Old Aug 24, 2012, 03:13 AM
CH33ZEBURG3R is offline
Find More Posts by CH33ZEBURG3R
Australia, VIC, Frankston
Joined Jul 2012
Idea
Turnigy Talon V2 Quadcopter - Build Info, Advice and Help
First off my Quad is now built as you can see, this is the finished product, i'm very happy with it and have put the first few video's up of my first flights.
For anyone who's deciding to build their first Quad and have chosen the sleek looking Talon V2 as their frame, i'm hoping you can come in here and get any help or advice on what others have used for there build, what motors or esc's do you need, batteries, props and how much is it going to weigh and where to place things etc.and what set up for flights people use. I know when i was deciding to buy mine i was searching around for threads where people have built the Quad and what parts they used, i also went on the search for videos of the Talon V2.
This is my first build after owning the AR.Drone i got hooked on quads and wanted something that was my own that i'd built, so to Hobbyking i went for parts, my quad is now complete and i'm in the process of learning to fly it, i'm having a lot of fun and i must admit it's a little bit harder than i first though, but saying that iv'e only had maybe 5-6 flights where i'm just hovering so i'm getting used to it a little.
The main parts i used were -
Turnigy Talon V2
Turnigy Plush 25A ESC's Plus a Spare + Programming card
Turnigy Aerodrive 2830 1130kv Motors plus a Spare
Hobbyking KK2.0 Flight control Board Manual can be found here - http://rosa-hp.sakura.ne.jp/181270330X7478X47.pdf
Hobbyking Power Distribution Board
Turnigy Nano-Tech 2200mah 3S 35-70c Lipo
Slow Fly Props - 8x4.5 + 9x4.7 in Green/Black CW+CCW (buy a few when there in stock)
Turnigy 9X Transmitter Manual here -http://www.hobbyking.com/hobbyking/s...X226591X16.pdf (Sorry about the LInks)
It was like Christmas came early when it all arrived
Also the small things you will need are things like Servo leads, nylon screws and spaces, heat shrink and extra wire also rubber grommets to help the FC board with vibrations a couple of battery straps, (I'd personally steer clear of the Turnigy one's, mine have virtually lost there stick in 3 weeks so i wouldn't recommend them.) 3.5mm bullet connectors and spare motor shafts and i also got two spare Talon V2 extended booms and I'd recommend getting more screws.
There will always be something you forget, iv'e made another two orders since the main one.
Anyway onto my build, i started by putting the frame together and the first problem i encounted were the M3 hex screws, maybe i was trying to tighten everthing up too tight but they kept rounding off the allen keys i have, i have since bought more M3 screws but with a Phillips head instead of the hex as they can be tightened up much more securely, i highly recommendgetting some in variuos sizes, there cheap enough and will save you problems down the line and I'll be using nylon lock nuts that i believe will be better also for tightening the arms.
Here's an issue that a few people are having with these mounts, it can be found on Pg.2 - http://www.rcgroups.com/forums/showt...1718162&page=2 basically the design of the mounts mean you need to have them the opposite way round to what the instructions tell you.
I also now have these that i'm going to try out instead of the PDB
i won't have to worry about where to mount the board then. (I actually found these to be no use as they were too rigid once all the bullet connectors were in place.
I'll put up more photo's and any updates when i get more time, but if anyone has any advice for others building the Talon V2 please share any ides
Also i'll put up any links to the Talon V2 builds below that i find:
TheFernMans build -
http://www.rcgroups.com/forums/showthread.php?t=1693730
Here's a 4 part guide on setting up a Quad with a Talon V2 Frame, pretty good if your starting out.(Not my Build by the way)
Part 1 - Parts and Set-Up
Basic Quadcopter Tutorial - Chapter 1 - Parts and Setup (6 min 59 sec)
Part 2 - Frame Construction
Basic Quadcopter Tutorial - Chapter 2 - Frame Construction (11 min 17 sec)
Part 3 - Power System
Basic Quadcopter Tutorial - Chapter 3 - Power System (20 min 17 sec)
Part 4 - KK2 Board, ESC Calibration,Throttle range and Props
Basic Quadcopter Tutorial - Chapter 4 - KK2 Board, ESC Calibration, throttle range and props (15 min 12 sec)
Here's a nice video of the Talon V2 with very similar set up
HobbyKing's KK2 board: FLIGHT FOOTAGE (8 min 34 sec)
I'd just like to add that you should seriously think of getting hold of the Phoenix Flight Simulator, it has a Quadcopter that you can fly and for someone building and flying for the first time it will help heaps in getting used to the controls, although it can never be like flying for real its the next best thing for honing your skills, especially when the weather is bad or you'd rather just stay indoors and practice. Highly Recommended
EDIT: Finally my very first test flight
Turnigy Talon V2 - Very First Flight (0 min 50 sec)
and my second, learning to hover on a full battery at the moment.
