Old Jan 20, 2013, 02:18 PM
thumbglitch is offline
Find More Posts by thumbglitch
Sydney N.S.W Maroubra
Joined May 2007
Hey Ziggy95 can you please post your settings?
Take a photo at each step like aileron pid, elevator and self level, I am just new to the KK2 and multicopters and am just finishing mine and not sure where to start.
Would the default settings of the tricopter in the KK2 be ok to start with?
thumbglitch is offline Find More Posts by thumbglitch
Old Jan 21, 2013, 07:31 AM
ziggy95 is offline
Find More Posts by ziggy95
Joined Jul 2012
Not all the default settings. PI are almost the same as precognized in 1st post of this thread.
You will have my complete kk2 config in 5 hours when i will be back at home (if the snow let me go back^^)
ziggy95 is offline Find More Posts by ziggy95
Old Jan 21, 2013, 08:09 AM
Joined May 2007
Thank you Ziggy95 that would be much appreciated if you would not mind just so I can test hover my tricopter.
Thanks again everyone
Old Jan 21, 2013, 08:43 AM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
Hi tg,
I have just followed the recommended tuning method of setting I to 0 and tune P then add I
I found that my Tri would hover reasonably well anywhere between 60-80 P on Aile/Elev and 20~25 I.
My Yaw P is 35 and I is 30 but this depends on the servo used more than much else I think and I just changed mine out again after my 306 died on me.
Stick scaling was 30 on Aile/Elev and 60 on yaw but before you try a flip you need to get these up to at least 50ish on Aile/Elev otherwise you'll do a large loop rather than a flip. Yaw doesn't need to change but 60 is quick for starting out so maybe 50 or 45 is better.
Rather than race ahead though and use the settings I've posted probably just as good to wait for ziggy's settings... though you now have a 2nd partial dataset to review.
Good luck and enjoy it. Flies nicely I think, plus the folding makes it really portable...
thwaitm is offline Find More Posts by thwaitm
Old Jan 21, 2013, 02:32 PM
Joined May 2007
Thank you thwaitm appreciate the advice, will see how I go with setting it up everything is done on the Tri just have to set up the controller.
Old Jan 21, 2013, 07:30 PM
shelterock is offline
Find More Posts by shelterock
Fly, crash, rebuild.
United States, NY, Shelter Island
Joined May 2011
Thumbglitch,
Are you using Simonk flashed escs?
H
shelterock is offline Find More Posts by shelterock
Old Jan 21, 2013, 08:11 PM
thwaitm is offline
Team WarpSquad
Joined Jun 2011
Originally Posted by shelterock View Post
Thumbglitch,
H
Good point. I forgot to mention that I _AM_.
Old Jan 21, 2013, 08:35 PM
Joined May 2007
No I don't think I am just using gaui 18 esc from my gaui 500x
Old Jan 22, 2013, 02:38 AM
ziggy95 is offline
Joined Jul 2012
thumbglitch ,
i did'nt find any time yesterday night.
I am with my Tri at work so i will write all my config in 2 hours.
I have madde yesterday a modification on the Yaw P gain because he was moving itself on the yaw.
See you in 2 hours ^^
Old Jan 22, 2013, 05:10 AM
ziggy95 is offline
Joined Jul 2012
Pfuhh, i forgot the battery. Config after works
Old Jan 23, 2013, 04:53 AM
Joined May 2007
Guys please help not sure what I am doing wrong if anything.
Ok so I put in the recommended settings, using a digital servo so setting is high and changed to servo from esc.
Now everything appears ok direction of motors and props give the copter enough power to leave the ground and just as it lifts off the servo moves the motor immediately to the right(looking at the copter from behind) does not matter what I do it just does the same thing, and if I try to correct it it just goes to the opposite direction.
Self level is off and then tried it with on still the same issue using a tgy306hv tail servo but not sure I am so bumbed as I can't get it to fly
PLEASE HELP
Old Jan 23, 2013, 05:39 AM
Mrhide is offline
Find More Posts by Mrhide
Mrhide's Avatar
Canada, QC, Laval
Joined Aug 2012
thumbglitch, see the 2 first videos on this post:
http://www.rcgroups.com/forums/showp...&postcount=490
are these the kk2 settings you have?
Did you calibrate the ESC's?
You're almost there
Mrhide is offline Find More Posts by Mrhide
Old Jan 23, 2013, 07:10 AM
Joined May 2007
Yes I have calibrated the esc's with the board everything seems to be working its just the servo, when I bring the motors upto speed and just enough power for the Tri to lift off the servo just goes hard right, with no input what so ever????
Yes followed the settings of the 2nd vid too and still same issue
I am ready to kick it!!!!
Old Jan 23, 2013, 05:03 PM
ziggy95 is offline
Joined Jul 2012
Here's my settings:
PI Editor:
Roll/Pitch : 30/100/18/20
Yaw : 75/20/42/10
Mode settings : Aux/Yes/Yes/yes (i use fasst on futaba, only one cable) else no
Stick scaling : 39/39/50/95
Misc : 10/0/30/0/50
Self level : 70/30 10/30
Mixer editor : channel 4 : rudder -100
Old Jan 23, 2013, 05:16 PM
jeffyd123 is offline
Find More Posts by jeffyd123
United States, OR, Bend
thank you thwaitm and ziggy... thats very helpful info for us newbs.
Does anyone have an ardupilot on their talon tri? if so some settings would be a lot of help for me. ( I got an apm 2.5 for my talon tri and Im building an RC Explorer with a KK2 for my trainer)
thanks again guys, your advice really is very much appreciated!
jeff
jeffyd123 is offline Find More Posts by jeffyd123
Discussion Talon V2 or F450 Frame? solars Multirotor Talk 28 Nov 13, 2015 04:55 PM
New Product Turnigy Talon Carbon Fiber Quadcopter Frame CrashingDutchman Multirotor Talk 510 Jan 20, 2015 01:05 AM
Sold Turnigy Talon V2 Frame $30 / shipped **PRICE REDUCED pefozzy Aircraft - Electric - Multirotor (FS/W) 5 Sep 15, 2012 04:21 PM
For Sale Turnigy Talon Quad Frame V1 penz83 Aircraft - Electric - Multirotor (FS/W) 2 Jun 03, 2012 05:17 PM
Sold universal quad frame and tricopter frame dr rc Aircraft - Electric - Multirotor (FS/W) 4 Mar 07, 2012 07:26 PM
