LEDs animau Multirotor Talk 6 Aug 07, 2012 10:06 AM
Help! How to Add LED Lights to DJI X450 Quadcopter with Naza FC + GPS + Camera Gimbal flywmoi Multirotor Electronics 3 Aug 05, 2012 03:22 PM
Discussion DJI F450 NAZA kit vs Witespy VC450 with NAZA kit MC21 Multirotor Talk 5 May 16, 2012 02:16 PM