Turnigy Talon V2 Quad (0 min 39 sec)
Quad Training - Turnigy Talon V2 (1 min 49 sec)
Turnigy Talon V2 Quadopter (3 min 12 sec)
Happy Flying
My build pics.
Description: Turnigy talon V2 and Turnigy 9xName: IMG_5426.jpg
Description: Lipo voltage alarm connected to PDB.Name: IMG_5422.jpg
Description: I made use of the foam from the KK2 board.Name: IMG_5434.jpg
Description: Esc wires extended and Bullet connectors fitted.Name: IMG_5436.jpg
Description: Slowly getting there.Name: IMG_5512.jpg
Description: Name: IMG_5514.jpg
Description: How the wires are routed and attached to the arms.Name: IMG_5504.jpg
Description: The start of the tidy upName: IMG_5505.jpg
Description: Cable ties to secure esc's to arms.Name: IMG_5506.jpg
Description: Light Check.Name: IMG_5507.jpg
Description: Getting neater.Name: IMG_5509.jpg
Description: Everything tidyName: IMG_5510.jpg
Description: Name: IMG_5511.jpg
Description: I thought i'd number which esc's are which to make things simpler for when i start testing everything.Name: IMG_5430.jpg
Description: My prop balancer i made from scrap pieces of wood i hadName: IMG_5431.jpg
Description: I sunk magnets in each end so one end is free to spin.Name: IMG_5411.jpg
Description: I sunk magnets in each end so one end is free to spin.Name: IMG_5665.jpg
Description: Tupperware onion ContainerName: IMG_5666.jpg
Description: Name: IMG_5667.jpg
Description: Name: IMG_5720.jpg
Description: Name: IMG_5721.jpg
Description: I used nylon screws instead of the black M3's to save weightName: IMG_5722.jpg
Description: Name: IMG_5723.jpg
Description: Name: IMG_5731.jpg
Description: Name: IMG_5732.jpg
Description: Name: IMG_5733.jpg
Description: Name: IMG_5735.jpg
Description: Name: IMG_5757.jpg
Description: Name: IMG_5758.jpg
Description: Name: IMG_5759.jpg
Description: Name: IMG_5760.jpg
Description: Name: IMG_5761.jpg
Description: Name: IMG_5762.jpg
Description: Name: IMG_5763.jpg
Description: Wires are neat through the Dome LidName: IMG_5764.jpg
Description: Small hole for Lipo Alarm BuzzerName: IMG_5765.jpg
Description: Name: IMG_5766.jpg
Description: Name: IMG_5767.jpg
Description: Name: IMG_5768.jpg
Description: Name: IMG_5769.jpg
Description: Name: IMG_5770.jpg
Description: Name: IMG_5773.jpg
Description:
CH33ZEBURG3R is offline Find More Posts by CH33ZEBURG3R
Old Aug 25, 2012, 09:20 AM
Joined Jul 2012
I made up some LED,s to hook up to the balance connector and attached them to the arms at the front of the Quad.
Description: Led's trimmed down and connector fitted.Name: photo 2.jpg
Description: Led's on the front of the frame.
The KK2 board has been shipped so hopefully next week i can start building again.
Old Aug 25, 2012, 04:09 PM
ronzu is offline
Find More Posts by ronzu
Joined Aug 2012
Very impressive. Good stuff. I am building my first quad as well using the turnigy frame. Will frequent your thread more often and share insights with you!
ronzu is offline Find More Posts by ronzu
Old Aug 25, 2012, 04:18 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
http://www.hobbyking.com/hobbyking/s...dProduct=11458
I used this hex driver and it's great. I was running into the same issue with rounding the hex driver. Get this and those screws on the Talon v2 frame were tight! I was even thinking about changing all the hex for regular screw but after tightening them with this Turnigy hex driver it was perfect. Highly recommended.
TheFernMan is offline Find More Posts by TheFernMan
Old Aug 25, 2012, 04:22 PM
TheFernMan's Avatar
Joined Jul 2012
Oh and protect the little legs. Or maybe even think about another way for landing gears. Those little legs tend to twist the motor mounts when landing hard on them.
