Well my servo stripped out. Was flying in the dome and it started spinning. Went about 1.5 revolutions and I was able to put it down. Heard the servo buzzing but the arm was spinning freely. I read the reviews saying the splines strip, looks like the case.
I think I should have gone with the 922 or a different servo. Wish I could repair it. |
United States, NY, Shelter Island
Joined May 2011
H |
Maidened mine today after a quick check in the garden. Absolutely a great bit of kit and with the KK2.0 v1.4 self level is perfect. I did reduce the settings to 80 from 100 as it snapped level too quickly for my liking! The gopro footage isn't bad considering I just used some small rubber washers on the Gopro mount board. The only things I really have to do is sort out the tail servo setip already discussed and get some decent props although the Gemfams from HK were reasonable.
Think I will try 1047 or 1147 props next time out and angle the gopro down to avoid seeing the props! vid to follow |
I suppose I could take another 306 from my 450 or even a 922 for now... do NOT use the 306. Would hate for anyone to crash their expensive talon because of the tail servo. I will go through some of the gears I have and see of any might fit. Does the tail really need to be that fast? It's not like a heli where the tail rotor acts directly laterally. I wouldn't even mind a mini-sized servo since I have a couple of those lying around that are 0.07s but might be way too heavy plus I'd have to modify the tray. ugh. this servo actually looks really nice. plastic looks like good quality. |
Bit of jello so need to look into improving this.
I think our talon needs something like this to firm up the platform
It was the output shaft. It just sheared. I have another one on a flybar'd 450 but once I test that other servo I will probably order a replacement. Just don't trust these anymore. Oh on another note.. when I landed hard one of the other motor mounts had twisted on the boom. I had never installed the grub screw into the motor mount. Maybe that's a good thing? In a crash then the soft metal has less chance of bending?
There are 4 small rubber washers between camera mount and main frame body. I will be using some moongel when it arrives or some foam from the KK2 packing. The gopro was mounted directly on the carbon frame with 2 elastic bands as I left the peice of rubber mat at home that I planned to sit the gopro on. |
Doug |
Doug |
Canada, AB, Division No. 6
Joined May 2012
I just used a couple of nitro fuel line washers on the mounts, I've never noticed any jello.
*edit* I just got back in from flying the tri on an 8000mah 3s. The flight characteristics were basically the same, just a little slower. Hover was roughly the same position on the stick. 2200mah - 12 minute hover 5000mah - 20 minute hover 8000mah - 22 minute hover (with a bit of wind and a bit of playing) So it looks like the sweet spot is 5A batteries with 11X4.7 props... What is the best resolution to upload vids to youtube? |
| Thread Tools | |
| New Product Turnigy Talon Carbon Fiber Quadcopter Frame | CrashingDutchman | Multirotor Talk | 484 | Apr 08, 2013 04:08 PM |
| Discussion Talon V2 or F450 Frame? | solars | Multirotor Talk | 27 | Apr 07, 2013 01:56 AM |
| Sold Turnigy Talon V2 Frame $30 / shipped **PRICE REDUCED | pefozzy | Aircraft - Electric - Multirotor (FS/W) | 5 | Sep 15, 2012 04:21 PM |
| For Sale Turnigy Talon Quad Frame V1 | penz83 | Aircraft - Electric - Multirotor (FS/W) | 2 | Jun 03, 2012 05:17 PM |
| Sold universal quad frame and tricopter frame | dr rc | Aircraft - Electric - Multirotor (FS/W) | 4 | Mar 07, 2012 07:26 PM |
