Old Feb 02, 2013, 01:08 AM
bigfella65 is offline
Find More Posts by bigfella65
Australia, NSW, Bathurst
Joined Mar 2009
Originally Posted by djdavid60 View Post
I can finally resume my Tricopter build! I decided to get a new radio, so I didn't want to calibrate my ESCs to my old radio, and then have to set it all up again. But lookie what arrived today!!!
Very nice radio...thinking of purchasing one of these.
bigfella65 is offline Find More Posts by bigfella65
Old Feb 02, 2013, 03:07 AM
Bigmic is offline
Find More Posts by Bigmic
Bigmic's Avatar
Norway, Sogn og Fjordane, Askvoll
Joined Aug 2012
Originally Posted by nothingman View Post
That was some cold weather, How do you protect the FC, Ive packed mine up with snow twice now and had to use a hairdrier to dry it out.
Do you take off with your goggles on or do you line of sight until you've got some altitude?
Having trouble with my FPV takeoff
My FC is packed in the original Case - just put some hole in the cap for the wires works perfect. Take off in a correct adjusted selvlevel modus without trouble. Take off fly and land with goggles on, yes.
Bigmic is offline Find More Posts by Bigmic
Old Feb 03, 2013, 08:46 PM
rocketscience is offline
Find More Posts by rocketscience
Not a six pack
rocketscience's Avatar
USA, IL, Chicago
Joined Jul 2008
quick video in the snow trying out the 2.7k/30fps and 1080/60fps differences. Jello effect seems about the same -- pretty minimal. I think a polarizer to slow down the shutter speed might help.
tricopter snow gopro test 2.7k and 1080/60 (4 min 44 sec)
rocketscience is offline Find More Posts by rocketscience
Old Feb 04, 2013, 03:45 AM
sharonarn is offline
Find More Posts by sharonarn
ישראל, תל אביב יפו
Joined Feb 2011
here is my try on the tricopter talon fpv
with openpilot board
mesubim 18.1 tricopter fpv (3 min 23 sec)
and here is anoter less seccesful flight...
i still dont know what went wrong in 3:15
fpv tricopter going down... (3 min 38 sec)
sharonarn is offline Find More Posts by sharonarn
Old Feb 04, 2013, 08:50 AM
Not a six pack
USA, IL, Chicago
Joined Jul 2008
That kind of looks like what happened to me a couple times - without fpv - when my rear motor would vibrate on the hinge like crazy and cause the board to go nuts. I had to keep the hinge kind of loose. Turns out the motor shaft was ever so slightly bent. Not sure if your setup uses the shaft or the adapters but maybe see if it wobbles?
I replaced the motor housing and shaft with a spare and now it's solid and I was able to tighten up the hinge and thrust bearings.
Old Feb 04, 2013, 10:52 AM
shelterock is offline
Find More Posts by shelterock
Fly, crash, rebuild.
United States, NY, Shelter Island
Joined May 2011
Sharonarn,
Looks like a prop failure perhaps. Since the unit didn't flip over completely. Wher ethe props intact and all the blades accounted for at the crash site if they were broken?
H
shelterock is offline Find More Posts by shelterock
Old Feb 04, 2013, 06:36 PM
Metallicgraph is offline
Find More Posts by Metallicgraph
Suppressed
Metallicgraph's Avatar
United States, GA, Guyton
Joined Nov 2012
New here but here is my build so far. Still have several changes im going to make. And still have some tuning to do.
Setup
Turnigy Talon Tricopter Carbon Fiber Frame
Hobbyking KK2.0 flashed to Firmware 1.5 Flight Control Board
Extended Carbon Fiber Boom 380mm
2X Turnigy nano-tech 2650mah 3S 35~70C Lipo
NTM Prop Drive Series 35-36A 910Kv / 350W
12x4.5 SF Props
F-30A SimonK flashed ESC
Metallicgraph is offline Find More Posts by Metallicgraph
Old Feb 04, 2013, 06:46 PM
Suppressed
Joined Nov 2012
I had the turnigy 306G tail servo so many people seem to love but i cant understand why. On my maiden i just slightly bumped the tail on the ground and it destroyed the internals, i will never buy that junk again. Right now I have a HS-5085MG which is a little slower but 100 times the quality. i was going to order a Savox SH-0257MG but this one seems great so far so it will probably just stay that way.
Old Feb 04, 2013, 07:14 PM
nothingman is offline
Find More Posts by nothingman
thump thump thump
nothingman's Avatar
Canada
Joined Oct 2012
Originally Posted by Invid View Post
Best thing you can do for vibes is lose the NTM 2826 prop spinners. I put on 5mm lock nuts instead and that solved 95% of my jello problems. Those spinners are seriously unbalanced and not worth the trouble.
I tried a fiber locknut yesterday after my spinner spun OFF, sounded a bit different so the vibrations must have gotten better. Also I like that it is NOT going to come loose in flight. Luckily I was still on the ground when my spinner flew off, never found it either.
nothingman is offline Find More Posts by nothingman
Old Feb 05, 2013, 06:58 PM
Mrhide is offline
Find More Posts by Mrhide
Mrhide's Avatar
Canada, QC, Laval
Joined Aug 2012
Please, anybody know which replacement servo arm I can use on this servo?!
http://www.hobbyking.com/hobbyking/s...dProduct=22687
bought a JR set locally and ...it's too big
Mrhide is offline Find More Posts by Mrhide
Old Feb 05, 2013, 07:56 PM
Suppressed
Joined Nov 2012
Sure do PM me your address and i will try to get it out tomorrow its all yours.
Old Feb 05, 2013, 08:15 PM
Invid is offline
Find More Posts by Invid
Canada, ON
Joined Mar 2012
I know I said lose the spinners, but it didn't expect you to take me in such a literal fashion.
Invid is offline Find More Posts by Invid
Old Feb 06, 2013, 10:46 AM
Suppressed
Joined Nov 2012
Its on the way to you good luck
Old Feb 07, 2013, 10:02 PM
Suppressed
Joined Nov 2012
Now that i got my gopro cable from rangevideo i was able to lose the other battery an clean it up a little.
Old Feb 07, 2013, 11:25 PM
Mrhide is offline
Mrhide's Avatar
Canada, QC, Laval
Joined Aug 2012
BIG THANK YOU to murrelljimmy !!
Discussion Talon V2 or F450 Frame? solars Multirotor Talk 28 Nov 13, 2015 04:55 PM
New Product Turnigy Talon Carbon Fiber Quadcopter Frame CrashingDutchman Multirotor Talk 510 Jan 20, 2015 01:05 AM
Sold Turnigy Talon V2 Frame $30 / shipped **PRICE REDUCED pefozzy Aircraft - Electric - Multirotor (FS/W) 5 Sep 15, 2012 04:21 PM
For Sale Turnigy Talon Quad Frame V1 penz83 Aircraft - Electric - Multirotor (FS/W) 2 Jun 03, 2012 05:17 PM
Sold universal quad frame and tricopter frame dr rc Aircraft - Electric - Multirotor (FS/W) 4 Mar 07, 2012 07:26 PM