Maybe something like this. I just ordered this.
http://www.goodluckbuy.com/repair-an...and-white.html
Old Aug 25, 2012, 04:47 PM
ronzu is offline
Joined Aug 2012
How are you supposed to use the new adapters instead of the pdb? I dont quite understand....got any pics to show how they will be used?
Old Aug 25, 2012, 06:09 PM
TheFernMan's Avatar
Joined Jul 2012
Those are four 3.5mm to 4mm adapters. Basically you can solder 3.5mm male plugs and connect the reds and the blacks ends from the ESCs to those adapters.
http://www.hobbyking.com/hobbyking/s...p?idProduct=68
Or you can solder the positive wire of each ESC to the back of those adapters. And the same for the negative wire.
Then connect the battery to those adapters. You wouldn't need a Power Distribution Board.
Oddcopter.com is a pretty cool site. Check out this wiring picture.
http://oddcopter.com/2012/04/13/quadcopter-wiring/
Old Aug 25, 2012, 07:26 PM
Joined Jul 2012
Yes i seen them but never ended up getting one, iv'e ordered more screws now anyway so i'll put up pics on what i do once they arrive i also plan on putting a M3 screw in the hole and drilling in to the CF frame to stop the arms twisting near the motors, it's pretty obvious that they designed it for that purpose.
Description: Threaded hole for M3 Screw to stop arm twisting
I'm really not to keen on this type of landing gear, i'd rather keep the Quad looking as it is, i'll be flying on grass anyway until i get good at flying but i may look into adding some kind or padding at the end of the legs at some point, i'll see how they go.
Iv'e also added a link to your build so people can see what others are doing
Old Aug 25, 2012, 07:33 PM
Joined Jul 2012
Pretty simple, obviously i soldered on bullet connectors on the esc's to fit the PDB, so all the Neg and all the Pos go into the female connectors
Description: Negative Connectors in place
Then its a case of soldering on a 4mm Bullet connector to the ends of the XT60 wires, i have a load of these already i just need to trim the wires down to the length i need once my 4mm bullet connectors arrive.
Description: XT60 needs a 4mm bullet connetor
Old Aug 25, 2012, 07:41 PM
Joined Jul 2012
A small tip for people ordering from hobbyking, use buddycodes to get things cheaper, you can try the Classifieds here - http://www.rcgroups.com/hot-online-deals-429/ or use this - http://hk.rc-international.info/swarm
I also found out that when ordering, lets say the frame, when you scroll down the extra parts you need are cheaper if you buy them together, also don't assume that's the cheapest price you'll get them. For instance buying the KK2 FC board is normally $29.99, now if you click on the Talon V1 Tricopter frame and scroll down its actually $24.28 saving over $5.
Old Aug 25, 2012, 09:10 PM
TheFernMan's Avatar
Joined Jul 2012
Nice tip, too late for me.. Bought another KK2 at full price :/
Old Aug 25, 2012, 09:58 PM
Joined Jul 2012
Yeah, my first one got sent back but got a refund after 3 days, so I ordered another one and it came to $27.99 then I added in a couple of other things and paid. THEN when i was looking at the new Talon Tri frame I noticed the KK2 board under it for $24.28 clicked on it and it went into my cart by which time it was too late for me to cancel my previous order lol.
Nevermind though hopefully someone can take advantage.
Old Aug 26, 2012, 11:22 AM
ronzu is offline
Joined Aug 2012
Thanks alot. That explains and clarifys my queries
happy building!
Old Aug 27, 2012, 10:53 AM
ronzu is offline
Joined Aug 2012
Hi guys,
Just wondering what brand soldering iron and tip would you reccomend for soldeing the bullet connectors and escs? Any personal perferences?
Thanks.
Old Aug 27, 2012, 02:32 PM
TheFernMan's Avatar
Joined Jul 2012
Maybe something with adjust power/ heat and removable tips? A small tip for those bullet connector. They have small holes for the tip of the iron. but people have done all type of soldering with whatever iron the had. Even those cheap RadioShack one.
Idea The Little Things - First Quad Build - Talon v2 w/ Dome TheFernMan Multirotor Talk 75 Dec 17, 2015 04:44 PM
Discussion Turnigy Talon Quadcopter V2 Build rubenhak Multirotor Talk 17 May 18, 2014 12:01 PM
Help! Talon V2 Setup Advice. 747Pilot Multirotor Talk 6 Sep 12, 2013 03:43 PM
Sold Talon V2 Carbon Fiber Quadcopter Frame STILL AVAILABLE! Depron Dave Aircraft - Electric - Multirotor (FS/W) 7 May 22, 2012 05:37 AM
