Old Nov 20, 2012, 04:58 PM
shelterock is offline
Find More Posts by shelterock
Fly, crash, rebuild.
United States, NY, Shelter Island
Joined May 2011
Originally Posted by Jelico View Post
Im flying mine with the HH2.0 V1.4 and DJI 2212 920 kv motors on 3S.
It flies OK but isnt amazing. Wondering who makes the best flight controller for around $200 USD fir tricopters?
Looking for something relatively easy to setup with a Naza style autolevel.
Also, can someone tell me the best balance point for this tricopter (with the arms set on the middle settings)
The balance point should be in the middle of your flight controller. The flight controller should be at the intersection of the 3 arms.
As far as choice of flight controller the kk2 is an exceptional value and field friendly controller. Naza doesn't work with a Y3 config.
The best choice seems to be the feature rich arducopter APM2.5 / knock-offs, multiwii variants and the great white elk "openpilot". Much talked about but hard to spot!
I have flown a quad with naza GPS and it was good. For 1/10th the price I love the KK2! I don't lose sleep over a crash or loss of my craft.
H
shelterock is offline Find More Posts by shelterock
Old Nov 20, 2012, 05:11 PM
Jelico is offline
Find More Posts by Jelico
Joined Jul 2008
thank you for the answers. On this I dont think you can get the controller exactly at the intersection of the three arms, but I should try and balance the battery at the intersection anyway?
I really wish the Naza ran tricopters.. so easy and fun to fly! The KK2.0 is fine but not quite as stable as the Naza
Jelico is offline Find More Posts by Jelico
Old Nov 20, 2012, 05:39 PM
Joined May 2011
The battery is actually quite forward of the KK2. I hang it right in front of the 4 bolts holding on the camera plate. 3300 3S and 2200 a little further forward. Best test is to hold the rig ready for flight by the center of the kk board edge and see if she balances. If your battery is underneath she'll be tail heavy.
H
Old Nov 21, 2012, 02:51 PM
AUTO_XX is offline
Find More Posts by AUTO_XX
Canada, AB, Division No. 6
Joined May 2012
Originally Posted by shelterock View Post
8000! wow, that's got to be a heavy battery. I don't think I'd have the focus for 20+ minutes of flying. I think my brain starts to struggle at about 10min of intense flying or wonders off out of boredom.
3300mAh in free flight , ziping around, gives me 10 minutes at 80% consumed.
I may try a 4000-5000 based on your test. You also have big motors on your Tri 35-36 If I recollect.
H
Yeah, I'm using 910kv 35-36 NTMs
The zippy 8000 3 cells are about 600grams so really they only bring the all up weight to 1.8kg with full fpv gear.
AUTO_XX is offline Find More Posts by AUTO_XX
Old Nov 23, 2012, 09:10 AM
dums2000 is offline
Find More Posts by dums2000
France, Auvergne, Clermont-Ferrand
Joined Jul 2012
hello guys,
I am very happy with my talon tricopter ...and had ever done some great flys with it ...but sadly this afternoon...got a crash with a tree...and so the turnigy 306G tail servo is damaged.
( http://www.hobbyking.com/hobbyking/s...dProduct=22687 )
unluckily this one is in back order for now , what do you suggest as replacement ?
Thanks !
Christophe.
dums2000 is offline Find More Posts by dums2000
Old Nov 23, 2012, 11:48 AM
rumbey is offline
Find More Posts by rumbey
Speed is Good!
rumbey's Avatar
Chippenham, Wilts
Joined Oct 2005
Just fitted a manual servo gimbal for my Gopro. Works great no jello apart from vibration on take off and descending to quickly. I'm liking the straight down view.
rumbey is offline Find More Posts by rumbey
Old Nov 23, 2012, 02:25 PM
3rdeyepro is offline
Find More Posts by 3rdeyepro
Hovership
3rdeyepro's Avatar
United States, CA, Cupertino
Joined Aug 2010
Where did you pick that up? I just ordered one from goodluckbuy similar to it.
