Old Nov 26, 2012, 09:16 PM
shelterock is offline
Find More Posts by shelterock
Fly, crash, rebuild.
United States, NY, Shelter Island
Joined May 2011
Originally Posted by R.T.K.F View Post
IMO ditch the NTM motors.. I will be throwing two out of the three in the bin after only two battery test flights.. the prop adaptors are drilled off center as well..
spend the money and get some quality motors / prop hardware so the vibrations are kept to a minimum..
The nut is the problem on the adapter. Try a regular bolt/nylon 5mm bolt and washer.
The motors are not bad. They like to be treated with care.
H
shelterock is offline Find More Posts by shelterock
Old Nov 26, 2012, 11:17 PM
R.T.K.F is offline
Find More Posts by R.T.K.F
Return To Kit Form
R.T.K.F's Avatar
Australia, WA, Joondalup
Joined Oct 2010
Yeh H, changing the nut did the job for vibes, but 2 off 3 motors are RS..
Guess we need to explore the HK quality items limit some times..
R.T.K.F is offline Find More Posts by R.T.K.F
Old Nov 27, 2012, 03:49 AM
AUTO_XX is offline
Find More Posts by AUTO_XX
Canada, AB, Division No. 6
Joined May 2012
I chose to replace all of the "top" bearings with ceramic coated for the NTM 35-36a 910kv motors.
Good enough price but I don't know how well they will stand up yet.
http://www.ebay.ca/itm/190719305307?...84.m1497.l2649
For the bottom bearing I'll be swapping for thrust bearings (on the way), these things have a high load for my heavy lift copters and it makes more sense this way. Time will tell if I have to spin down one side of the race on the lathe.
The little "stag-horn" clips are a PITA too, then bend too easily and pop loose in a crash. Swap 'em out for regular old e-clips.
AFAIK a lathe is almost mandatory for this hobby, with all of the prop adapters, shafts, mounts, etc. that you might need it is impossible to find some of this stuff.
A milling machine has come in handy more than a few times too, once I get the CNC milling machine done (I got a faulty driver) the sky is the limit when it comes to frames and wings Might even CNC the lathe too while I'm at it.
AUTO_XX is offline Find More Posts by AUTO_XX
Old Nov 27, 2012, 06:32 AM
Dimmitri is offline
Find More Posts by Dimmitri
Joined Aug 2012
Hello! Part are welcome if anyone should be already buy http://www.hobbyking.com/hobbyking/s...dproduct=25561
Dimmitri is offline Find More Posts by Dimmitri
Old Nov 27, 2012, 07:29 AM
FlyingGolem is offline
Find More Posts by FlyingGolem
Subsurface flying expert
FlyingGolem's Avatar
United States, CA, Santa Clarita
Joined Oct 2012
No great loss there.. haha..
The pivot setup is rubbish anyway.. Few have posted the mods required for a smooth opperation and reduced load on your servo..
Thank. I'll have to dig back through the thread and find those mods then.
FlyingGolem is offline Find More Posts by FlyingGolem
Old Nov 27, 2012, 08:48 AM
Joined May 2011
$20 for all that might be a good first buy but if you need only the pushrods it's a bit steep. 25% of the cost of the entire frame. What a rip or kick in the teeth.
H
Old Nov 27, 2012, 10:16 AM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
the KK2 is $20! lol
TheFernMan is offline Find More Posts by TheFernMan
Old Nov 28, 2012, 03:52 AM
AUTO_XX is offline
Joined May 2012
Originally Posted by TheFernMan View Post
the KK2 is $20! lol
Looks like a permanent price too! Good news for the hobby.
Old Nov 28, 2012, 12:34 PM
henrymoro is offline
Find More Posts by henrymoro
henrymoro's Avatar
Espaņa, Cantabria, Miengo
Joined Jul 2007
Hi Guys,
I have now my Talon tricopter with emp motors N2830-1120 / 3s 2200 and Apc 9x4.7 and I feel i have no enough power to get it in the air with the gopro.
I would like to mount T-Motor, any of you may suggest me Motor/Prop for using with 3s 2200 batt ?
Thanks!
henrymoro is offline Find More Posts by henrymoro
Old Nov 29, 2012, 06:04 PM
Joined May 2011
Originally Posted by henrymoro View Post
Hi Guys,
Thanks!
Do you have the best tool in the hobby? A watt meter? Your EMPs are barely working. Throw a 4S on there and see what you get.
I've been playing with 1000kV and between 3S and 4S is a big difference. On 4S she'll have plenty of lift. Cheaper to buy batteries than new motors. Especially T-motors
H
Old Nov 29, 2012, 06:06 PM
Joined May 2011
The frame at 221mm seems to struggle with props bigger that 10". I'm tweaking 11" sf props and she's a handful with big wobbles. Going back to 9 or 10" 3 blades. She flew really well on 10x6x3. Not much power on 3s with 9x5x3.
H
Old Nov 29, 2012, 07:41 PM
powerstroke01 is offline
Find More Posts by powerstroke01
powerstroke01's Avatar
USA, CA, Ahwahnee
Joined Sep 2004
Anyone have pics of their tail assembly? Im getting frustrated cause i dont know how to attach the metal tail piece to the servo arm.. Do i drill out the holes?
powerstroke01 is offline Find More Posts by powerstroke01
Old Nov 30, 2012, 12:43 AM
AUTO_XX is offline
Joined May 2012
Yep, you'll need to take the servo arm of your choice and line it up with the center of the aluminum piece (Very important they line up).
Then it is just a matter of screwing the aluminum piece on or pre drilling with an undersized hole and screwing it on (I did this).
It might be a good idea to clamp it too if you don't want to hold three things lined up at once
It is a poor design and looks like an afterthought but what are you gonna do? The slot should have been made a bit wider to let it slide back and forth till it's centered and then tightened afterward. The good news is that the screws hold very well in the servo arm so you won't need to worry about it in the future. My camera was stolen a few months ago or I would take a quick pic for you. it isn't hard, just make sure the centers line up.
Old Nov 30, 2012, 06:23 AM
USA, CA, Ahwahnee
Joined Sep 2004
Thanks!
Old Dec 02, 2012, 05:06 PM
3rdeyepro is offline
Find More Posts by 3rdeyepro
Hovership
3rdeyepro's Avatar
United States, CA, Cupertino
Joined Aug 2010
Some video from Thanksgiving weekend
Dreams of Turkey (2 min 44 sec)
3rdeyepro is offline Find More Posts by 3rdeyepro
Discussion Talon V2 or F450 Frame? solars Multirotor Talk 28 Nov 13, 2015 04:55 PM
New Product Turnigy Talon Carbon Fiber Quadcopter Frame CrashingDutchman Multirotor Talk 510 Jan 20, 2015 01:05 AM
Sold Turnigy Talon V2 Frame $30 / shipped **PRICE REDUCED pefozzy Aircraft - Electric - Multirotor (FS/W) 5 Sep 15, 2012 04:21 PM
For Sale Turnigy Talon Quad Frame V1 penz83 Aircraft - Electric - Multirotor (FS/W) 2 Jun 03, 2012 05:17 PM
Sold universal quad frame and tricopter frame dr rc Aircraft - Electric - Multirotor (FS/W) 4 Mar 07, 2012 07:26 PM
