Old Dec 30, 2012, 07:32 PM
Joe_Wildcat is offline
Find More Posts by Joe_Wildcat
Joe_Wildcat's Avatar
United States, FL, Cocoa Beach
Joined Mar 2011
Home made canopy for the talon
Here's a few pics of the home made canopy I made for my talon tri. It's a 2.5 liter coke bottle heat shrunk over a wooden plug.
Joe_Wildcat is offline Find More Posts by Joe_Wildcat
Old Dec 30, 2012, 08:49 PM
jeffyd123 is offline
Find More Posts by jeffyd123
United States, OR, Bend
very nice joe...
did you weigh the canopy?
some more info of the cutting of the bottle and how you melted it would be great...
thanks thats a great idea.
jeffyd123 is offline Find More Posts by jeffyd123
Old Dec 31, 2012, 01:03 PM
Joined Mar 2011
More detail how to make your canopy
Here is a video showing most of the process.
canopy (0 min 0 sec)
I copied this technique from other rc group users... look around and you will find other examples. i have used this method to make canopies and wheel pants for my foamies, and decided to make a lid for the tri. You are some what limited by the shape and size of the bottle but with some effort you can get some nice results. The finished weight of mine was about 30 grams. I also attached pic of how I secured it with rubber bands.
Joe
Old Jan 01, 2013, 01:52 PM
very cool...
thanks a lot for that video... makes total sense now.... I ddidnt know those bottles shrank like that LOL.
Old Jan 01, 2013, 11:00 PM
bigfella65 is offline
Find More Posts by bigfella65
Australia, NSW, Bathurst
Joined Mar 2009
http://youtu.be/H-VMOIBPuZA
Joe
That is friggin clever mate, will have to give that a go for sure.
bigfella65 is offline Find More Posts by bigfella65
Old Jan 06, 2013, 04:04 PM
Mrhide is offline
Find More Posts by Mrhide
Mrhide's Avatar
Canada, QC, Laval
Joined Aug 2012
Hello,
can somebody please explain to me the difference between different prop configurations/rotation in the tricopter setup?!
I see them all and I'm wondering which one to use. I've configured it like the first one below, prop 3 and 2 but I want to understand why !!
thanks!
Mrhide is offline Find More Posts by Mrhide
Old Jan 06, 2013, 04:30 PM
fantomphish is offline
Find More Posts by fantomphish
gold coast
Joined Jan 2010
Originally Posted by Mrhide View Post
Hello,
thanks!
The first pic are the arms folded for transportation, you don't fly it like that, the others are standard flight configuration and then there's the "T" configuration aswell but to get the "CG" right you have to put the battery on the rear boom, the last pic looks like they have aftermarket extended booms on..
fantomphish is offline Find More Posts by fantomphish
Old Jan 06, 2013, 05:59 PM
Mrhide is offline
Mrhide's Avatar
Canada, QC, Laval
Joined Aug 2012
oh is that why it's not flying so well ?! yeah I figured that much thanks
I'm not talking about the different position of the sticks... what I mean is the CW (clock wise) or CCW (counter clock wise) PROPS configuration. I've seen 2 same on the right and back AND 2 same of the left and back + all 3 the same .... does it make a difference?! it has to right?
Thanks!
Old Jan 06, 2013, 07:56 PM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
Thanks!
On a Tri... not really because you have a servo to move the rear prop to counteract the yaw you get from having all three props spinning in the same direction. The reason for using both CW and CCW props is to try to balance the reaction yaw as much as possible so you have more identical left and right yaw performance.
In a hover, the two front motors basically cancel each others reaction torque out, leaving the servo to counteract only the rear motors torque.
It's possibly slightly more efficient that way but not significantly different. If you could only buy CW props cheaply then you'd not care much.
Similarly, it doesn't matter which way your rear prop turns as long as it is creating lift at least!! but as long as you have 2 of 1 and 1 of another convention is that the the two front props turn in opposite directions and the rear matches one of the front two (this balances the dis-symmetry of lift generated by the two advancing blades better and minimises inherent roll).
thwaitm is offline Find More Posts by thwaitm
Old Jan 06, 2013, 07:57 PM
thwaitm is offline
Team WarpSquad
Joined Jun 2011
Flipping advice request
I flew my tri yesterday (and stuffed it after a failed flip - more like a loop with a discontinuity at the bottom) but I have to say that the self level appears to be working very well with 1.5FW on my KK2 though I normally fly in rate it's nice to have SL if you're very high up or very far out.
On the flipping flipping issue... can anyone point me to what's the stick input I should be looking for to get a nice tight flip? Add throttle then full back elevator until upright (90deg) reduce throttle to below hover thrust maintaining full read elevator and then add power again as the flying thing gets upright again? (This is similar to a Heli flip which has collective unlike the Tri which is FP)
Or just add throttle and maintain full rear elevator?
And if it still takes ages to come around, increase P? decrease I? decrease D?
Any hints anyone...? Thanks.
Old Jan 06, 2013, 08:47 PM
Mrhide is offline
Mrhide's Avatar
Canada, QC, Laval
Joined Aug 2012
That makes sense now! Thank you very much for that answer!
Old Jan 06, 2013, 08:51 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Warthox has a stick video in slow motion.
http://www.rcgroups.com/forums/showthread.php?t=1428309
TheFernMan is offline Find More Posts by TheFernMan
Old Jan 07, 2013, 01:23 AM
thwaitm is offline
Team WarpSquad
Joined Jun 2011
Thanks Fern-ster! So, it's just like a flip on a heli then - which is basically what I was doing... so then I wonder if I need to increase my KK2 AILE/ELEV limits to get a faster flip rate. It seems the difference between front and rear prop thrust is not large enough for a decent flip rate... I'll go try the KK2 thread for that answer.
Old Jan 07, 2013, 06:37 AM
shelterock is offline
Find More Posts by shelterock
Fly, crash, rebuild.
United States, NY, Shelter Island
Joined May 2011
3D stuff requires a higher stick scaling rate. 100+ type stuff. I've been to chicken to try. Also remember that in loops with a multi rotor you need continues power since there is no wing to create lift like a plane or a heli with high rpm rotor. These props drop lift real quick. Cutting power near the top of the loop can be trouble. I would think to stay on the throttle but with higher stick scaling. I use my 3 position switch to offer 3 levels of responsiveness. 1 highest edgy flight with quick to scary response down to 3 for FPV / video smooth flight.
H
shelterock is offline Find More Posts by shelterock
Old Jan 07, 2013, 09:20 AM
thwaitm is offline
Team WarpSquad
Joined Jun 2011
OK shelterock - I see where you're coming from. I'll take a(nother) look at the manual and maybe some vids which I'm sure are around on YT to help me sort it out.
Discussion Talon V2 or F450 Frame? solars Multirotor Talk 28 Nov 13, 2015 04:55 PM
New Product Turnigy Talon Carbon Fiber Quadcopter Frame CrashingDutchman Multirotor Talk 510 Jan 20, 2015 01:05 AM
Sold Turnigy Talon V2 Frame $30 / shipped **PRICE REDUCED pefozzy Aircraft - Electric - Multirotor (FS/W) 5 Sep 15, 2012 04:21 PM
For Sale Turnigy Talon Quad Frame V1 penz83 Aircraft - Electric - Multirotor (FS/W) 2 Jun 03, 2012 05:17 PM
Sold universal quad frame and tricopter frame dr rc Aircraft - Electric - Multirotor (FS/W) 4 Mar 07, 2012 07:26 PM