3rdeyepro is offline Find More Posts by 3rdeyepro
Old Nov 23, 2012, 03:49 PM
rumbey is offline
Speed is Good!
rumbey's Avatar
Chippenham, Wilts
Joined Oct 2005
I got it with my locust fpv quad but modified it slightly. I prefer the Tricopter Replaced the pan servo with the wooden pine block. I just need to sort out a smoother operation maybe in the TX or buy a servo regulator.
Goodluckbuy do the locust quad - http://www.goodluckbuy.com/locust-fo...gopro-ptz.html
Old Nov 23, 2012, 04:23 PM
Joined May 2011
Well tried to fine tune my gemfan 11x4.7 sf and can't get her smooth. 10x6x3 were great, as we're the 9x5x3 GWS props. Anyone else try these?
H
Old Nov 24, 2012, 04:57 AM
rumbey is offline
Speed is Good!
rumbey's Avatar
Chippenham, Wilts
Joined Oct 2005
I'm using Gemfan 9x4.7. Make sure you balance the hub as well. You will note on all the gemfans (the ones I have anyway) One side has flashing that needs to be removed to balance
Flood Tour Slaughterford with Turnigy Talon Tricopter (5 min 6 sec)
Old Nov 25, 2012, 10:57 PM
FlyingGolem is online now
Find More Posts by FlyingGolem
Subsurface flying expert
FlyingGolem's Avatar
United States, CA, Santa Clarita
Joined Oct 2012
Alas, I just received my Talon and was very excited to commence the build. Right up to the point where I found out it is missing one of the two bearings for the tail rotor assembly. As getting any useful, let alone timely, help from HK is unlikely, does anyone have the specs on this piece? Any potential sources for a replacement?
FlyingGolem is online now Find More Posts by FlyingGolem
Old Nov 26, 2012, 01:56 AM
WitnessOnly is offline
Find More Posts by WitnessOnly
Cleared for take off...
WitnessOnly's Avatar
Australia, VIC, Melbourne
Joined Jan 2010
A lot of useful bits in here for the talons yaw system. Thrust bearings and alike, ball and sockets are compadible also....
http://www.hobbyking.com/hobbyking/s...450_HK450.html
WitnessOnly is offline Find More Posts by WitnessOnly
Old Nov 26, 2012, 09:53 AM
powerstroke01 is offline
Find More Posts by powerstroke01
powerstroke01's Avatar
USA, CA, Ahwahnee
Joined Sep 2004
Here is my cart so far. Ive already got esc's on the way and i have a distrobution board already..
Every thing look ok?
powerstroke01 is offline Find More Posts by powerstroke01
Old Nov 26, 2012, 04:52 PM
R.T.K.F is online now
Find More Posts by R.T.K.F
Return To Kit Form
R.T.K.F's Avatar
Australia, WA, Joondalup
Joined Oct 2010
IMO ditch the NTM motors.. I will be throwing two out of the three in the bin after only two battery test flights.. the prop adaptors are drilled off center as well..
spend the money and get some quality motors / prop hardware so the vibrations are kept to a minimum..
R.T.K.F is online now Find More Posts by R.T.K.F
Old Nov 26, 2012, 04:54 PM
Return To Kit Form
R.T.K.F's Avatar
Joined Oct 2010
No great loss there.. haha..
The pivot setup is rubbish anyway.. Few have posted the mods required for a smooth opperation and reduced load on your servo..
Discussion Talon V2 or F450 Frame? solars Multirotor Talk 28 Nov 13, 2015 04:55 PM
New Product Turnigy Talon Carbon Fiber Quadcopter Frame CrashingDutchman Multirotor Talk 510 Jan 20, 2015 01:05 AM
Sold Turnigy Talon V2 Frame $30 / shipped **PRICE REDUCED pefozzy Aircraft - Electric - Multirotor (FS/W) 5 Sep 15, 2012 04:21 PM
For Sale Turnigy Talon Quad Frame V1 penz83 Aircraft - Electric - Multirotor (FS/W) 2 Jun 03, 2012 05:17 PM
Sold universal quad frame and tricopter frame dr rc Aircraft - Electric - Multirotor (FS/W) 4 Mar 07, 2012 07:26 PM
