Old Jan 13, 2013, 09:15 PM
shelterock is offline
Find More Posts by shelterock
Fly, crash, rebuild.
United States, NY, Shelter Island
Joined May 2011
Originally Posted by djdavid60 View Post
I ordered almost everything else for my Talon Tri. The only thing I haven't selected yet is the tail servo. What seems to be the best servo that you guys have been using so far? Is the servo mount plate cut for a mini or micro servo? If it is cut for a micro, have any of you cut out the servo hole and used a larger tail servo?
I also ordered some thrust bearings for the tail servo mechanism from Amain Hobbies, since HK was out of stock.
Here is what I am using so far:
Motors - NTM 28-26 1000KV / 315W
ESCs - Hobbywing FunFly 30A (These work great with the Paris boards)
Controller - Multiwiicopter.com v4r6 PARIS Sirius™ IMU (Gyro, Acc, Mag, Baro) USB, Paris GPS / remote Compass MAG, and OLED: PARIS 1" OLED 128x64 PID tuning display I2C
Lipo - Turnigy Nano-Tech 2650MAh 4S 35-70C
Now I wait for everything to arrive.
Doug
I used a solar 12g digital and currently a 992mg from turnigy. I have the 306 digital. I understand that none of them stand up to a good crash. The motors mounted on top create undue leverage on the tail servo causing it to break.
I say keep it digital but cheap to start.
H
shelterock is offline Find More Posts by shelterock
Old Jan 14, 2013, 04:01 AM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
I'm actually using the 360 from Turnigy but only because I didn't notice that the Savox SH-0257mg would have fitted.
I use the 257 on my 450 heli and it's very smooth. The 360 isn't bad but lacks a little toughness. I already trashed one output shaft through the effects of dumb thumbs. Not sure anything would have survived that dumping mind...
EDIT: Here's another example of blatant tricopter abuse... sorry for the giggling but it was kinda fun.
Motor bearings oiled both before and after, dried off afterwards in the breeze of the aircon heater (and ~35% humidity)
Pratting about with the Tricopter in the snow (6 min 21 sec)
thwaitm is offline Find More Posts by thwaitm
Old Jan 16, 2013, 05:25 PM
Ricklandia is offline
Find More Posts by Ricklandia
United States, FL, Weston
Joined Nov 2012
Originally Posted by Joe_Wildcat View Post
Here is a video showing most of the process.
http://youtu.be/H-VMOIBPuZA
...Joe
Positively brilliant!
Ricklandia is offline Find More Posts by Ricklandia
Old Jan 17, 2013, 04:19 AM
ziggy95 is offline
Find More Posts by ziggy95
Joined Jul 2012
Hi there,
I power on my TTT and i have a problem with my TGY-306G-HV.
There is a continuous noise. I read it is normal because it is a numeric servo but the noise is really annoying.
Better explanation with a small video :
tricopter turnigy talon bruit sur le servo (1 min 1 sec)
I didn't reverse rudder in mixer editor yet ^^
Do you have an idea ?
ziggy95 is offline Find More Posts by ziggy95
Old Jan 17, 2013, 04:34 AM
thwaitm is offline
Team WarpSquad
Joined Jun 2011
When the props start turning you can hear it... unless you put your ear dangerously close to the prop!
Make sure the rear swivel assembly is free to turn and that the links are loose enough, otherwise learn to live with it or buy another servo are your remaining options. Mine also jitters around neutral, not quite as bad as that though.
Old Jan 17, 2013, 04:56 AM
ziggy95 is offline
Joined Jul 2012
Ty thwaitm for your response.
I will do some tests tonight and i will add propellers.
as you say , i will heard it only before flying ^^
But i will search for a solution anyway
Old Jan 17, 2013, 05:49 AM
ziggy95 is offline
Joined Jul 2012
Ok, a french guy with similar problem resolve it with that :
http://www.hobbyking.com/hobbyking/s...dProduct=23206
After , no noise at all.
I will try tonight with this one i have :
Old Jan 17, 2013, 05:50 AM
ziggy95 is offline
Joined Jul 2012
First link was wrong :
http://www.hobbyking.com/hobbyking/s...dProduct=31197
Old Jan 17, 2013, 07:35 AM
Joined May 2011
Interesting to hear how loud that servo is. All my digital servos buzz a little and are high stress constantly trying to be perfectly positioned. They usually settle down. If you give the tail a light push does it stop buzzing? Are you running at 6v or 5v? What flight controller is that? KK2?
H
Old Jan 17, 2013, 08:03 AM
ziggy95 is offline
Joined Jul 2012
Hi,
Servo is powered by a KK2.
Exactly the same for the other friend, KK2 and Turnigy Talon
So, i think its powered with 5v.
Here's the link in the french forum:
http://www.multi-rotor-fans-club.com...p=15801#p15801
Old Jan 17, 2013, 08:06 AM
ziggy95 is offline
Joined Jul 2012
It does't stop buzzing when i move the tail. The noise is very important.
More than what you heard in the video.
But now, i'm pretty sure to drop it tonight
Old Jan 18, 2013, 05:22 AM
ziggy95 is offline
Joined Jul 2012
Bas news, it doesn't work (persistant servo noise).
Good news , my tri is almost ready to fly.
I have only settings PI to do on my KK2
Old Jan 18, 2013, 07:12 AM
thumbglitch is offline
Find More Posts by thumbglitch
Sydney N.S.W Maroubra
Joined May 2007
Guys with the kk2 where do I plug the servo into? Do I plug it into the kk2 or directly to the receiver?
thumbglitch is offline Find More Posts by thumbglitch
Old Jan 18, 2013, 07:13 AM
Joined May 2007
Also just picked one off these up and just about to start assembling it
Old Jan 18, 2013, 08:32 AM
Joined May 2011
Servo goes into #4 on kk2. Not receiver.
Discussion Talon V2 or F450 Frame? solars Multirotor Talk 28 Nov 13, 2015 05:55 PM
New Product Turnigy Talon Carbon Fiber Quadcopter Frame CrashingDutchman Multirotor Talk 510 Jan 20, 2015 02:05 AM
Sold Turnigy Talon V2 Frame $30 / shipped **PRICE REDUCED pefozzy Aircraft - Electric - Multirotor (FS/W) 5 Sep 15, 2012 05:21 PM
For Sale Turnigy Talon Quad Frame V1 penz83 Aircraft - Electric - Multirotor (FS/W) 2 Jun 03, 2012 06:17 PM
Sold universal quad frame and tricopter frame dr rc Aircraft - Electric - Multirotor (FS/W) 4 Mar 07, 2012 08:26 PM
