Old Nov 14, 2012, 06:04 PM
Socratic is offline
Find More Posts by Socratic
United States, NH, Barrington
Joined Sep 2011
Well, maybe I won't be flying quite as quickly as I thought. Hung up on something pretty simple - perhaps just brain cramp? Watching the Zero Video, it appears that the Steadicam IMU plugs into the controller using the A E T R connectors. If that is correct, where do I plug my receiver A E T R connection? Anyone know what I am supposed to do here?
Think I just figured out my issue. I need to use S Bus off C7 to S Bus on my Receiver. That takes care of where to plug things in. Now I just need to familiarize myself with setting up using the S Bus feature - at least there is info on that!
Socratic is offline Find More Posts by Socratic
Last edited by Socratic; Nov 14, 2012 at 07:56 PM. Reason: Figured it out - I think
Old Nov 14, 2012, 10:50 PM
zerouav is offline
Find More Posts by zerouav
Joined Mar 2012
Good job! You are right
Steadi IMU to A E T R connectors of MC, notice the order of connector colour
S-Bus to C7(MC),
Another IMU to I1 and I2 connectors of MC.
zerouav is offline Find More Posts by zerouav
Old Nov 15, 2012, 09:55 PM
Socratic is offline
Joined Sep 2011
Okay.....on to the next issue. I purchased a Turnigy 5.0 4S battery for this quad. It has 5.5 bullet connectors already installed. Do I need to cut them off and replace with an XT60? Doesn't seem to make sense since we are talking 80 amp bursts vs 250 amp burst capability. Is the draw on the quad so little that it doesn't really matter what connector I use? I don't really see how to connect unless I use a XT60 since that is what Zero provided on the special cable. Should be fun soldering 8 ga wire to the XT60. BTW, next video installment of the build will be up on YouTube shortly (4 hours to upload first).
Old Nov 16, 2012, 03:29 AM
fajar is offline
Find More Posts by fajar
fajar's Avatar
Indonesia, Special Capital Region of Jakarta, Jakarta
Joined Jan 2011
You can use XT60, dont worry about stressing the wire for a quad that size.
fajar is offline Find More Posts by fajar
Old Nov 16, 2012, 03:39 AM
zerouav is offline
Joined Mar 2012
Both 5.5 bullet connectors and T60 can be available, just make sure the battery connector and Steadi470 connector are matched, and notice the positive pole and negative pole.
But it is strongly suggested to replace the battery connector to T60.
Old Nov 16, 2012, 09:21 AM
Socratic is offline
Joined Sep 2011
Thanks for the help on the connector. Here is the latest assembly video:
Zero Steadi470 - Hooking up Electronics (11 min 47 sec)
Old Nov 16, 2012, 10:44 AM
olahf is offline
Find More Posts by olahf
Joined Oct 2012
http://youtu.be/HnUjz2L7GHU
thanks for your videos socratic
olahf is offline Find More Posts by olahf
Old Nov 19, 2012, 10:21 PM
Zero UAV is offline
Find More Posts by Zero UAV
Joined May 2012
Nice Video! Look forward to your flying
Zero UAV is offline Find More Posts by Zero UAV
Old Nov 20, 2012, 06:13 AM
New Copter is offline
Find More Posts by New Copter
Spain, Aragon, Sos
Joined Jun 2012
In the first post there is this information:
"Currently the Zero-Steadi470 only supports the Futaba S-BUS system for radio control. This means in order to pilot by radio control you must have a Futaba S-BUS compatible receiver."
Are there plans to support PPMSum as the YS-X6?
Thanks in advance.
New Copter is offline Find More Posts by New Copter
Old Nov 22, 2012, 09:24 PM
ise2012 is offline
Find More Posts by ise2012
ZeroUAV
ise2012's Avatar
Australia, SA, Tarcoola
Joined Jul 2012
the PPM-SUM
Thanks in advance.
hi , my friend , the Zero-Steadi470 only supports the Futaba S-BUS system for radio control.
but the ys-x6 can support the PPM-SUM , just connect it to the ch8 of ap .
as we know the Zero-Steadi470 use the YS-x6 , why can not use the ppm-sum .
because the Zero -Steadi470 hava another IMU to cotrol the GIMBAL .
Zero-Steadi470 have no planes to support the PPM-SUM now ,
but your suggestion is good , we will consider it .
thank you my friend .
peter
ise2012 is offline Find More Posts by ise2012
Site Sponsor
Old Nov 23, 2012, 04:48 AM
Spain, Aragon, Sos
Joined Jun 2012
Hi, Peter, thanks for your answer.
Recently bought a Graupner radio and now I find that I gain nothing.
I tested with a converter from PPM to Sbus without solving the problem.
OK, I guess I'll have to buy a Futaba radio.
Old Nov 23, 2012, 06:31 AM
Zero UAV is offline
Joined May 2012
Zero-Steadi470 Photography for Tibet
http://v.youku.com/v_show/id_XNDc3ODA1NTYw.html
Old Nov 25, 2012, 12:56 PM
Socratic is offline
Joined Sep 2011
Stuck battery mount tube
Anyone have any suggestions on how to loosen up the battery mount - seems the smaller CF tube is stuck inside the larger one and I can no longer turn or extend/shorten the battery position. At this point, I am just going to drill a second hole and position the mount properly front to back but I won't ever be able to use another brand/size battery unless I can get this thing to move. Any suggestions appreciated. Thanks.
Stuck Battery Mount (0 min 0 sec)
Old Nov 25, 2012, 04:42 PM
Socratic is offline
Joined Sep 2011
And Balancing Issues
Not able to get the camera stabilizer in balance. Also appears that the servos are not responding to input when I try to calibrate them. Nothing is happening when I go through the setup other than confirmation on the tablet program. Ideas as to what I am doing wrong here? Yes......had to plug in connection to ESCs to power bus that servo's plug into on the FC. Daaaaaaaaaaa Now if I can only find out cause of out of balance. Just to let you know, I did add weight to lower part of stabilizer and was able to get it pretty close. Doesn't seem to be super critical as it does seem to stay in balance now when everything is powered up. Though, I don't like the idea of having to ADD weight to a quad....usually I try to eliminate weight. Eventually I will see if there is any negative consequences in more weight.
MVI 0473 (3 min 4 sec)
Old Nov 26, 2012, 05:01 AM
milouze is offline
Find More Posts by milouze
Registerer Used
milouze's Avatar
Paris
Joined May 2010
Did you try with a lighter battery? Or add some weight to the lower part (seems that not that much weight is needed)? 'cause the extend/shorten part of the battery tray seems a bit tricky to tweak.. material against material friction; not so good. What about using some drops of lube, to pull off the tube, clean it and sand slightly inside the main tube? Yeah I know, you should not have to do that for that product class, but you don't want to be stuck :/
milouze is offline Find More Posts by milouze
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2426 Feb 07, 2016 07:14 AM
New Product Zero UAV YS-X6 [Owners Thread] *Autopilot system for multirotors* Zero UAV Multirotor Electronics 2418 Feb 06, 2016 05:41 PM
Discussion The XAircraft X650/X650V MultiCopter (Aerial Photography & Video) owners thread xaircraft Multirotor Talk 20833 Nov 11, 2015 07:23 AM
Discussion Zero UAV Quad discussion & questions Zero UAV Multirotor Electronics 103 Dec 14, 2012 04:52 AM
New Product Zero-Steadicam Frame - for Professional Aerial Filming (NEX5N RAW VIdeo + PDF) DiVidesign Multirotor Talk 49 Oct 06, 2012 06:35 AM
